dukeneverwinter Posted March 28, 2015 Share Posted March 28, 2015 Starting tomorrow, I will be undertaking my biggest project on my 08 outback XT 5MT. Since the car has 97k miles, I figured I should do the timing belt. Tomorrow is going to be the last weekend day I will have free for a while. Might as well do it now, instead of waiting six or more months. Also, after doing the vf52 upgrade and custom tune for the dw65 pump and Perrin DP I have decided to upgrade my clutch at the same time! Guess what that means. Upgrade and refresh time! So here is a list of parts I will be installing tomorrow, some for fun, some because why not. The engine is coming out and a lot of things will be super easy to get to. Timing belt, and pulleys, etc. ALL OEM including bolts. Water pump, OE Cam shaft seals Crank seal Rear main seal Valve cover gaskets, inner and outer, plus half moon seals Flywheel resurface OEM wrx 06+ Exedy stage 1 organic Killer B oil pickup and baffle, might as well check the stock right? And if I am in there , might as well uprgrade right? Piece of mind? Oil cooler gasket Group n motor mounts Group n trans mount Perrin crank pulley(pure BLING!) Don't know why I bought it..... Grimmspeed master cylinder brace It's going to be a busy day, I'll post picks along the way. Some things are left out because they were done very recently (plugs,t-stat,etc) Link to comment Share on other sites More sharing options...
Pazuzu Posted March 28, 2015 Share Posted March 28, 2015 sounds like a busy day Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 28, 2015 Author Share Posted March 28, 2015 3hours later and the engine is out. I guess we are slow. http://tapatalk.imageshack.com/v2/15/03/28/7473e3c3d4844bb6cebaf90d3656f876.jpg Link to comment Share on other sites More sharing options...
2006 Subaru Legacy GT Posted March 28, 2015 Share Posted March 28, 2015 Keep us updated.... Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 28, 2015 Author Share Posted March 28, 2015 97k 5mt snout before installing TSK. does it need it? Who cares, I got and am installing it.http://tapatalk.imageshack.com/v2/15/03/28/aca4e294cea88613aef9b442ca8266ce.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 28, 2015 Author Share Posted March 28, 2015 Old clutch. Unsure on mileage http://tapatalk.imageshack.com/v2/15/03/28/f3b5c546a2782f4f9c14feeade3a9225.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 28, 2015 Author Share Posted March 28, 2015 Menu for the dayhttp://tapatalk.imageshack.com/v2/15/03/28/d4e42422ff3f95b699743f617b01ff40.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 29, 2015 Author Share Posted March 29, 2015 Timing belt on, bling pulley on. All new timing bolts and pulleys and water pump and camshaft/crankseals!http://tapatalk.imageshack.com/v2/15/03/28/85ed26962c6ba57eba26eb001925902e.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 29, 2015 Author Share Posted March 29, 2015 I got to borrow three special service tools for working with the pulleys and timing belt. My buddy didn't have the tool for the drivers side exhaust pulley. We had to use the old timing belts wrapped around a ton of stuff and clamped via vice grips. Man, those pulleys are on SUPER right. Having the right tools made it a lot easier for the other three pulleys. http://tapatalk.imageshack.com/v2/15/03/28/cce1955ccb91712e4b53cfc08fc07f9c.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 Such tiny cams http://tapatalk.imageshack.com/v2/15/03/30/26c68a74b4a50194fd55d4e6d2774abc.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 I had three of the four special tools for the timing belt and can seals. This is how we dealt with the last pulley.http://tapatalk.imageshack.com/v2/15/03/30/16efda6d3c737892b7b4fccd98fe31ba.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 My buddy that helpedhttp://tapatalk.imageshack.com/v2/15/03/30/f83b748744bc1074a238885999d01100.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 Old vs newhttp://tapatalk.imageshack.com/v2/15/03/30/189b4f266f1760727ef756c1fd5de2e1.jpghttp://tapatalk.imageshack.com/v2/15/03/30/2f1182740a08a5d624a98da141f25343.jpghttp://tapatalk.imageshack.com/v2/15/03/30/12349f8c43bbace5be2a1b2850a3c79b.jpg Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 And going back in!http://tapatalk.imageshack.com/v2/15/03/30/d31b5de3f67f5533777ae68ef92e3b35.jpg Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 31, 2015 Moderators Share Posted March 31, 2015 Nice work. I plan to do something similar in the next little bit here but I'm planning to take at least 2 weeks worth of evenings to get it all done "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 It's my daily driver. Has to be running Monday through Friday!! Link to comment Share on other sites More sharing options...
NewJerseyDevil Posted March 31, 2015 Share Posted March 31, 2015 awesome Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2015 Share Posted March 31, 2015 Not sure if it's to late...but I would not put a stage 1 clutch in these cars. I did a Spec 2 and it lasted 45,000 miles before it started slipping in 5th gear. I now have a Spec 2+. Good luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 31, 2015 Moderators Share Posted March 31, 2015 Not sure if it's to late...but I would not put a stage 1 clutch in these cars. I did a Spec 2 and it lasted 45,000 miles before it started slipping in 5th gear. I now have a Spec 2+. Good luck. Under reasonable power levels and not launching the car and shifting properly, a stock (or similar style) clutch should last longer than just about any aftermarket or "upgraded" clutch option. Seems most aftermarket clutches wear much faster regardless of having better holding capacity. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Flinkly Posted March 31, 2015 Share Posted March 31, 2015 Ha, if you think the pulley is bling, then why the master brace? The pulley actually made a noticable difference (GS here) where the brace was my biggest waste of funds so far. Normal things like flushing fluid and good pads way more useful, or a booster swap. Just sayin, even though i did the same thing. Sent from my XT1028 * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2015 Share Posted March 31, 2015 Under reasonable power levels and not launching the car and shifting properly, a stock (or similar style) clutch should last longer than just about any aftermarket or "upgraded" clutch option. Seems most aftermarket clutches wear much faster regardless of having better holding capacity. Yea, if you drive like your grand mother... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 31, 2015 Author Share Posted March 31, 2015 Blead the brakes recently, and I can actually feel a difference with the brace. Sure it is also bling, but I was curious. Also, because step 1 in the instruction for the brace is 'remove engine' I thought I would throw money at grimmspeed. Instead of flushing it down a toilet! Link to comment Share on other sites More sharing options...
Flinkly Posted March 31, 2015 Share Posted March 31, 2015 remove engine? lol. I don't remember that one, but i'm sure I laughed when I installed mine (no engine removal). it does look cool in the engine bay, except i'm the only one who looks in there. the sti/wrx booster is a next step, if you haven't upgraded to lgt calipers/rotors/pads already. at least the lgt rear is ventilated (good for heavy load/trailer hauling). * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
MrTris Posted March 31, 2015 Share Posted March 31, 2015 OP, I like your pictures and content. Would like to have them in the Build Theads subforum. If you want to move it there, click Thread Tools at the top of your first post, then Move Thread, and select Build Threads. Link to comment Share on other sites More sharing options...
Mike07LGT Posted March 31, 2015 Share Posted March 31, 2015 How do you like the pulley? Im getting ready to do my timing belt and was thinking of upgrading while im in there. Also anything else you feel should be done at the same time as the belt and water pump and thermostat? 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
