SBT Posted June 26, 2016 Share Posted June 26, 2016 What are you using to upload pics? You can save them to your computer, size them to around 640x? and then attach them to here. Or use photobucket With our recent server upgrade, these are the new filetypes and size allowances. http://legacygt.com/forums/attachment.php?attachmentid=232521&stc=1&thumb=1&d=1466724174 - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 26, 2016 Author Share Posted June 26, 2016 Not sure which tmic you have, but I've found leaving the turbo loose on the up pipe until the tmic is located and tighten in the TB hose and turbo outlet is easier. Allows the turbo to move around a bit and help the tmic line itself up. Yeah I remember reading that somewhere now that you mention it, something to note while pulling the damn thing off next weekend. Link to comment Share on other sites More sharing options...
SBT Posted June 26, 2016 Share Posted June 26, 2016 This will be invaluable now and in the future. http://legacygt.com/forums/attachment.php?attachmentid=167975&d=1384657978 - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted June 26, 2016 Author Share Posted June 26, 2016 I have that printed out sitting with all the new hoses and vacuum lines. The only problem is that diagram is for an aftermarket EBCS, beyond that everything else is good on it. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted July 2, 2016 Author Share Posted July 2, 2016 Turbo is back off, might be time for a new downpipe. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2016 Share Posted July 2, 2016 The service manual has a vacuum hose map in the back of it. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted July 3, 2016 Author Share Posted July 3, 2016 Thanks! Link to comment Share on other sites More sharing options...
SBT Posted July 3, 2016 Share Posted July 3, 2016 I'm sure you already have a copy of this, but posting just in case. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted July 4, 2016 Author Share Posted July 4, 2016 Indeed I do, thanks though. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted July 9, 2016 Author Share Posted July 9, 2016 Rotella T6 ok for startup? Link to comment Share on other sites More sharing options...
rhino6303 Posted July 9, 2016 Share Posted July 9, 2016 Rotella T6 ok for startup? Don't use synthetic on a rebuilt or new engine right away. Use the cheapest dino oil you can find for the first startup and dump, or spend the $$ on something like Brad Penn/Joe Gibbs break-in oil. Link to comment Share on other sites More sharing options...
SBT Posted July 9, 2016 Share Posted July 9, 2016 Don't recommend synthetic for start-up/break-in on a new/rebuilt engine. Redline has an engine break-in oil additive. For a new/rebuilt engine, I do the startup/warmup on straight dino, then immediately change the oil and filter (again with straight dino) and add the Redline Break-in Additive. Then I drive it relatively easy (no WOT/4K RPM limits) for the first 100 miles At 100 miles replace the oil/filter with straight dino, and repeat the process again at 200, 300, 500 mile intervals. At a 1000 miles, I run the synthetic of my choice. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted July 9, 2016 Author Share Posted July 9, 2016 Copy that. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 1, 2016 Author Share Posted August 1, 2016 Does anyone have a pic of how the harness is ran across the back of the engine? Mine is in the way of the TB elbow and I can't figure a way to move it. Link to comment Share on other sites More sharing options...
StkmltS Posted August 1, 2016 Share Posted August 1, 2016 I can take a few pics of my IM/harness/everything tonight after work if you don't figure it out before then. I left everything connected to the IM when I took it off. It's just laying on a shelf so I can get a photo at pretty much any angle you need. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 1, 2016 Author Share Posted August 1, 2016 I would really appreciate that. I don't remember how or when mine got separated because it's been so god damn long. Anything under the intercooler pointing towards the harness. I can't find any pics of that area. I can't recall if the harness runs along the intake manifold, and how things like the connectors up towards the front of the engine (boost solenoid etc) are exactly threaded through there. I feel like I'm gonna have to pull the intake manifold again. Link to comment Share on other sites More sharing options...
freaksavior Posted August 1, 2016 Share Posted August 1, 2016 You check Max's thread? http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106p4.html Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 1, 2016 Author Share Posted August 1, 2016 These pics on page 9 are pretty close, but he has done something different with his hoses. That hard breather tube that runs along the back and to both valve covers is missing. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106p9.html Look I'm just gonna throw some pics up and if anyone can tell me whats phucked up that would really help a lot. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 1, 2016 Author Share Posted August 1, 2016 Pis of the chaos. The picture where I'm pointing is the pipe that the right port on the passenger side valve cover goes on correct? The left port goes up to the pcv tube. I know the damn hoses go right to them but the way this thing is fitting back together some things just feel out of place. I'm feeling that some of it may be the hose kit I bought, it's bigger in diameter than the old hoses. So places like between the turbo/intercooler connection I can't fit the harness down in it because of the bigger hoses. Link to comment Share on other sites More sharing options...
StkmltS Posted August 1, 2016 Share Posted August 1, 2016 I'm not familiar enough with the backside of the motor to be able to answer confidently from my desk at work... but I think you're correct about the picture your hand is in. That's the line that crosses over and connects to the driver side head? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 1, 2016 Share Posted August 1, 2016 I'd have to agree with that. There are two ports off the valve cover. I have that plastic pipe removed because of the AOS. Is this any help, http://i185.photobucket.com/albums/x40/92Si/DSCN4714.jpg http://i185.photobucket.com/albums/x40/92Si/DSCN4705_zps2a4d6923.jpg Make sure you put these ground wires back on the ground bar. http://i185.photobucket.com/albums/x40/92Si/DSCN4706_zps5ba71203.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
StkmltS Posted August 2, 2016 Share Posted August 2, 2016 Here's the backside of my IM mess. Not sure if it'll be helpful because of what's missing, but the wiring harness is untouched as far as the location/routing goes. http://uploads.tapatalk-cdn.com/20160802/2b36b38e70e9b02331fb13ccf0c2e75e.jpg http://uploads.tapatalk-cdn.com/20160802/2ca092acc461350695049ff6cb1f261d.jpg http://uploads.tapatalk-cdn.com/20160802/81a9e7940b9d22517834f636701eeb7a.jpg My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 2, 2016 Author Share Posted August 2, 2016 Yeah, as of right now my harness goes across (in front of) the TB, blocking the elbow from being put on properly and thus I can't get the intercooler on. I seem to not have enough slack to drape it over the top as it sits. From your guy's pictures, the harness runs along the top of the hard plastic breather tube, mine currently does not. Also, where the harness runs to the front of the engine, it looks like both of yours goes between the plastic tube and the intake, mine goes under the tube then to the front. That's probably where the extra slack went. Thank you guys so much. Link to comment Share on other sites More sharing options...
StkmltS Posted August 2, 2016 Share Posted August 2, 2016 Glad we could help. Please make checks payable to "Andrew's Rebuild", PO box... My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted August 2, 2016 Author Share Posted August 2, 2016 Don't cash it until December of next year please. Link to comment Share on other sites More sharing options...
