jojorios Posted February 10, 2016 Share Posted February 10, 2016 On/off as in where to tap into power? Or are you not planning on using the remote? Link to comment Share on other sites More sharing options...
wrxwhit Posted February 10, 2016 Author Share Posted February 10, 2016 See, still learning. Technically I don't need a switch if the remote will power the demons on and off correct. I certainly don't want them to come on with daytime running lights/headlights etc. only for special situations . So really just need to hook up to battery power and use remote to turn on and off? Link to comment Share on other sites More sharing options...
jojorios Posted February 12, 2016 Share Posted February 12, 2016 I wired it to my front positioning lights if I recall. So they only work with the car on, and then I control on/off with the remote. I didnt want to wire them to the battery just incase I forgot to shut them off. I do plan on adding a switch to my halo drls in the cabin so I can have demon eyes on only for fun. Sent from my SAMSUNG-SM-N915A using Tapatalk Link to comment Share on other sites More sharing options...
Bootyologist Posted February 13, 2016 Share Posted February 13, 2016 Used eBay lens baking for separation http://uploads.tapatalk-cdn.com/20160210/988874a7aefe4d099f7b2b164545960f.jpg Was smart this time and used a pan covered in tin foil and placed perfectly so no craziness happens again I set mine on an old towel that was on top of a cookie sheet. Thought the bare sheet would get too hot. Well the towel moved and a corner slipped down through the grate and started to smolder. Kitchen was full of smoke, and the wife was not impressed. Luckily I caught it in time and didn't start a fire. Sent from my Nexus 5X using Tapatalk Link to comment Share on other sites More sharing options...
Ellesedil Posted February 13, 2016 Share Posted February 13, 2016 I set mine on an old towel that was on top of a cookie sheet. Thought the bare sheet would get too hot. Well the towel moved and a corner slipped down through the grate and started to smolder. Kitchen was full of smoke, and the wife was not impressed. Luckily I caught it in time and didn't start a fire. Sent from my Nexus 5X using Tapatalk Sounds like the oven was on too high? Link to comment Share on other sites More sharing options...
ssulb Posted February 16, 2016 Share Posted February 16, 2016 How hard was it to retro fit the projectors? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
TwoTone Posted February 16, 2016 Share Posted February 16, 2016 How hard was it to retro fit the projectors? Sent from my iPhone using Tapatalk If you can bake the headlights open, these are a bolt in kit. https://www.theretrofitsource.com/complete-retrofit-kits/application-specific/morimoto-retro-quik-system-subaru-legacy-2003-2009.html#.VsJvBvIrL-g Link to comment Share on other sites More sharing options...
fedaykin Posted February 16, 2016 Share Posted February 16, 2016 If you're not confident enough to stick your headlights into an oven, grab a heat gun and a lot of patience. I took mine apart with a cheap heat gun, a screwdriver and being gentle (the back plastics are quite soft). Your aim is to get the sealant soft enough so you can pry the lens off. Link to comment Share on other sites More sharing options...
ssulb Posted February 16, 2016 Share Posted February 16, 2016 If you can bake the headlights open, these are a bolt in kit. https://www.theretrofitsource.com/complete-retrofit-kits/application-specific/morimoto-retro-quik-system-subaru-legacy-2003-2009.html#.VsJvBvIrL-g I was actually going to buy these but I was just wondering if there's any differences or if it's just bolt on. I am planning on modifying the Special Appearance OEM headlights but I am going to use a heat gun on low to separate the housing. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
wrxwhit Posted February 16, 2016 Author Share Posted February 16, 2016 Direct fit Link to comment Share on other sites More sharing options...
wrxwhit Posted February 24, 2016 Author Share Posted February 24, 2016 Which 194 led position lights to get. I'm thinking a 5000k non 360 led as you probably don't want these lights to be bouncing all over the place correct? Link to comment Share on other sites More sharing options...
Zee199969 Posted February 24, 2016 Share Posted February 24, 2016 I got these for my position lights: http://www.vleds.com/shop-bulb-numbers/194-168-158-led/360/6-5k.html The lumen rating isnt so crazy that I would be blinding people with em. It illuminates the reflectors just enough and has the one LED on top shining forward My "Build" Link to comment Share on other sites More sharing options...
wrxwhit Posted February 24, 2016 Author Share Posted February 24, 2016 Yes, yes thanks Zee man!! Link to comment Share on other sites More sharing options...
Zee199969 Posted February 24, 2016 Share Posted February 24, 2016 I can snap a pic of them tomorrow to give you a better idea of what I'm talking about My "Build" Link to comment Share on other sites More sharing options...
wrxwhit Posted February 24, 2016 Author Share Posted February 24, 2016 If you don't mind Link to comment Share on other sites More sharing options...
vikcity Posted February 24, 2016 Share Posted February 24, 2016 I have the exact same position lights along with 5k hids and 5k led fog lights and they all look great. The position lights linked above do a good job a filling the lens without being too bright. Color is pretty close too. I wouldn't say it actually looks this bright but you can see if fills the headlight well: http://uploads.tapatalk-cdn.com/20160224/db31f10fb1446f6dc476fbe28b193264.jpg Sent from my LG-H900 using Tapatalk Link to comment Share on other sites More sharing options...
ssulb Posted February 24, 2016 Share Posted February 24, 2016 I bought some cheap LED bulbs from Amazon and put them in for the side markers. I hate how at night they look red-ish to me a little as you can see in the photo. http://i1166.photobucket.com/albums/q615/sebastiansulborski/Forum%20Pictures/Legacy/DSC_4629.jpg I got these for my position lights: http://www.vleds.com/shop-bulb-numbers/194-168-158-led/360/6-5k.html The lumen rating isnt so crazy that I would be blinding people with em. It illuminates the reflectors just enough and has the one LED on top shining forward I would like to see how those LEDs look like. Bet they aren't that bad. Link to comment Share on other sites More sharing options...
Zee199969 Posted February 25, 2016 Share Posted February 25, 2016 Here you go whit! hope this also helps you ssulb My "Build" Link to comment Share on other sites More sharing options...
wrxwhit Posted February 25, 2016 Author Share Posted February 25, 2016 Yes, confirmed my purchase!That 2nd pic in the parking garage really shows the true color and level of brightness. I can't wait to get these things back in the car. What did you do for your high beams Link to comment Share on other sites More sharing options...
Zee199969 Posted February 25, 2016 Share Posted February 25, 2016 I bought some cheap LED bulbs from Amazon and put them in for the side markers. I hate how at night they look red-ish to me a little as you can see in the photo. Maybe try the 194 flank bulbs from vleds for the sidemarker. I probably should've swapped the stock ones out when installed the 2013 special appearance headlights My "Build" Link to comment Share on other sites More sharing options...
Zee199969 Posted February 25, 2016 Share Posted February 25, 2016 What did you do for your high beams I got some LED high beams from Perscitus. They're really bright for high beam usage. I unplugged the DRL resistor so they're off unless I turn em on with the stalk My "Build" Link to comment Share on other sites More sharing options...
wrxwhit Posted February 25, 2016 Author Share Posted February 25, 2016 That's my plan also to disable the DRL. I was thinking LED too for high beams or some crap 5000k xenon as I rarely ever use high beam. Need money for V3 Accessport :0 Link to comment Share on other sites More sharing options...
matts_pats Posted February 25, 2016 Share Posted February 25, 2016 Where did you buy your 2013 headlights? eBay? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted February 25, 2016 Share Posted February 25, 2016 Rockauto had one side that was a closeout price for around $90. Got the other side a lil later as I was trying to see if that would be discounted as well. I like the cutoff that these give over my OEM ones, but that could be due to having a brand new housing lens. My "Build" Link to comment Share on other sites More sharing options...
marcin93 Posted February 25, 2016 Share Posted February 25, 2016 Contemplating retrofitting my anzo's.... Link to comment Share on other sites More sharing options...
