nstg8r Posted August 18, 2014 Share Posted August 18, 2014 Okay, so a question to those with the add-on fog light kit... when you turn your fogs on, does the dash indicator light for the fogs illuminate? Link to comment Share on other sites More sharing options...
DJMajickMan Posted August 18, 2014 Share Posted August 18, 2014 Are you talking factory installed or dealer installed? <- Factory installed. When I press the dashboard fog light with headlights on any anything except parking and High beams the fog light dashboard light comes on as well as the fogs. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
nstg8r Posted August 18, 2014 Share Posted August 18, 2014 Are you talking factory installed or dealer installed? <- Factory installed. When I press the dashboard fog light with headlights on any anything except parking and High beams the fog light dashboard light comes on as well as the fogs. Sent from my iPhone using Tapatalk Turn signal stalk switch = Factory installed on Limited models Mirror control switch = Factory/Dealer accessory on other trim levels DIY kit = mirror control switch I'm asking for those with the mirror control fog light switch. Link to comment Share on other sites More sharing options...
amick1995 Posted August 18, 2014 Share Posted August 18, 2014 I installed mine myself and have the mirror control switch. The light does come on when they are on Link to comment Share on other sites More sharing options...
nstg8r Posted August 18, 2014 Share Posted August 18, 2014 I installed mine myself and have the mirror control switch. The light does come on when they are on Okay, so then that Green/Red wire at pin #3 must be connected to the BIU somewhere. Link to comment Share on other sites More sharing options...
nstg8r Posted August 19, 2014 Share Posted August 19, 2014 ... so I am not sure where the green wire would go... you could always touch it to ground and see if your fogs turn on... I tried this this morning, and yes, when I ground the Green/Red wire at Pin #3, the fog lights turn on as well as the dash indicator light. Link to comment Share on other sites More sharing options...
nstg8r Posted August 20, 2014 Share Posted August 20, 2014 Okay, so I think it's safe to assume that the fog light switch is a SPST that connects Pin #3 to Pin #7. If we could get a hold of these switches without having to buy the whole fog light kit, we could easily remove or cut the GR wire from Pin #3 on the harness and use the switch for some other purpose. Link to comment Share on other sites More sharing options...
nstg8r Posted August 21, 2014 Share Posted August 21, 2014 I found the part number for the Euro version that has the power folding side mirrors... 83061AJ000. Perscitus' switch didn't have a part number on it (the part number is a sticker with a QR code on the back of the switch). If anyone with a mirror control with the fog light switch wants to take a look to see if they have the part # stick, it would be appreciated. Link to comment Share on other sites More sharing options...
DJMajickMan Posted August 21, 2014 Share Posted August 21, 2014 I found the part number for the Euro version that has the power folding side mirrors... 83061AJ000. Perscitus' switch didn't have a part number on it (the part number is a sticker with a QR code on the back of the switch). If anyone with a mirror control with the fog light switch wants to take a look to see if they have the part # stick, it would be appreciated. How hard is it to pull that out? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
nstg8r Posted August 21, 2014 Share Posted August 21, 2014 How hard is it to pull that out? Sent from my iPhone using Tapatalk It's really easy if you know how to do it, but you wouldn't even have to. The part number sticker is on the back of the switch, so all you have to do is access the back of the panel the same as if you were installing a new flasher module. Here's where the sticker should be... Link to comment Share on other sites More sharing options...
BigBopper Posted August 21, 2014 Share Posted August 21, 2014 No sticker part # on back of my switch Can you elaborate on how you tested the GR to ground? key onposition lights onheadlights onfog light switch on If you replace wire in pin 7 with direct ground what would be the result? fog lights on anytime dash switch is onwould dash fog indicator lamp work as expected Haven't really thought these questions through (still on first cup of coffee). Link to comment Share on other sites More sharing options...
nstg8r Posted August 21, 2014 Share Posted August 21, 2014 No sticker part # on back of my switch Perscitus didn't have a sticker on his and says it never had one, so Subaru must be hiding something, lol. Can you elaborate on how you tested the GR to ground? key onposition lights onheadlights onfog light switch on I unplugged the connector, pushed one end of a wire into the connector at #3, the other end of the wire directly to the bare metal frame in the dash. Then, with no key in the ignition and the steering stalk fog light switch set to off, I turned the headlights on and the fogs came on. They would go on and off as I would remove and replace the wire from pin #3. The dash light would go on & off as well. If you replace wire in pin 7 with direct ground what would be the result? Pin #7 is a direct ground. If you removed it completely, none of the mirror functions would work. fog lights on anytime dash switch is onwould dash fog indicator lamp work as expected Haven't really thought these questions through (still on first cup of coffee). You still need to bypass the BIU for this to work. Since we don't know where the GR wire goes, that may make it more difficult but not impossible. You would do the same mod as described here, but you would need a longer wire. Then, instead of connecting one end to the White wire at the BIU, you would connect it to the GR wire at the mirror switch. Link to comment Share on other sites More sharing options...
marcin93 Posted January 28, 2016 Share Posted January 28, 2016 Can you explain to me how to get to the mirror switch wires? This seems to be the dead end for the independent fog light switch. You still need to bypass the BIU for this to work. Since we don't know where the GR wire goes, that may make it more difficult but not impossible. You would do the same mod as described here, but you would need a longer wire. Then, instead of connecting one end to the White wire at the BIU, you would connect it to the GR wire at the mirror switch. Link to comment Share on other sites More sharing options...
TheMicahLay Posted January 28, 2018 Share Posted January 28, 2018 Finally figured this out. Posted a write up here. http://legacygt.com/forums/showthread.php/fully-independent-fog-light-mod-267964.html Kind of a hybrid between the OP's mod and nstg8r's idea. Just had to find the right wires and wire the trigger lead to a steady 12v ign source rather than the parking lights to achieve full independence. Link to comment Share on other sites More sharing options...
Starks Posted January 29, 2018 Share Posted January 29, 2018 Uh, okay. Thanks for everyones hard work, I didn't realize it was a problem people were trying to figure out. Here's what I did. The kit I bought had an independent fog switch, fogs lights, inserts, and all the wiring. Check out my setup. This allows me to control fogs with an oem looking switch, independently of what my headlights do for about $60. Not free like this mod, but to get you started plus the benefit of independent you really can't beat this price. I'm almost positive these are the same style lamps that Subaru would use OEM. I'm mostly sure the included harness would plug into the OEM lamp connector. (They aren't chrome btw) ZMAUTOPARTS Subaru Legacy Bumper Driving Fog Lights Lamps Chrome https://www.amazon.com/dp/B01N3LEFXD/ref=cm_sw_r_cp_apa_M-ZBAbQSDXGW0 Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
