kylegordon Posted June 14, 2014 Share Posted June 14, 2014 is a wide body conversion possible? if so how can i go about getting this done? Link to comment Share on other sites More sharing options...
Eliott Posted June 14, 2014 Share Posted June 14, 2014 Fender flares is easiest way to go. Use the search, there's a few recent threads about them. Link to comment Share on other sites More sharing options...
Drift Motion Posted June 14, 2014 Share Posted June 14, 2014 Yes. Step 1 - get off your computer Step 2 - go to a body shop Step 3 - go crazy Step 4 - paint Step 5 - post pics Link to comment Share on other sites More sharing options...
JBear Posted June 15, 2014 Share Posted June 15, 2014 Step 1.5 - win lotto Link to comment Share on other sites More sharing options...
FX35B4 Posted June 15, 2014 Share Posted June 15, 2014 You will need lot of time and money... I believe this car is only one "true" wide body Legacy. http://minkara.carview.co.jp/userid/159507/blog/27815853/ Link to comment Share on other sites More sharing options...
Eliott Posted June 15, 2014 Share Posted June 15, 2014 You will need lot of time and money... I believe this car is only one "true" wide body Legacy. http://minkara.carview.co.jp/userid/159507/blog/27815853/ Hnnnggggg omg Link to comment Share on other sites More sharing options...
JBear Posted June 15, 2014 Share Posted June 15, 2014 First 4th gen one I've ever seen anyway. Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 15, 2014 Share Posted June 15, 2014 Wb to a wagon no less. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 15, 2014 Share Posted June 15, 2014 Damn, is that ever SEKSY...that RULZ! ! ! I would love to see a kit but the issue with something like that is that it would definitely take a professional body shop that specializes in custom work to really make something like that really fit. The front fenders, rocker panel skirts, front end bumper cover and parts, are not too difficult but morphing the rear widebody fenders on to the existing body panels and making them fit and look like that car, like they belong, is truly art. I would love to see that on a sedan because I would bet that it would be looking like a Trans-Am car and think of the 11" wide +25 offset wheels you could fit on that baby....things that make you go Hmmmmmm......... Link to comment Share on other sites More sharing options...
Code Posted June 15, 2014 Share Posted June 15, 2014 the 11" wide +25 offset wheels you could fit on that baby....things that make you go Hmmmmmm......... That Hmmmmmmmm would be your wheel bearings, sir. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
vagabond Posted June 15, 2014 Share Posted June 15, 2014 I have a widebody. Is called outback Link to comment Share on other sites More sharing options...
Drift Motion Posted June 15, 2014 Share Posted June 15, 2014 That Hmmmmmmmm would be your wheel bearings, sir. party pooper Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 15, 2014 Share Posted June 15, 2014 That Hmmmmmmmm would be your wheel bearings, sir. Perhaps Wabbit....perhaps.... Link to comment Share on other sites More sharing options...
lingling1337 Posted June 15, 2014 Share Posted June 15, 2014 You will need lot of time and money... I believe this car is only one "true" wide body Legacy. http://minkara.carview.co.jp/userid/159507/blog/27815853/ We need more info on this... hks factory car? Link to comment Share on other sites More sharing options...
quick4dr Posted June 15, 2014 Share Posted June 15, 2014 Instagram @ js25_Finesse_Fanatics is my wide body or @Argueta93 or @dylan_flynn is another. Link to comment Share on other sites More sharing options...
MrTris Posted June 15, 2014 Share Posted June 15, 2014 .. Or just get a 5th Gen? Also, that wagon looks like it's having an anaphylactic reaction. Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted June 16, 2014 Share Posted June 16, 2014 Been thinking of making some abs wide body flares at work(vacuum forming.) But a little nervous about cutting most the metal off to mount them. They would look like a rocketbunny for a frs, not just simple flares. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 16, 2014 Share Posted June 16, 2014 Been thinking of making some abs wide body flares at work(vacuum forming.) But a little nervous about cutting most the metal off to mount them. They would look like a rocketbunny for a frs, not just simple flares. Could you just buy some used fenders or maybe junkyard pull offs to use as guinea pigs rather than using your own car? Maybe make some that you could fit over the top on take off fenders and then play with them to make them fit exactly the way you want. That way, you're not out anything except the cost of the fenders and I wouldn't even cut anything until you had them fitting the body lines correctly as you would want. Now, the rears................... Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted June 16, 2014 Share Posted June 16, 2014 fronts are not what i was worried about, but the rear is a whole different ball game. And spending alot of money getting spare parts is going to be alot of money, considering the molds we make would be about 20-30lbs of epoxy x 4 molds. The epoxy is not cheap. Link to comment Share on other sites More sharing options...
boxkita Posted June 16, 2014 Share Posted June 16, 2014 if you are going to do it, at least put carbon fiber flares on it. Another option would be "tub" the rears and go inboard a bit. Getting rear camber is hard without running into the inside fenderwell. For the sedan option, google "subaru legacy gt300". If that doesn't make you drool, call 911 immediately, you maybe dead. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
thisisthenewsic Posted June 16, 2014 Share Posted June 16, 2014 could do something along these lines? http://www.raceplace.ru/upload/medialibrary/7e9/7e907a7b09df6db360d7ff0a070b0b4f.jpg http://www.raceplace.ru/projects/avtomobil_subaru_legacy/ Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 17, 2014 Share Posted June 17, 2014 could do something along these lines? http://www.raceplace.ru/upload/medialibrary/7e9/7e907a7b09df6db360d7ff0a070b0b4f.jpg http://www.raceplace.ru/projects/avtomobil_subaru_legacy/ Could DEFINITELY groove on owning this. Hell, I would take that even if it was a N/A...LOL Link to comment Share on other sites More sharing options...
kzr750r1 Posted June 17, 2014 Share Posted June 17, 2014 It's the ol can of worms. One thing leads to another. Link to comment Share on other sites More sharing options...
sashadg1 Posted September 29, 2014 Share Posted September 29, 2014 What about installing outback fender flares, anyone do this. Might look good if done right w wheels and slammed Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 29, 2014 Share Posted September 29, 2014 Outback fender flares are useless we have less room than the legacy's becuase they pulled in the fenders to mount them. we are just as wide as legacy's but we have an 1.25" lip that we can't roll. they would be useless on a legacy. Link to comment Share on other sites More sharing options...
