Scottydunno Posted March 15, 2018 Share Posted March 15, 2018 Just went for a drive with the mod in place. I love it! It really improved the overall feel and control. It is also much easier now to revmatch resulting in very smooth gear changes and stuff. Even my wife who is currently learning how to drive, she was able to master it very quickly. So, we may not have to get a car with an auto after all I thought the purpose of us driving stick was to avoid our other halves driving said car.... Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 15, 2018 Share Posted March 15, 2018 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 17, 2018 Share Posted March 17, 2018 I did the mod to the 06 as well. Same comment. It's really great. It should have been like this from the factory. As far as I understand, it looks like it was like that before 2002 or so. And then they started to add these nonsense dampeners. My conclusion: every single LGT/OBXT owner with a stick should absolutely do this mod. Link to comment Share on other sites More sharing options...
Rhitter Posted March 18, 2018 Share Posted March 18, 2018 (edited) I just did this mod. My initial thought is - it didn't do anything. Second thought the clutch is slightly more vibraty. It makes backing up easier I guess, it's a little easier to tell when the engine is going to stall going up a hill. Driving around I haven't felt that much. I wonder if I still have air in the clutch lines / MC / SC. I notice a really small difference. But, not sure it was worth it yet. I did find what I think was corrosion on the MC that was preventing the dampener from sealing and contributed to a slow leak. Hopefully that's fixed. Edited March 18, 2018 by Rhitter My OBXT build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 18, 2018 Share Posted March 18, 2018 I guess YMMV. Did you have to do the slave as well? Link to comment Share on other sites More sharing options...
Rhitter Posted March 18, 2018 Share Posted March 18, 2018 Yep. I'll drive it in stop and go traffic tomorrow. That will provide a better sense. My OBXT build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 18, 2018 Share Posted March 18, 2018 That's strange. I would think you would be able to feel even more improvement than I since I only had to modify the master cylinder. Link to comment Share on other sites More sharing options...
Rhitter Posted March 19, 2018 Share Posted March 19, 2018 I wonder if some of it is because I have like every single drive line upgrade I can get. I am curious if that makes a difference. I have group-n motor / transmission mounts, dogbone, poly transmission bracing mounts, every rubber part that can be changed in / around the transmission, rear diff inserts, probably more that I don't remember. I am curious if those helped removing the jerkiness (and it was far jerkier before I replaced all these). Need to get my wife into my car again and see if she notices the engagement point better. But, she sucks at stick and I am not sure she has enough background to notice. My OBXT build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 19, 2018 Share Posted March 19, 2018 That would actually be a good test though. If the engagement point is indeed better, she would probably not stall it. My wife basically mastered it. Went for another drive with her today and she did great. I also went and did some light off-roading last week and it was definitely easier to start on rough terrain uphill from a standstill. Even backing up is more predictable. But it is true that you do have a lot of mods that could have helped as well already. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 23, 2018 Share Posted March 23, 2018 So Rhitter, still not noticing any improvement? I just drove the 06 (for the second time after the mod) and I can definitely make smoother and more predictable gear changes now. Also noticed that in the past, that car was having the idle bounce a bit when I was slowly engaging the clutch in first gear. Now, that's gone. I was blaming dirty throttle body or something but I guess I was wrong. Link to comment Share on other sites More sharing options...
gkinslow Posted March 23, 2018 Share Posted March 23, 2018 What type of difference (if any) has anyone noticed shifting during WOT pulls? Anyone with >400whp do this mod yet? Definitely intriguing. Wish I had done this when I replaced my clutch master cylinder a while back. Link to comment Share on other sites More sharing options...
solidxsnake Posted March 23, 2018 Author Share Posted March 23, 2018 I did this very shortly after buying my LGT (walkthrough posted in May '15, I bought the car late March '15). I was coming from an 8th gen ('02) Corolla, and I was very confused when occasionally I would bog the car or have a rough start, especially on hills, when I'd been driving very smoothly on the Corolla for years, but I chalked it up to not knowing the car. Once I did this mod, I realized that it wasn't me, but the lack of response the stock setup gives, mainly in the delayed transient response when you're moving the clutch quickly, like a hill start, or a shift during a WOT pull. I don't think I WOT pulled the car at all before I did this mod, but I've definitely had no trouble making smooth shifts at WOT after doing it. Link to comment Share on other sites More sharing options...
Infosecdad Posted March 23, 2018 Share Posted March 23, 2018 This is on my short list... was thinking of waiting until I did my clutch, but might do it before; if I can just get work time burn under control... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 23, 2018 Share Posted March 23, 2018 It should just take you 45mn really. Link to comment Share on other sites More sharing options...
Flinkly Posted March 23, 2018 Share Posted March 23, 2018 45 minutes to remove and replace the master damper and bleed the system?!? i haven't done it cause i'm afraid of running out of time and needing my DD. and i've temporarily lost my garage parking spot. and it's cold and wet and slanted in my driveway. and i'm lazy. lol. * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 24, 2018 Share Posted March 24, 2018 (edited) 45 minutes to remove and replace the master damper and bleed the system?!? i haven't done it cause i'm afraid of running out of time and needing my DD. and i've temporarily lost my garage parking spot. and it's cold and wet and slanted in my driveway. and i'm lazy. lol. Yeah. I mean it's not hard. Take the intercooler off, take the juice out of the master cylinder using a syringe or the like, remove the dampener, put your bolt, refill, bleed, intercooler back. done . Edit: I should add that I did not remove the master cylinder from the car. I followed covertrussian method to remove the dampener. It was quick and easy. I did have to buy the tool (forget how it is called) at Ace though. And I did not change the line either. Just installed the bolt. And the 45mn time only applies to folks with the LGT/OBXT without the additional dampener in the slave. Edited March 24, 2018 by xt2005bonbon Link to comment Share on other sites More sharing options...
Rhitter Posted March 25, 2018 Share Posted March 25, 2018 (edited) Flinkly it took me 2.5 hours. Completely removed my GS tmic, disconnected and completely removed the slave cylinder and master reservoir, looking for all my scattered tools, losing them multiple times in the middle, and getting my wife to help me bleed the system. After doing it I think it's worth it. I would do it again. Before the mod I thought the engagement point was near the top of the clutch pedal travel. Now I know it's at the top. It's subtle, I am curious how different clutches feel with the mod. Maybe I would not have burned out my last clutch in 20k miles if I had done this. I think 1.5 hours is reasonable if I had read the directions in advance and knew where my tools were and didn't keep losing everything I set down. and it's cold and wet and slanted in my driveway. and i'm lazy. lol. It's not worth doing when cold and wet. It's not that big of an improvement. Wait until the weather improves. Edited March 26, 2018 by Rhitter My OBXT build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 3, 2019 Share Posted December 3, 2019 Let me bump this thread. I think my question is related to its content... Has anyone seen this master cylinder design before? I decided to buy a new one from a subaru dealer (via ebay), gave my car specs and I got this one. Is there a damper hidden in there? I hope not ... Link to comment Share on other sites More sharing options...
gkinslow Posted December 3, 2019 Share Posted December 3, 2019 Yeah I blew the bottom out of that one in 2 months. Then I bought this Exedy replacement that was actually cheaper: Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 3, 2019 Share Posted December 3, 2019 mmmh. Yeah, I think I have also read similar issues with wrx/sti owners. Then, I should probably return that thing ASAP. Dang it. Thanks for the info about the Exedy replacement. Part number? Link to comment Share on other sites More sharing options...
gkinslow Posted December 3, 2019 Share Posted December 3, 2019 MC586 Should be $40 or so. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 3, 2019 Share Posted December 3, 2019 Dang, that's way cheap. Just spent 150$ for that OEM one... Link to comment Share on other sites More sharing options...
gkinslow Posted December 3, 2019 Share Posted December 3, 2019 (edited) I said the same after buying one for triple the price and it lasting 2 months. The Exedy has lasted much longer. I thought Exedy was the OEM supplier for the clutch master cylinder... Edit: http://shop.exedyusa.com/store/product/itmgroupdetail.aspx?groupid=52788&make=SUBARU Edited December 3, 2019 by gkinslow Link to comment Share on other sites More sharing options...
airgasm Posted December 4, 2019 Share Posted December 4, 2019 Did y'all remove the damper from Exedy, too? Crossing fingers that I have better luck with new OEM piece because I literally put that sucker in few weeks ago. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 4, 2019 Share Posted December 4, 2019 Which sucker did you put? The same one I just bought? Link to comment Share on other sites More sharing options...
