Plug n Play Aux-in mod for 2005 6cd radios
jazzymt
Yes I'm using the cables that came with the Pro kit. The power to the docking cable is spliced from the cigarette lighter on the ash tray side. I grounded the docking cable to the chassis on the trim piece screw. The thing is even without the GLI I only get power to the iPod if I connect the docking cable to the patch cable. So somehow the RCA cables are used to complete the circuit. Should I have connected the ground to something else?
  • Replies 2.4k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Well there's your problem right there! :)
The cable is using the audio ground as a power ground - that's bad - if without the audio ground your iPod won't charge - that means the ground you used on the iPod cable is no good. You need a better ground - I would splice into the ground wire for the cigarette lighter - or use one of the bare metal sides of the radio if you don't want to splice anything. You need a good metal-to-metal contact.
[CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER]
Jazzy, get on it and stock it :D
Actually, I am *finally* happy to report that I'll be adding this product to my site fairly soon. There will be some price/kit "restructuring" soon as well (using this GLI will allow me to simplify/reduce the number of different cables/adapters I carry).
Unfortunately - PAC is WAY behind on products right now - my iPod cables are indefinitely backordered...I'm sure they will catch up soon though.
I decided to go with the cable in the top dash cubby. Seemed to be convenient to a vent-mount, keeps ipod at eye level. Just enough room, if careful, to stow the ipod with belkin cable connected in the cubby (easy if disconnect the cable). Powered from cigarette lighter.
Jazzy,
How long is the ipod kit on back order for ( I put in my order earlier this week)??? thats a major bummer! :icon_conf
tbosubi,
what mount are you using on your vents? I think I like that idea of putting it in the cubby. I definetly dont need to be looking down all the time when I am driving.
RipxLGT
tbosubi,
RipxLGT
It's a modified cell-phone thing from Radio Shack. The kind that includes a big unit to clamp the phone. But since my phone lives in a glove with a knob that slips into a belt clip, I ditched the big clamp and picked up a little sleeve with an adhesive back -- the kind you stick to your dash -- and stuck it on the platform to act as the receiver for the phone. (Note in the picture on the left, you see the platform -- with white lettering about how to insert & remove from the vent slats -- and the sort of keyhole-shaped receiver stuck onto the right side of it.)
When I put the iPod in, I discovered that the belt clip on the back of the glove my iPod lives in (a Marware model) fit the cell phone glove knob receiver thing perfectly.
It that's not clear as mud, there's at least one other similar set up I've spotted at GBXDirect:
http://www.gbxdirect.com/store/cellular_mount_solution.php?make=Subaru&model=Outback+Wagon&yearfrom=2005&yearto=2007
Happy to try to make that explanation clearer if need be. :-)
-K
Oh -- RipxLGT, there's one thing I shoud mention. Mounted on the vents, the iPod face really picks up light from open sun roof shade. During the day, mostly I leave it closed or almost closed, else cant see the iPod display for the reflection.
-K
Jazzy,
I'm not sure. Like I said they are backordered all the way to the manufacturer. You should have either seen that they were out of stock when you purchased the kit or received a backorder notification from me already.
...Checking my bank account, it looks like I have a big charge from my vendor on Friday, so they probably shipped to me on Friday (hopefully) and should be here sometime next week.
I have a 2.5i '06 Legacy and I'm having trouble installing my aux-in board. I have the single CD head unit.
I've almost got all the wires in the back of the air conditioning unit disconnected. There is one blue cable that is connected to the Temp. control that is confusing me. It's really hard to access and I don't see any way of disconnected it. There is a white roundish piece of plastic that is connected to the A/C unit that has said blue cable running through it. I know this blue cable is connected to the temp. control because when I turn the temp. knob, said cable moves in and out.
Because I can't disconnect this part, I can only take the entire head unit so far out. I'm able to pull the right side of the head unit out much further than the left(obviously, seeing as the cable is on the left).
Any single CD head unit owners experience similar difficulties?
The cable is disconnected up near the driver side vent above the radio. This is the install instructions for the Metra faceplate which points it out - hopefully that helps.
Did you make sure to put the all the screws back in the same location as they came out from? Sounds like either the loading mechanism gear is jammed from a long screw where it should have a short screw, or the ribbon cable is not fully seated & the CD player isn't getting power...
Hmm, there were only two long screws, and I put them in the two holes on the top of the face plate. I'll try it again with the faceplate on without the screws holding it up.
I've already tried reconnected the ribbon cables and made sure they were snug. Thanks again for your help.
I'm afriad I'm out of ideas then... have you tried reinstalling it without the aux-in board?
Heh, I actually just came back upstairs from doing that, and it works without the aux-in board installed. I'm going to go back in and make sure all the ribbons are facing the right way and are in the right places. I'm almost positive I had them right before, seeing as I tried reconnecting them multiple times.
Edit: No success. When I put it in with Aux-In board, cd will not load. Without Aux-In board, it loads.
Edit 2: Possible defect?
Possible, but unlikely - there's another possibility though. Count the number of pins on the bottom of the board that are soldered on each ribbon cable socket. There should be an empty hole at the end, and 14 soldered pins...
I just got done putting everything back together the way it used to be. I'll do that after school tomorrow. What would that mean if there are/aren't 14 soldered pins and one empty hole?
Again, thank you for being so helpful.
Edit: Jesus, sleep deprivation is a bitch. Not sure what I was thinking when I typed that. But uhh... Yeah, there are 14 soldered holes and one empty one on each the to CD Changer and the to Amp sockets
It would mean I sent you the aux-in board for the 02-04 Impreza. This is what it should look like (as you've already figured out).
http://i27.photobucket.com/albums/c161/JazzyMT/solder_pins.jpg
It sounds like you've got the right board. The only other thing I can think of is either one of the cables is backwards, or not plugged in all of the way... :icon_conf
In the instructions it says that the ribbon cables can be inserted either way into the circuit board. In the actual stereo the side of the cable with the wires exposed comes in contact with the side of the port with the wires, so I'm pretty sure they aren't in the wrong way there.
In the instructions it says that the ribbon cables can be inserted either way into the circuit board...
It still says that? :icon_eek: Wups - well, yea, that isn't true. The aux-in board has sockets that can go in either way, but the radio does not.
