FLlegacy Posted September 4, 2015 Share Posted September 4, 2015 Nothing like firing up a engine you took apart yourself and it purring like a kitten! Good job thanks for sharing this with us! Link to comment Share on other sites More sharing options...
BBPeik Posted September 6, 2015 Author Share Posted September 6, 2015 Took her out today for a ten mile run. All seems to check out great. HDSS clutch took a bit of getting used to. That along with the damper removal made it a bit weird the first few starts. Computer is still re learning a bit, but overall it ran amazing. Here is a pic of the engine finished and installed. Now on to better things like wheels. http://i1378.photobucket.com/albums/ah113/BBPeik/finished_zpstpnywdtd.jpg My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
DrD123 Posted September 6, 2015 Share Posted September 6, 2015 brake fluid is looking pretty dark... Link to comment Share on other sites More sharing options...
BBPeik Posted September 6, 2015 Author Share Posted September 6, 2015 Its brand new ATE blue My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted September 23, 2015 Author Share Posted September 23, 2015 This is a bit late but figured I should keep my build thread up to date. Last Friday the 18th I got new wheels and a DAMD steering wheel that I got from Jackal. The Wheels are TSW Nurburgring Bronze 19"x8" 45 offset. Tires Hankook Ventus V12 Evo110 245/40/19. http://i1378.photobucket.com/albums/ah113/BBPeik/20150918_142639_zpsqpmheyjj.jpg My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted May 14, 2016 Author Share Posted May 14, 2016 So I figured that since I am doing the engine swap I should keep my build thread up to date. Should have the swap done in a few days then I have the tune. Thanks again to Swannee for the swap opportunity. The link to the swap thread is below to keep things congruent. http://legacygt.com/forums/showthread.php/bbpeik-swannee-engine-swap-251678.html The Engine is as follows Bored and honed with torque plates 3angle valve job, resurface and set lash CP pistons ARP head studs King main bearings King rod bearings 11mm STi oil pump OEM water pump Manley rods. Sti heat treated crank. STI Cams BNR 20G turbo w/ ported WG GFB Mach 2 BPV Invidia Catted DP Grimmspeed EBCS ACT HDSS Clutch w/ stock flywheel Cobb 725cc Injectors DW200 Fuel Pump AEM Wide band O2 I think that is about it. I will post more once it is all finished. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted May 14, 2016 Author Share Posted May 14, 2016 Figured while I was at it I should make a list of everything that I have done to my car so far since I purchased it almost exactly 2 years ago. The swap above obviously TSW Nurburgring Bronze 19x8 Bilstein Struts Eibach Springs Eibach 22mm RSB Whiteline 24MM FSB Plastidip Grill LGT badges Blacked out headlights Accessport V3 STI shifter Damd Wheel Perrin brass shifter bushing Perrin short shift adapter Clutch damper delete SPT Boost Guage Stoptech cross drilled rotors ATE blue brake fluid and clutch fluid Perrin intercooler coupler Rear window spoiler(it fell off still gotta put it back on) Perrin Steering dampner lockdown And trust me the to do list is still a mile long My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
KCLeo12 Posted May 15, 2016 Share Posted May 15, 2016 Nice build we gotta meet up for a drive sometime. Link to comment Share on other sites More sharing options...
BBPeik Posted May 15, 2016 Author Share Posted May 15, 2016 For sure. I wander all over SD so I am sure we could find a place to meet up. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 10, 2016 Author Share Posted June 10, 2016 So now I am back to my regular build thread. Since I am limited by my intercooler I am going to start looking into making a fmic setup. Not sure of the detail yet, but that seems the easiest way to go. I had thought about just modding a mishimoto fmic kit for a wrx, but they cost a small fortune. So now I am looking into what I would need to make my own setup. One thing is for sure though. It will be much less expensive than another option and really should be pretty easy. Heres hoping. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 11, 2016 Author Share Posted June 11, 2016 Finally finished making the mount for my wideband gauge today. Pretty happy with the results. Also re mounted my rear window spoiler. It had started to come loose a few months back and I pulled it off. Finally got around to pulling the old double stick off and applying new stuff. http://i1378.photobucket.com/albums/ah113/BBPeik/20160611_161741_zpsr3ddpjng.jpg My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
Bloobaru Posted June 16, 2016 Share Posted June 16, 2016 Thanks a lot for the thread Brendan. Outstanding job with the photos and great-looking LGT. Very informative. Link to comment Share on other sites More sharing options...
Mrstacy Posted June 16, 2016 Share Posted June 16, 2016 I haven't heard of too many fifth generation front mounts. i'm very interested in this part especially. i have a 2012 that i'd like to do. Your build may inspire me to do an upgrade or two. Link to comment Share on other sites More sharing options...
Zee199969 Posted June 16, 2016 Share Posted June 16, 2016 I haven't heard of too many fifth generation front mounts. i'm very interested in this part especially. i have a 2012 that i'd like to do. Your build may inspire me to do an upgrade or two. ebo03 has a front mount on his 5th gen. there was another member on here that did also but I cant recall their name since they are not very active, at least not as of late. My "Build" Link to comment Share on other sites More sharing options...
BBPeik Posted June 16, 2016 Author Share Posted June 16, 2016 ^^^I am going to try the process west top mount first. If that does not work I may go FMIC. We will see. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
cww516 Posted June 16, 2016 Share Posted June 16, 2016 ebo03 has a front mount on his 5th gen. there was another member on here that did also but I cant recall their name since they are not very active, at least not as of late. I was gonna take a crack at s2 (not very active = stuck in a garage, etc.), but I don't know if he has a FMIC yet, so I'd just end up looking dumb. Link to comment Share on other sites More sharing options...
Ellesedil Posted June 16, 2016 Share Posted June 16, 2016 ebo03 has a front mount on his 5th gen. there was another member on here that did also but I cant recall their name since they are not very active, at least not as of late. SomeZero has (had?) one. He stopped posting last year (and his last post was pretty cryptic, indicating he was going to part things out). http://legacygt.com/forums/showthread.php/somezero-s-slo-lgt-214909.html?t=214909&highlight=fmic Link to comment Share on other sites More sharing options...
Zee199969 Posted June 16, 2016 Share Posted June 16, 2016 SomeZero has (had?) one. http://legacygt.com/forums/showthread.php/somezero-s-slo-lgt-214909.html?t=214909&highlight=fmic That's who I was thinking of, but the only username that came to mind was Darksabre, who did not have an FMIC My "Build" Link to comment Share on other sites More sharing options...
foxrider28 Posted June 17, 2016 Share Posted June 17, 2016 There's this fmic JDM wagon. http://legacygt.com/forums/showthread.php?p=4350016 Link to comment Share on other sites More sharing options...
FLlegacy Posted June 17, 2016 Share Posted June 17, 2016 Italian legacy has a fmic...on his 3.6. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
BBPeik Posted June 23, 2016 Author Share Posted June 23, 2016 Installed the Process West top mount intercooler. http://legacygt.com/forums/showthread.php/process-west-wrx-verticooler-installation-253808.html My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted July 20, 2016 Author Share Posted July 20, 2016 Keeping things up to date. Process West IC installed along with racer x CP(thanks minuccims) My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted August 16, 2016 Author Share Posted August 16, 2016 Mishimoto Radiator installed http://legacygt.com/forums/showthread.php/mishimoto-sti-08-radiator-install-255262.html My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted August 26, 2016 Author Share Posted August 26, 2016 Primitive skid plate installed My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted September 9, 2016 Author Share Posted September 9, 2016 I have been making a list of all my mods, so I can have them displayed at Subiefest. This is what I have so far. If any of you think of something I forgot please let me know so I can add it to the list . Here is what I have so far. Thanks Engine: EJ255 Stage 3 tuned by Bren Tuning and built by Infamous Performance Escondido CA Accessport V3 Bored and Honed with torque plates 3 Angle valve job CP pistons Manley Rods ARP Head Studs King main and rod bearings STI heat treated crank 11mm STI oil Pump STI intake and exhaust camshafts BNR 20G VF54 turbo with ported wastegate Process West 2015 WRX Verticooler Racer-X Charge pipe Turbosmart kompact bypass valve Mishimoto STI-08 Radiator Grimmspeed 3 port EBCS Cobb 725cc injectors DW200 fuel pump Invidia Catted Downpipe AEM wideband AF sensor Transmission: STS short shifter Perrin brass shifter bushing Perrin WRX short shift adapter ACT HDSS with stock flywheel Clutch Damper delete Suspension/Brakes: RCE Bilstein Worx struts Eibach sport springs 24mm Whiteline front sway bar 22mm Eibach rear sway bar Perrin steering dampner lockdown Stoptech cross drilled rotors Interior/Exterior: TSW Nurburgring Bronze 19x8 245/40/19 Blacked out headlights Plastidip Grill L7 emblem overlays Rear window spoiler SPT boost gauge DAMD Steering Wheel Subaru Logo puddle lights Primitive racing skid plate My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
