Moderators BarManBean Posted July 8, 2014 Moderators Share Posted July 8, 2014 Pulled a LV the other day and my Fuel Trim A is pegged at +15. When idling, the wideband reads in the 14.5AFR range, so that seems fine. Boost builds fine, tested today in fourth and got up to 18psi seemingly with no issue before letting off. For possibilities I'm thinking: O2 sensor (it's new, but I guess I'm not completely ruling that out)MAF sensorVacuum leak Weird thing is that would think that any of those being an issue would cause fuel trims to be off across the board...hmmm... Anyone have any ideas? I guess I'll boost leak test the car first off, maybe clean the MAF, then see what happens. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
05sleeper Posted July 9, 2014 Share Posted July 9, 2014 I have the same issue but runs stupid rich in boost. I've cleaned maf and it is reading right but didn't fix it. New af so i know that's not it but haven't replaced my rear o2 yet. All my vacuum hoses look good and are connected. I need to pressure test/smoke test to make sure no leaks as well. Link to comment Share on other sites More sharing options...
Underdog Posted July 9, 2014 Share Posted July 9, 2014 A small vac leak will not necessarily throw off trims across the board. It becomes a smaller and smaller percentage of the overall as mass flow increases. Your WBO2 reading 14.5 just indicates that the ECU is adding enough fuel to reach stoich, or close to anyways. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 9, 2014 Author Moderators Share Posted July 9, 2014 Did a boost leak test last night, FPR hose popped right off I'm assuming that was the issue, time will tell I guess. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
05sleeper Posted July 9, 2014 Share Posted July 9, 2014 Ah that's scary! When i replaced all my vacuum hoses i zip tied or used tiny clamps on all the connection points to help prevent things from popping off. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 9, 2014 Author Moderators Share Posted July 9, 2014 A small vac leak will not necessarily throw off trims across the board. It becomes a smaller and smaller percentage of the overall as mass flow increases. Your WBO2 reading 14.5 just indicates that the ECU is adding enough fuel to reach stoich, or close to anyways. Yeah, that's why I wasn't too worried at first. When the trim is pegged (max or min) you just don't know how much farther it "wants" to go, but with the WBO2 reading things I new it was close. That said, given that it was the FPR hose it definitely needed to be fixed sooner rather than later. LV is much better so far after a 15 minute drive this morning, swinging negative now, actually. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
hobo2701 Posted July 9, 2014 Share Posted July 9, 2014 Better to run rich than lean anyday Link to comment Share on other sites More sharing options...
CPUNeck Posted January 26, 2015 Share Posted January 26, 2015 I'm not hi-jacking, but have the same problem. ~20% LTFT at idle. Initially rough with misfires and stall at times. Idles fine albeit low, and runs out good after what's been done below. All vacuum hoses R&R'd, with ~1/8" cut from ends for nice tight fit, zip ties added where boost lives.OE front and rear O2's (1yr old)OE plugs (1yr old)PCV Assembly (3 months old)OE OCV x2 (noticeable smoothing of ending)BG44k fuel treatment x2 over past yearR&R MAFUpgraded fuel pump DW(forgot model) drop in... replaced and seated properly.R&R'd engine grounds, cleaned and protected with liquid electric tapeSmoke tested to 14psi with zero leaks... (I'm luck, there's a great mechanic and a good guy close to me, Infamous Performance)OE short block from Subaru with my heads machined and rebuilt.Replaced turbo inlet with AVO (thinking the original had a tear... it didn't, was new replacement during engine rebuild.Spray tested with pilot start while monitoring trims... NGflooded the suspect connections with water (all of them) which revealed an area by the turbo was leaking. Separate post for the leack (it's in the TVG manifolds) http://legacygt.com/forums/showthread.php/tgv-manifold-small-end-cover-vacuum-leak-236480.htm No one has been able to identify the cause of the condition. It has improved greatly, but trims remain. Here I'm testing the FBR http://legacygt.com/forums/showthread.php/tgv-manifold-small-end-cover-vacuum-leak-236480.html After some brainstorming the consensus was too much air or not enough fuel (bad injectors, bad pump etc. Findings: At ~1450ft, at idel car has about 22in/mg, when that is applied to the FPR the pressure pump pressure remains 35%Whan adding 10-12psi shop air, pressure jumps to 55-56psi rock steady. Seams the FP was supposed to be ~39-43psi at idle. if it's close but no cigar, is the FBR bad? Link to comment Share on other sites More sharing options...
dga Posted January 26, 2015 Share Posted January 26, 2015 Honestly I've learned that, even though the little vacuum hoses look good, they can leak enough that they'll throw off your fuel trims. I had this same thing happen with one of the purge solenoid vacuum hoses, so I went ahead and zip-tied all of them and the fuel trims returned to normal. Link to comment Share on other sites More sharing options...
CPUNeck Posted January 27, 2015 Share Posted January 27, 2015 So after pulling hair and nashing or teeth, I discovered a very small hole in the 1/8" vacuum hose which houses the pill. I only found it because I was moving the hose around a lot while dowsing it with water (while running) So the leak was under the clamp, and looked like a tack had made the hole at an angle. Repairing this leak as reduced my TRIM's by almost 10%! The remainder for me is coming from the TGV shaft end cap. Both sides are leaking allowing a fairly substantial vacuum leak... but would alto allow pressure leakage. I'm working on how to correct it. -C Link to comment Share on other sites More sharing options...
