ammcinnis Posted December 5, 2016 Share Posted December 5, 2016 TSB was published to STIS on 11/21/2016 Hmmm. I can't find it on STIS ... either in the "What's New" section or searching the TSB section by year, model, and trim. I can find TSB [15-]203[-16], 204, 206, and 207, but no 205. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Fiatz79 Posted December 5, 2016 Share Posted December 5, 2016 I brought this to the dealer this morning. (Car is in for wind noise). We'll see what happens. I'd just like to have a mute on the Nav. ;-) Lighting Mods Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS Subaru 20mm RSB Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 5, 2016 Share Posted December 5, 2016 There's nothing on that tsb. Where did this update come from Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
Opie Posted December 7, 2016 Share Posted December 7, 2016 TSB is there, not sure why I can see it and you guys can't. Downloaded it HERE Edit: fixed link Link to comment Share on other sites More sharing options...
Fiatz79 Posted December 7, 2016 Share Posted December 7, 2016 Well... Had TSB# 15-205-16 patches installed today. (It DOES indeed exist). There is now a mute button for NAV. The compass and TBT on the dash are not working so it's back to the dealer in the morning. Thinking the HU probably needs a hard reset. Will keep you posted. Haven't had a chance to play with the rest. Lighting Mods Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS Subaru 20mm RSB Link to comment Share on other sites More sharing options...
Opie Posted December 7, 2016 Share Posted December 7, 2016 Well... Had TSB# 15-205-16 patches installed today. (It DOES indeed exist). There is now a mute button for NAV. The compass and TBT on the dash are not working so it's back to the dealer in the morning. Thinking the HU probably needs a hard reset. Will keep you posted. Haven't had a chance to play with the rest. Look on Page 19 of the TSB I posted and perform the Memory Clear Procedure, that should reset it. It will also wipe out most of your settings; radio stations, Bluetooth connections, etc that will need to be reset after. Save you a trip to the dealer. Link to comment Share on other sites More sharing options...
Fiatz79 Posted December 7, 2016 Share Posted December 7, 2016 Look on Page 19 of the TSB I posted and perform the Memory Clear Procedure, that should reset it. It will also wipe out most of your settings; radio stations, Bluetooth connections, etc that will need to be reset after. Save you a trip to the dealer. Thanks Opie, Tried the reset and still have the issues. Fortunately, the dealer is 5 minutes away. Going bright and early!! Lighting Mods Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS Subaru 20mm RSB Link to comment Share on other sites More sharing options...
Fiatz79 Posted December 7, 2016 Share Posted December 7, 2016 All fixed now. One of the update files was corrupted. Re-flashed in about 45 minutes. Now for the joy of redoing all of the settings. (It's worth it just for the mute button). Seems to load a bit faster. Will check about the other listed fixes later. Lighting Mods Low Beams: D4S - OSRAM XENARC 66440 CBI HID BULBS Highbeam/DRL: 9005 - OSRAM NIGHT BREAKER UNLIMITED 9005NBUHCB BULBS Fog: H11 - OSRAM NIGHT BREAKER UNLIMITED 64211NBU-01B BULBS Subaru 20mm RSB Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 7, 2016 Share Posted December 7, 2016 . Link to comment Share on other sites More sharing options...
vicvega Posted December 7, 2016 Share Posted December 7, 2016 So the question is going back to the title, does Mirrorlink work after the update? Right now I have it working but I had to downgrade my Samsung Galaxy S3 to jellybean 4.3 which is on a RingPlus plan. I would like to use my HTC 10 which has the Mirrorlink service running but the phone is running Android 6.0 Marshmallow and won't link to the head unit. Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 7, 2016 Share Posted December 7, 2016 So the question is going back to the title, does Mirrorlink work after the update? Right now I have it working but I had to downgrade my Samsung Galaxy S3 to jellybean 4.3 which is on a RingPlus plan. I would like to use my HTC 10 which has the Mirrorlink service running but the phone is running Android 6.0 Marshmallow and won't link to the head unit. Sent from my HTC 10 using Tapatalk I have the samsung s7 active and it works It's really stupid though. I have navigation and that's all its really good for though. Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
vicvega Posted December 8, 2016 Share Posted December 8, 2016 I have the samsung s7 active and it works It's really stupid though. I have navigation and that's all its really good for though. Sent from my SAMSUNG-SM-G891A using Tapatalk Interesting. Any specific steps or suggestions as to how you got it to work? Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 8, 2016 Share Posted December 8, 2016 Interesting. Any specific steps or suggestions as to how you got it to work? Sent from my HTC 10 using Tapatalk Assuming you have the headunit updated there are mirrorlink apps you have to install on your phone. Mirrorlink doesn't just work by itself. Also make sure the mirrorlink setting is enabled on your phone. If you go to the mirrorlink website it will tell you the apps available. Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 8, 2016 Share Posted December 8, 2016 To make this clear you can't mirror your phone screen to your headunit. Despite the name mirrorlink it is sort of just another version of Android auto but a lot worse. It's really pointless. It's good if you have the non nav unit because you can download a mirrorlink GPS app. Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
vicvega Posted December 8, 2016 Share Posted December 8, 2016 I'm a developer myself and IT engineer. Just Linux isn't my cup of tea. I'm sure there are some good coders that can make it happen. I suggested on another post that over at XDA developers when they are in need of rooting an unrootable phone they put a bounty out and get the job done. They can make it happen and work as expected if enough folks put in the request. Just a thought. Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
vicvega Posted December 13, 2016 Share Posted December 13, 2016 Ford owners with SYNC 3 will be able to upgrade their head units to Apple Car play and Android auto to some older models. Subaru, are you listening?!? I had contacted Subaru a few months ago on this and I did tell them don't tell me we'll forward the information to the engineers etc but they never replied. I guess they didn't like that I knew what their response would be. Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
chadam1978 Posted December 14, 2016 Share Posted December 14, 2016 shall we start a petition? Link to comment Share on other sites More sharing options...
chadam1978 Posted December 14, 2016 Share Posted December 14, 2016 what would be the least expensive mirror link capable android phone I should get in order to run sygic and or similar apps? I have unlimited data on my iPhone 6 and can just weather to the android phone as a slave in a sense? Thoughts Link to comment Share on other sites More sharing options...
ammcinnis Posted December 14, 2016 Share Posted December 14, 2016 I had contacted Subaru a few months ago on this and I did tell them don't tell me we'll forward the information to the engineers etc ... Do you really expect anybody in Subaru customer service to have the authority to halt production until the infotainment system is modified to satisfy your desires? "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
vicvega Posted December 14, 2016 Share Posted December 14, 2016 Ahm, no. I have no expectations and that's not the point. The point is, it would be nice if they offered the upgrade even if we the consumer had to pay for it. Head units have ROM memories or what they called back in the day EPROMs which can be reflashed/reprogrammed. Capiche? Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
chadam1978 Posted December 16, 2016 Share Posted December 16, 2016 So what would be the least expensive android phone that works with mirror link such as sygic? Link to comment Share on other sites More sharing options...
vicvega Posted December 17, 2016 Share Posted December 17, 2016 I have a Galaxy S3 with Android 4.3 Jellybean and it works as expected with drivelink installed. Sent from my HTC 10 using Tapatalk Link to comment Share on other sites More sharing options...
CT2015Legacy Posted December 20, 2016 Share Posted December 20, 2016 shall we start a petition? Let's do it and get it started. Post it on the Outback forum as well. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
chadam1978 Posted December 21, 2016 Share Posted December 21, 2016 That was my thought. Why not, what do we have to lose? In the meantime, Vicvega mind taking a pic of what sygic looks like on your Legacy's head unit please? I am curious to see what a gps app would look like on the screen:) Thank you kindly Link to comment Share on other sites More sharing options...
