Rhitter Posted February 27, 2015 Share Posted February 27, 2015 225 is a good width. Lights. The LGT lights universally suck. Look for upgrades. Especially if you do much night driving. Undercar protection. The hard skid plate pays off, especially if you live on rough roads or potholes. Interior - Double-Din upgrade. I never did it, as no justification. One of the few things I wish I had done. There are several threads on this. 225 is boring 245/45/18 is where it's at. This should fit with a spec.b suspension and rolling the rear fenders. Danteleon in the Outback pictures forum has them mounted up. http://legacygt.com/forums/showpost.php?p=4398532&postcount=17 Boxkita - any personal experience with a hard skit plate? I am leaning towards primitive. double-din - working on 3d printing a double din. I know none of the details. http://legacygt.com/forums/showpost.php?p=5076546&postcount=334 My OBXT build Link to comment Share on other sites More sharing options...
boxkita Posted February 27, 2015 Share Posted February 27, 2015 225 is boring 245/45/18 is where it's at. This should fit with a spec.b suspension and rolling the rear fenders. Danteleon in the Outback pictures forum has them mounted up. Boxkita - any personal experience with a hard skit plate? I am leaning towards primitive. double-din - working on 3d printing a double din. I know none of the details. 245 doesn't really fit. However nice try. 225 is more than enough. I never put one on, as it was easier to zip tie the OEM undercover back together. Sgt.Gator and others have used them with great success. The primitive one has good reviews. Check the GB forum as it may be still active. If I was going to be in situations where extreme off-roading was required, I'd add one. For area OP lives in, I'd add one for safety. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 27, 2015 Share Posted February 27, 2015 I'm running 235/40/18 tires and I really like how they preform. I want to get them on track to see where there limits are. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
rapture Posted February 27, 2015 Share Posted February 27, 2015 Love my gt spec skid plate Link to comment Share on other sites More sharing options...
boxkita Posted February 27, 2015 Share Posted February 27, 2015 I'm running 235/40/18 tires and I really like how they preform. I want to get them on track to see where there limits are. What tires? cause size doesn't matter if tires are crap. Michelin SuperSports/Dirrezza Z?/BFG Rival are all in the same category. Although the BFG Rival is more in the Michelin Sport Cup category. After that, you're in the 40 treadwear realm. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 27, 2015 Share Posted February 27, 2015 What tires? cause size doesn't matter if tires are crap. Michelin SuperSports/Dirrezza Z?/BFG Rival are all in the same category. Although the BFG Rival is more in the Michelin Sport Cup category. After that, you're in the 40 treadwear realm. Goodyear eagle F1. The stock tires from my dads focus ST 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted February 27, 2015 Share Posted February 27, 2015 Goodyear eagle F1. The stock tires from my dads focus ST All season? A decent clover leaf (no holes, cracks or frost heaves) will tell you how good there are. If you can make a steady howl, that's pretty close to the limit. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 27, 2015 Share Posted February 27, 2015 All season? Summers. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Benjamin M Posted February 27, 2015 Share Posted February 27, 2015 ...which will be far outside your normal cruising rpm (unless 5k is normal). But 4k+ sounds so intoxicating with the killer b hh, and nameless catback. 245 doesn't really fit. However nice try. 225 is more than enough. I never put one on, as it was easier to zip tie the OEM undercover back together. Sgt.Gator and others have used them with great success. The primitive one has good reviews. Check the GB forum as it may be still active. If I was going to be in situations where extreme off-roading was required, I'd add one. For area OP lives in, I'd add one for safety. http://tapatalk.imageshack.com/v2/15/02/27/57714e7fc2c95ebfccff92f357b223ea.jpg http://tapatalk.imageshack.com/v2/15/02/27/c240d457441ac62c2da1cbd994ccf3f4.jpg 245/45/18 potenza s04 pole position Is be interested in an undertray, but not sure how nice it'd play with the kb oil pan/hh Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
rapture Posted February 27, 2015 Share Posted February 27, 2015 She is a beaut!!! I run the yokoham advAn ado3 225 40 18in summer on a xxr 18-8.5 And my stock wheels wrapped in conti extreme winter 225-40-17 for fall/winter Love them both! Link to comment Share on other sites More sharing options...
Rhitter Posted February 27, 2015 Share Posted February 27, 2015 She is a beaut!!! I run the yokoham advAn ado3 225 40 18in summer on a xxr 18-8.5 And my stock wheels wrapped in conti extreme winter 225-40-17 for fall/winter Love them both! Just going off your avatar you have an LGT - the stock outback sized tire is 225/55/17. 245/45/18 has the same diameter as Outback stock. Although, if you want to step down to LGT sized tires you can replace the ABS modules (probably more involved than just that, read Leviman's thread) to get the Speedo to read correctly. My OBXT build Link to comment Share on other sites More sharing options...
boxkita Posted February 27, 2015 Share Posted February 27, 2015 I took the mufflers off in prep for getting nameless deletes. My gas mileage sucked because I liked the noise at 5k. KB HH are not in my future...I wish. 245? Because outback? On 17's with my current ride height the tires are even with the fender openings. In compression, I get rubbing. So 225 is my limit. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 27, 2015 Moderators Share Posted February 27, 2015 I have 235/45r18s that I run (MPSSs). I know a couple OBXT owners who run 245/45r18s, in the +45/+48 range. They work with a fender roll and reasonable ride height. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted February 27, 2015 Share Posted February 27, 2015 >10k builds and reasonable should never occur in same thread Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
rapture Posted February 27, 2015 Share Posted February 27, 2015 Yeah think i got mine wrong lol I meant 225 for the winters 245 for the summers lol Link to comment Share on other sites More sharing options...
Benjamin M Posted February 27, 2015 Share Posted February 27, 2015 I took the mufflers off in prep for getting nameless deletes. My gas mileage sucked because I liked the noise at 5k. KB HH are not in my future...I wish. 245? Because outback? On 17's with my current ride height the tires are even with the fender openings. In compression, I get rubbing. So 225 is my limit. Because outback. I only get rubbing a full lock such as driving in parking lots Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
OBXTrunner Posted February 27, 2015 Author Share Posted February 27, 2015 Im running 245/45/18 on my car with 1" adapters and dont get any rubbing but im also still stock hieght Link to comment Share on other sites More sharing options...
