seanyb505 Posted March 21, 2016 Author Share Posted March 21, 2016 It's late March, at it was 35 degrees. COMMON THIS IS WHY I'M DOING IT NOW AND NOT CHRISTMAS EVE Link to comment Share on other sites More sharing options...
StkmltS Posted March 21, 2016 Share Posted March 21, 2016 I feel your pain. My ringland-mobile has been forced into DD duty become my '92 corolla DD has a fuel supply problem that I refuse to work when it's cold outside. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
cBax Posted March 21, 2016 Share Posted March 21, 2016 I was happy to see 35 deg temps this past weekend. 3-4" of snow today...not crazy about that. You'll be sweating soon enough. I don't miss living in GA at all. '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
seanyb505 Posted March 21, 2016 Author Share Posted March 21, 2016 True. That. Got the cam bolts out. Vice grips and belt method. Honestly nothing to it with a jack handle on the end of a breaker bar. I tried a few other methods first, but only having one breaker bar held me up. Link to comment Share on other sites More sharing options...
seanyb505 Posted March 29, 2016 Author Share Posted March 29, 2016 Between family doctor visits and less than ideal parts, I missed the timeline. There were a few days where I couldn't get started in the garage until 1pm. I think I'm within two full days until first fire, about what I missed throughout the week. At 203k miles, the car still had banjo filters, and catted up pipe. To my knowledge the tune was stock as well. The turbo, while covered in leaked antifreeze, is in phenomenal shape. Zero shaft play. My guess is the turbo had to have been replaced, and at least 3yrs/50k miles ago. Other fun learnings include shredded ground wires, missing down pipe bracket bolts, seized turbo bolts, obvious tgv gasket leakage, and a broken crank gear tooth for the crank position sensor. Link to comment Share on other sites More sharing options...
cBax Posted March 29, 2016 Share Posted March 29, 2016 Go ahead and multiply that forecast by at least 2. haha. I'm laughing with you, not at you. Any juicy pics for the peanut gallery? '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
seanyb505 Posted March 29, 2016 Author Share Posted March 29, 2016 How's this for "juicy": http://i161.photobucket.com/albums/t217/seanyb505/Message_1458682850306_zpswgnbthfz.jpg I've tried to take a lot of pics. Unfortunately some of the more complicated stuff is lacking visual documentation as I was trying to focus on the task at hand. I'll get some more up in time line fashion soon. Link to comment Share on other sites More sharing options...
seanyb505 Posted March 31, 2016 Author Share Posted March 31, 2016 As the engine sits now: http://i161.photobucket.com/albums/t217/seanyb505/20160331_080819_HDR_zpslmaxqqws.jpg Still need to install up, turbo, coolant reservoir, filtered oil line, flywheel and clutch. And timing covers obviously, but I'm waiting to prime the engine before that. Link to comment Share on other sites More sharing options...
SBT Posted March 31, 2016 Share Posted March 31, 2016 Looking good Sean. Almost ready to oil-fill. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Max Capacity Posted April 1, 2016 Share Posted April 1, 2016 Did I tell you to trial mount the tmic to the TB and turbo before you install the engine ? I've learned to leave the turbo loose on the uppipe until I have all the bolts started the TB hose tight. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
seanyb505 Posted April 1, 2016 Author Share Posted April 1, 2016 Grimmspeed intercooler, flexible hoses and all that. Link to comment Share on other sites More sharing options...
SBT Posted April 2, 2016 Share Posted April 2, 2016 Get your GS TMIC mounts in-place while the engine is out... Will make it easier afterwards to just install the TMIC. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
seanyb505 Posted April 4, 2016 Author Share Posted April 4, 2016 So...I drove it to work today. I need some better updates for this thread. I've a garbage ton of info and pics. Link to comment Share on other sites More sharing options...
StkmltS Posted April 4, 2016 Share Posted April 4, 2016 Did I tell you to trial mount the tmic to the TB and turbo before you install the engine ? I've learned to leave the turbo loose on the uppipe until I have all the bolts started the TB hose tight. And check you oil, our cars use it. :lol: #LTTL (leave the turbo loose) My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
cBax Posted April 4, 2016 Share Posted April 4, 2016 So...I drove it to work today. I need some better updates for this thread. I've a garbage ton of info and pics. Congrats!! '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
seanyb505 Posted April 5, 2016 Author Share Posted April 5, 2016 Well I've got about 50 miles on the engine and p0011 popped up. Luckily I was just outside the neighborhood so I reset the code and turned around. No noises or anything. The right vvt reading has been low since first start. Link to comment Share on other sites More sharing options...
SBT Posted April 5, 2016 Share Posted April 5, 2016 Check Scruit's issue with "sealant" in/around that area, and VVT solenoid readings. Possible you have a plug/dam in your oil flow there. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
cBax Posted April 5, 2016 Share Posted April 5, 2016 ^^ I'm worried about that myself. I do think that those passages are low pressure drain backs though. Meaning that the AVCS would still function, just leak oil out the seal instead of draining back to the head. Good luck '05 Outback XT www.facebook.com/baxleysspeedshop www.baxleysspeedshop.com Link to comment Share on other sites More sharing options...
seanyb505 Posted April 5, 2016 Author Share Posted April 5, 2016 I made special effort to push something stiff through those passages after I installed the cam cradle. When they came back mostly clean I figured there shouldn't be enough remaining RTV to be a restriction. Link to comment Share on other sites More sharing options...
SBT Posted April 6, 2016 Share Posted April 6, 2016 Possible leak on the front of the AVCS pulley... just running through my mind of what it could possibly be that would be VVT-related. Connector on that bank? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted April 6, 2016 Share Posted April 6, 2016 Also, check the cam position sensor connector on bank one - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Scruit Posted April 6, 2016 Share Posted April 6, 2016 https://www.youtube.com/watch?v=qNlghZi21Wk https://www.youtube.com/watch?v=7W28wd8Z624 Link to comment Share on other sites More sharing options...
seanyb505 Posted April 6, 2016 Author Share Posted April 6, 2016 Great vids, I definitely think I used the lesser amount in the first vid. I know I've got an oil drip from the drivers driver's side timing cover, but I'm surprised on the passenger it's so bad it's causing codes. Link to comment Share on other sites More sharing options...
seanyb505 Posted April 14, 2016 Author Share Posted April 14, 2016 Hasn't been much progress lately, with tax season and all. I removed the engine just to have an easier time working with valve covers and such. The driver's side is ready to go back together. There didn't seem to be any rtv gunking up the cradle oil channels, but then again the driver's side wasn't throwing any codes. Just waiting to go pick up new cam seals. I didn't like the way the exhaust seal fit on the cam, or the way the intake fit on the cam gear. Also going to install the seals when bolting the cam cradle down, as opposed to pounding in the seal with the special tool aka giant socket. Any reason not to do it this way? Link to comment Share on other sites More sharing options...
SBT Posted April 14, 2016 Share Posted April 14, 2016 Look at Scruit's build. He did it with the cam cradle off to make it easier and better sealed. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
