msmith Posted January 10, 2006 Share Posted January 10, 2006 I did check it. It's secure. My signal was strong pre-install, and now my 'normal' stations won't come in well, nor any at all really. Reception was fine before I installed everything (even though I have metallic tint). Perhaps the combo of tint plus gear = Yeah, that sucks... I vote for the metallic tint+gear theory. The metallic tint is probably containing the RF emitted by the electronics much more than if you didn't have it on there. I used non-metallic tint and have zero problems. You could redo the rear window in non-metallic and see if that helps. Link to comment Share on other sites More sharing options...
PGT Posted January 10, 2006 Share Posted January 10, 2006 maybe a Fuba mounted VW style is the solution. Link to comment Share on other sites More sharing options...
SVXWRX Posted January 10, 2006 Share Posted January 10, 2006 what ever happened to antenna boosters? the local Pepboys and Advance Auto used to carry them, but now they are no where to be found? my FM is "OK", with the occaisional crackle, but i'm running a dual diversity tuner deck with an auxillary antenna, and it should sound "VERY VERY GOOD." i didn't have much luck searching online for an antenna booster under $30, either. anyone know a good place to get one? EDIT: nevermind, i found a few. Link to comment Share on other sites More sharing options...
PGT Posted January 10, 2006 Share Posted January 10, 2006 booster = amplifier. If the antenna isn't getting anything because of noise/tint issues, then all you amplify is noise. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 11, 2006 Share Posted January 11, 2006 Us wagons get the antenna on the side rear glass, i think, or more antenna's My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
SVXWRX Posted January 11, 2006 Share Posted January 11, 2006 booster = amplifier. If the antenna isn't getting anything because of noise/tint issues, then all you amplify is noise. thanks - i have an EE degree. i guess i was off-topic a bit. back on topic - i assume you don't have the front windshield tinted? if not, i've seen a powered "blade" antenna that mounts to the inside of a window - it might not be too out of place above the rear view mirror near the headliner. ??? EDIT: hey, i found it - http://www.audio-warehouse.com/web/mdl/44-UA200/detail.asp Link to comment Share on other sites More sharing options...
PGT Posted January 17, 2006 Share Posted January 17, 2006 Yeah, that sucks... I vote for the metallic tint+gear theory. The metallic tint is probably containing the RF emitted by the electronics much more than if you didn't have it on there. I used non-metallic tint and have zero problems. You could redo the rear window in non-metallic and see if that helps. I'm not hearing static. I'm hearing warble tones, or digital switching noise. Some stations are strong enough to overpower it (though not enough to be noise free), but the tuner locks on to every step when I hit 'seek'. So, 102.7, then 102.9. then 103.1, etc. Link to comment Share on other sites More sharing options...
msmith Posted January 17, 2006 Share Posted January 17, 2006 It's likely the switching power supplies of one or both of the amplifiers... disconnect the turn on lead of the 500/1 to see if the noise goes away. We need to at least determine which component is the primary transmitter. I still think retinting with non-metallic on the back window might be the only real fix. Link to comment Share on other sites More sharing options...
Coyote65 Posted January 17, 2006 Share Posted January 17, 2006 When I'd re-assembled after pulling the radio, I had also lost radio reception, but it turned out I'd used the antenna amplifier power lead instead of the auxillary power lead for the amp turn on line. After swapping things back everything was good to go. Could that be the problem? (seems as not, but I'm a firm believer in Occam's Razor). Link to comment Share on other sites More sharing options...
PGT Posted January 18, 2006 Share Posted January 18, 2006 It's likely the switching power supplies of one or both of the amplifiers... disconnect the turn on lead of the 500/1 to see if the noise goes away. We need to at least determine which component is the primary transmitter. well, as soon as it stops raining I will test the tint - open the hatch up and roll all the windows down - if the FM comes back, we know the culprit Then, cycle through each component to see which one is the leaky bastard. I still think retinting with non-metallic on the back window might be the only real fix. is right Link to comment Share on other sites More sharing options...
rockford33 Posted January 18, 2006 Share Posted January 18, 2006 I'm not hearing static. I'm hearing warble tones, or digital switching noise. Some stations are strong enough to overpower it (though not enough to be noise free), but the tuner locks on to every step when I hit 'seek'. So, 102.7, then 102.9. then 103.1, etc. I have the exact same problem now after getting everything installed. More of a warble tone than static, and the search button now hits every frequency. I might look into a solution when it gets warmer out. Link to comment Share on other sites More sharing options...
msmith Posted January 18, 2006 Share Posted January 18, 2006 Hmmm.... do you also have metallic tint, rockford33? Yours is a sedan, right? Link to comment Share on other sites More sharing options...
rockford33 Posted January 18, 2006 Share Posted January 18, 2006 Hmmm.... do you also have metallic tint, rockford33? Yours is a sedan, right? I do have a sedan. I told them I needed non-metallic tint because of possible radio issues. Based on price, I am pretty sure it is not ceramic (only paid $160 I think for the whole tint job), maybe it is dyed. I'll have to check the info they provided me when I had everything done. If it is metallic, I will be a little pissed..... I looked at the website just now. I believe I have the Johnson Window Films RayGuard tint, which is non-metallic and the Johnson site states it is non-conductive so as not to interfere with GPS, rear window antennas, etc. So I am not sure what my issue would be. Link to comment Share on other sites More sharing options...
PGT Posted January 18, 2006 Share Posted January 18, 2006 what amps are you running? Link to comment Share on other sites More sharing options...
rockford33 Posted January 18, 2006 Share Posted January 18, 2006 what amps are you running? JL 500/1 and JL 300/4 Link to comment Share on other sites More sharing options...
PGT Posted January 18, 2006 Share Posted January 18, 2006 my guess is that we are hearing switching noise from the 500/1. Either that or the CleanSweep is singing it's own tune. Should be able to test it by pulling out the turn-on lead from the 500/1. Link to comment Share on other sites More sharing options...
rockford33 Posted January 18, 2006 Share Posted January 18, 2006 my guess is that we are hearing switching noise from the 500/1. Either that or the CleanSweep is singing it's own tune. Should be able to test it by pulling out the turn-on lead from the 500/1. Unfortunately, I won't be able to play with the car until next weekend since I am out of town this weekend. If you do find that hepls your situation, let me know and I will try it on mine. If that is the case for both, we may have found our problem. Link to comment Share on other sites More sharing options...
msmith Posted January 18, 2006 Share Posted January 18, 2006 Yup, you should both disconnect the turn-on lead of the 500/1 to see if the problem disappears... if it persists with the 500/1 disconnected, then proceed to disconnect the turn-on lead of the other amplifier and see if the station seek behavior normalizes (you won't be able to hear the station, obviously). If the problem persists after that, it's the CleanSweep (unlikely). If it's the 500/1 causing the interference, please post the serial numbers of those amplifiers... I need to see what revision they are. If they are old, I may be able to get them checked out and updated for you guys, which might help. Link to comment Share on other sites More sharing options...
PGT Posted January 25, 2006 Share Posted January 25, 2006 my noise is from the 500/1 one - emailed my S/N. Design suggestion for the CleanSweep - can you make the AUX in or switched lead turn the unit on as well vs. only the speaker inputs? I leave my radio off if just using the iPod. Not a big deal, but seems like it would be a minor fix. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 25, 2006 Share Posted January 25, 2006 there is a switch for that already..i think My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PGT Posted January 25, 2006 Share Posted January 25, 2006 there is a switch for that already..i think so, RTFM eh? :laugh: So, with it turned off, it defaults to the switched lead. Perfect. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 26, 2006 Share Posted January 26, 2006 hehe, i never have my stock radio on now that I got XM My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mikeyd Posted January 26, 2006 Share Posted January 26, 2006 Hello, just wanted to throw in my opinion of the cleansweep. It's an outstanding product! Check out my thread of my install for more info: http://legacygt.com/forums/showthread.php?t=26678 Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
Xantium Posted January 26, 2006 Share Posted January 26, 2006 any idea if you can get an extra silver knob (the kind that comes with clean sweep) to put on my rbc-1... basically what you did. Link to comment Share on other sites More sharing options...
mikeyd Posted January 26, 2006 Share Posted January 26, 2006 any idea if you can get an extra silver knob (the kind that comes with clean sweep) to put on my rbc-1... basically what you did. Well you could pm msmith (Manville Smith - JL guy), he was real nice about getting me a calibration CD despite the fact that I bought the cleansweep online which JL does not condone. He may be able to send you one. That knob does match nice though and its a good size. Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
