Bubbaray Posted September 23, 2014 Share Posted September 23, 2014 PLEASE HELP My motor is gone in my 06 Legacy 2.5i and need to know what engines will fit or work with my car. Thanks in advance Link to comment Share on other sites More sharing options...
Akasa Posted September 23, 2014 Share Posted September 23, 2014 (Easier/Cheaper) The same SOHC 2.5i that Subaru put in the car. (Harder/More Expensive) Turbo powerplant (EJ255/257) If you're talking about swapping something like a cummins diesel or a 2jz, I can't help you there. Link to comment Share on other sites More sharing options...
MrTris Posted September 23, 2014 Share Posted September 23, 2014 Technically, any EJ-series engine will fit. But you'll need to get the same engine that your car had. Link to comment Share on other sites More sharing options...
Squad51 Posted September 23, 2014 Share Posted September 23, 2014 My vote is for a VQ35HR Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 Click on the Vendor tab on the blue bar up top. Then look for Heuberger or Fredbeans. Contact one of them from a short block. Do you have a local shop that can R&R the engine ? See my click here link in my sig for what I did. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted September 23, 2014 Share Posted September 23, 2014 Click on the Vendor tab on the blue bar up top. Then look for Heuberger or Fredbeans. Contact one of them from a short block. Do you have a local shop that can R&R the engine ? See my click here link in my sig for what I did. He's NA, and honestly, better off not buying a brand new SB. OP, yours can be rebuilt, since I'm assuming it just needs new bearings --right -- You spun a rod bearing due to lack of oil? Everything else should clean up just fine and last another 60-100k. Link to comment Share on other sites More sharing options...
chato Posted September 23, 2014 Share Posted September 23, 2014 buick turbo 6 is a popular option Link to comment Share on other sites More sharing options...
kzr750r1 Posted September 24, 2014 Share Posted September 24, 2014 buick turbo 6 is a popular option Beat me to it.... Link to comment Share on other sites More sharing options...
Bubbaray Posted September 25, 2014 Author Share Posted September 25, 2014 So can I replace the EJ25 engine with a EJ20? Link to comment Share on other sites More sharing options...
kzr750r1 Posted September 25, 2014 Share Posted September 25, 2014 Sure if you want to re engineer the car. Your best bet is to replace/rebuild the motor that your car was equipped with. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 26, 2014 Share Posted September 26, 2014 Post 113 has a bunch of sources for used engines with warranties. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p8.html Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 27, 2014 Share Posted September 27, 2014 With enough money just about anything will fit... 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
MrTris Posted September 27, 2014 Share Posted September 27, 2014 With enough money just about anything will fit... Why hasn't anyone done a lambo v10 swap? Those are readily available at JYs all over the nation. . . Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 27, 2014 Share Posted September 27, 2014 Why hasn't anyone done a lambo v10 swap? Those are readily available at JYs all over the nation. . . Lack of commitment 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
