sneeky Posted January 27, 2014 Share Posted January 27, 2014 I've searched the forums. Does anyone know of a walk through to do a cleaning on my MAF sensors? Also, how about a walk through on seafoaming with a vacuum line. Not sure which line to use and do I need to change the oil and spark plugs afterwards? Or is just the oil suffice? Wanted to seafoam using a vacuum line, but if involves changing my spark plugs I'd rather not. Link to comment Share on other sites More sharing options...
Nrw Posted January 27, 2014 Share Posted January 27, 2014 Unplug MAF Remove the two tiny screws holding the MAF sensor Gently remove MAF sensor Spray with MAF cleaner Link to comment Share on other sites More sharing options...
sneeky Posted January 27, 2014 Author Share Posted January 27, 2014 Nrw thank you. I was hoping there was a walk-through with pictures since I'm schmuck when it comes to cars. Link to comment Share on other sites More sharing options...
stm25rs Posted January 27, 2014 Share Posted January 27, 2014 See attached pictures. Get MAF cleaner from your autozone/pepboys/whatever. CRC is the brand. The picture of the sensor shows where to spray. You want to clean the bulb (green arrow), but part of the sensor is actually inside - you'll see the wires in there. Follow the instructions on the MAF cleaner can, regarding spray distance/length of sprays. Let it dry before reinstalling; should dry very quickly, since you don't need to douse the sensor with cleaner for the cleaner to work. Oh yeah, and disconnect your battery first, to prevent electrical hazard, and to clear the ECU's learned parameters. The car will idle a little funny when you restart it, but that's just the ECU relearning. My car doesn't always like to start on the first turn of the key, after clearing the ECU, don't worry if that happens to you. Link to comment Share on other sites More sharing options...
nouse4aname Posted January 27, 2014 Share Posted January 27, 2014 I've never disconnected it when cleaning on this one or prior cars. Just undo the two screws, flip it over, spray cleaner inside, screw it back in. I would also take a q-tip with some cleaner on it to the bulb gently if it's really dirty like a first time cleaning of a used car. Link to comment Share on other sites More sharing options...
sneeky Posted January 27, 2014 Author Share Posted January 27, 2014 I love this forum! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 27, 2014 Share Posted January 27, 2014 I've never disconnected it when cleaning on this one or prior cars. Just undo the two screws, flip it over, spray cleaner inside, screw it back in. I would also take a q-tip with some cleaner on it to the bulb gently if it's really dirty like a first time cleaning of a used car. This is how I do mine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
covertrussian Posted January 27, 2014 Share Posted January 27, 2014 Here is how I cleaned mine, anything electrical I try to unplug, clean, let it dry, then reconnect it. Make sure you use MAF cleaner only! 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
sneeky Posted January 28, 2014 Author Share Posted January 28, 2014 Here is how I cleaned mine, anything electrical I try to unplug, clean, let it dry, then reconnect it. Make sure you use MAF cleaner only! Awesome! This is exactly what I needed. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 28, 2014 Share Posted January 28, 2014 FWIW, After the second cleaning when I started the car I got 2 CEL's. both dealing with the MAF. I reset the ECU, all has been fine. Now once a year when I clean it, I leave it plugged in. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sneeky Posted January 28, 2014 Author Share Posted January 28, 2014 FWIW, After the second cleaning when I started the car I got 2 CEL's. both dealing with the MAF. I reset the ECU, all has been fine. Now once a year when I clean it, I leave it plugged in. If it's as easy as just taking a q-tip to it, I'll most likely leave it plugged in also. Link to comment Share on other sites More sharing options...
stm25rs Posted January 29, 2014 Share Posted January 29, 2014 FWIW, After the second cleaning when I started the car I got 2 CEL's. both dealing with the MAF. I reset the ECU, all has been fine. Now once a year when I clean it, I leave it plugged in. Do you still reset the ECU when you clean it? Here's my thinking on the subject, from a controls engineering perspective, with limited knowledge of ECUs/engine operation....somebody correct me if I'm wrong: The basic principle of operation for the MAF is: there's a wire, heated at a constant current. Increased airflow cools the wire more, which decreases the resistance, which allows more current to flow. As the MAF gets dirty, the sensor's reading will drift, and the ECU is (or should be) slowly adjusting to the sensor drift, which would affect fuel trims, which is why you should reset the ECU when you clean the MAF. Link to comment Share on other sites More sharing options...
nouse4aname Posted January 29, 2014 Share Posted January 29, 2014 Or just let it slowly adjust itself back. Link to comment Share on other sites More sharing options...
zanzabar Posted January 29, 2014 Share Posted January 29, 2014 Do you still reset the ECU when you clean it? Here's my thinking on the subject, from a controls engineering perspective, with limited knowledge of ECUs/engine operation....somebody correct me if I'm wrong: The basic principle of operation for the MAF is: there's a wire, heated at a constant current. Increased airflow cools the wire more, which decreases the resistance, which allows more current to flow. As the MAF gets dirty, the sensor's reading will drift, and the ECU is (or should be) slowly adjusting to the sensor drift, which would affect fuel trims, which is why you should reset the ECU when you clean the MAF. a dirty maf makes it run lean, so you dont have to clear it as it would just run rich for a little bit. Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 30, 2014 Share Posted January 30, 2014 Do you still reset the ECU when you clean it? Here's my thinking on the subject, from a controls engineering perspective, with limited knowledge of ECUs/engine operation....somebody correct me if I'm wrong: The basic principle of operation for the MAF is: there's a wire, heated at a constant current. Increased airflow cools the wire more, which decreases the resistance, which allows more current to flow. As the MAF gets dirty, the sensor's reading will drift, and the ECU is (or should be) slowly adjusting to the sensor drift, which would affect fuel trims, which is why you should reset the ECU when you clean the MAF. Your evaluation was pretty much spot on. To take it further so you know WHY it runs lean. The dirt acts as an insulator on the MAF sensing bulb/wire not allowing the wire to cool properly, which in turn tells the engine not enough air is coming in, which causes the ECM to reduce the amount of gas through the injectors, which does, as zanzabar says, cause it to run lean. Lean, as we all know too well, is the kiss of death for boxer engines, ESPECIALLY for cylinder #4. If Subaru would just make 3 cylinders engines.......no more problems with #4.... Link to comment Share on other sites More sharing options...
Max Capacity Posted January 30, 2014 Share Posted January 30, 2014 Do you still reset the ECU when you clean it? No, only if I get a CEL. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
artard Posted December 20, 2015 Share Posted December 20, 2015 Here is how I cleaned mine, anything electrical I try to unplug, clean, let it dry, then reconnect it. Make sure you use MAF cleaner only! thanks, cleaned mine. all that gunk gone now. Link to comment Share on other sites More sharing options...
covertrussian Posted December 21, 2015 Share Posted December 21, 2015 Keep in mind the actual maf wire is inside (seen by looking at the bottom of the sensor). The one you cleaned is the IAT sensor. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
LatentWagen Posted December 22, 2015 Share Posted December 22, 2015 ^ This. Everyone referencing cleaning a "bulb" has cleaned the temp sensor, not the MAF sensor. The MAF is a hot wire (or wires) that also gets gunked up, but it's located inside the tube. Be extremely careful cleaning it, and use a flashlight to make sure it's free of debris. http://legacygt.com/forums/attachment.php?attachmentid=173439&stc=1&d=1390851760 Spray your MAF cleaner into the tube (red arrow above)... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
LatentWagen Posted December 22, 2015 Share Posted December 22, 2015 Went out and grabbed this pic, after hitting it with some CRC MAF cleaner. http://legacygt.com/forums/attachment.php?attachmentid=221734&stc=1&d=1450812212 Hope this helps to clear up how to clean these sensors. I didn't use a Q-tip to clean mine (this is on an 06 WRX w/ 81k), but if you are gentle enough - and there is still debris after liberal spraying - then go for it. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
