Danny0l3 Posted May 25, 2014 Share Posted May 25, 2014 I have a 2005 legacy gt with accessport, k & n short ram intake and borla full exhaust. I had my check engine light come on along with the cruise control light flash. I realized the filter on my intake had fallen off, and corrected the issue. When i plugged in my access port the code said it was running lean. I cleared the code, but the car seems to be running horrible. I get lots of lag in all gears and don't know what the issue can be at this point. If anyone can please help it would be greatly appreciated. Link to comment Share on other sites More sharing options...
Mike07LGT Posted May 25, 2014 Share Posted May 25, 2014 Just look at all the other threads about blown turbos and noises under the hood and such... get the car to a reputable mechanic if you are unable to diagnose the issue yourself... and be prepared for bad news as it sounds like it could be bad. Have you had the car tuned? If not maybe you should get in touch with a tuner and see if they can help you. Running an intake on an untuned car is a big no no with these cars... good luck! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Mike07LGT Posted May 25, 2014 Share Posted May 25, 2014 Also more information about the car like milage and when you purchased it and has the timing belt been done and any other technical info you can give is gonna help the experts around here give you good advice 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Danny0l3 Posted May 25, 2014 Author Share Posted May 25, 2014 Well the only tune I've done to the car is the access port itself. the car is a 2005 legacy gt with only 40,000 miles. No timing belt or anything done yet as the car does not have too many miles. Link to comment Share on other sites More sharing options...
idiot4hire Posted May 25, 2014 Share Posted May 25, 2014 Do accessports support intakes Link to comment Share on other sites More sharing options...
rob-2 Posted May 25, 2014 Share Posted May 25, 2014 Do accessports support intakes Not the one he has Link to comment Share on other sites More sharing options...
Tehnation Posted May 25, 2014 Share Posted May 25, 2014 Better pray your turbo didn't suck in anything, I would inspect the turbo asap. As well as look for vacuum leaks. Link to comment Share on other sites More sharing options...
Danny0l3 Posted May 27, 2014 Author Share Posted May 27, 2014 thanks guys for all the help, i cleaned out my MAF sensor and re-installed the map on my accessport. Seems to be running fine again, luckily no turbo issues. Link to comment Share on other sites More sharing options...
InTheBay Posted May 27, 2014 Share Posted May 27, 2014 I would seriously look for vacuum leaks. I would be willing to bet that you have a hose or connection that is sucking in air and ruining your AFR. Be careful, if you run lean you will melt pistons. Link to comment Share on other sites More sharing options...
Tehnation Posted May 27, 2014 Share Posted May 27, 2014 I'd also check that turbo for shaft play, ya never know! Link to comment Share on other sites More sharing options...
Danny0l3 Posted May 29, 2014 Author Share Posted May 29, 2014 do you guys think that when my intake filter fell off it could have caused the AFR sensor to get slightly dirty? I will also check for vacuum leaks and the turbo as mentioned though. Link to comment Share on other sites More sharing options...
12sechatch Posted May 29, 2014 Share Posted May 29, 2014 When your intake fell off, the car saw zero air coming into the engine (this is assuming it fell off after the MAF). To compensate, it probably adjusted fuel or timing causing the lean. Seems logical anyway... Link to comment Share on other sites More sharing options...
Shello007 Posted May 30, 2014 Share Posted May 30, 2014 Do accessports support intakes You took the words out of my mouth. I believe for the WRX's, the SPT intakes aren't supposed to cause any issues. That being said, running K&N with an OTS tune is no bueno. Link to comment Share on other sites More sharing options...
JBear Posted May 30, 2014 Share Posted May 30, 2014 Now that we've got that all cleared up... how do you like that Borla exhaust? Link to comment Share on other sites More sharing options...
WhiteMonster06 Posted May 31, 2014 Share Posted May 31, 2014 If you download the Cobb sf maps from their website directly and upload them to your AP , then you can run an intake more safe than just a base map tune. I did for mine before I was cryotuned and had zero issues. Also, do check those vac lines and secure them with zip ties anyway. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 1, 2014 Share Posted June 1, 2014 OP, what was the # of the code you got, or whats the CEL for running lean. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GT Gaze Posted June 3, 2014 Share Posted June 3, 2014 I also have my check engine light on and my cruise light flashing! idk what it means? the check engine light is my egr sensor cus my exhaust! but what does the cruise flashing mean? and my parking brake light is stuck on!! Link to comment Share on other sites More sharing options...
