adj789 Posted March 6, 2014 Author Share Posted March 6, 2014 93 cable should be here tomorrow Link to comment Share on other sites More sharing options...
Apex-XT Posted March 8, 2014 Share Posted March 8, 2014 Anyone suggest intake manifold gaskets? 300k miles, BNR 16g, CryoTune, 'Bullet-Proofed' IC, Motor rebuild @ 250k b/c of a cracked exhaust valve. Original 5 EAT. Oil changed religiously @ 3,000 mi. Link to comment Share on other sites More sharing options...
adj789 Posted March 10, 2014 Author Share Posted March 10, 2014 I had to replace the flap on the intake manifold because it went bad so I think its ok. That cable doesn't work I'm going to try the Ebay one. Link to comment Share on other sites More sharing options...
stealitall Posted March 12, 2014 Share Posted March 12, 2014 The only way you can get the FL232RL chip set to work is with older driver. Can't remember what number it is. But if you do some very hard search its out there.. Link to comment Share on other sites More sharing options...
adj789 Posted March 18, 2014 Author Share Posted March 18, 2014 The only way you can get the FL232RL chip set to work is with older driver. Can't remember what number it is. But if you do some very hard search its out there.. Yeah the the drivers were a PITA to install but I got the computer to recognize the cable but RR wouldn't connect to the car. Something that I've started to notice recently is a gassy smell outside the car and I checked my tailpipes for excessive build up and I noticed a slight wisp of smoke while it was idling, I think I'm burning oil, I did check my oil levels and they're OK (it's been just over 1000 miles since my oil change) I really hope it's not my piston rings. Edit: I just had a thought, I had the screens in the banjo bolts removed, could this be happening because I'm over oiling my turbo? I have a buddy coming out in a couple weeks to do a compression test for me. Link to comment Share on other sites More sharing options...
covertrussian Posted March 19, 2014 Share Posted March 19, 2014 I've had my turbo banjo screens removed for 5k miles with no issues. The turbo banjo bolt (one that is on the turbo itself) has a built in restrictor. Also it's very hard to over oil a journal bearing turbo. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
adj789 Posted March 19, 2014 Author Share Posted March 19, 2014 So the only 2 things left are my temp sensor or my rings are fried I'm ordering another cable but I wont be able to do anything with it this week Link to comment Share on other sites More sharing options...
Apex-XT Posted March 20, 2014 Share Posted March 20, 2014 Removed 300k miles, BNR 16g, CryoTune, 'Bullet-Proofed' IC, Motor rebuild @ 250k b/c of a cracked exhaust valve. Original 5 EAT. Oil changed religiously @ 3,000 mi. Link to comment Share on other sites More sharing options...
lee07 Posted March 20, 2014 Share Posted March 20, 2014 Burned valves Link to comment Share on other sites More sharing options...
adj789 Posted March 25, 2014 Author Share Posted March 25, 2014 for some reason I'm getting 18.6 mpgs now, my last 2 tanks I've gotten over 250 miles Link to comment Share on other sites More sharing options...
covertrussian Posted March 26, 2014 Share Posted March 26, 2014 Same driving styles and gas station? What about ambient temps, did they change? If all else stayed the same, then they might have switched to summer gas. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
micha3lchu Posted March 26, 2014 Share Posted March 26, 2014 for some reason I'm getting 18.6 mpgs now, my last 2 tanks I've gotten over 250 miles Being quite heavy footed myself, I'm lucky to get around 17-20 driving around town in traffic. Sounds like things are getting better? Link to comment Share on other sites More sharing options...
covertrussian Posted March 26, 2014 Share Posted March 26, 2014 Stop flooring it everywhere. Love the typical non useful advise. Not all gas mileage issues are related to flooring the car. I get 16mpg driving like a grandma, and 14mpg driving it like I like driving. But because I drive 100% city with low MPH's gas mileage suffers. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
JJr Posted March 26, 2014 Share Posted March 26, 2014 +1, throw in a bunch of hills and it goes down. Link to comment Share on other sites More sharing options...
adj789 Posted March 27, 2014 Author Share Posted March 27, 2014 actually I've been pushing it a little more. I just got a second job this week so I have to sit in stop-n-go traffic in the mornings and highway miles in the afternoon Link to comment Share on other sites More sharing options...
covertrussian Posted March 28, 2014 Share Posted March 28, 2014 Highway driving will raise your averages indeed. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
adj789 Posted March 28, 2014 Author Share Posted March 28, 2014 this was a week before i started this new job it still shakes in the morning so I still want to get it tested Link to comment Share on other sites More sharing options...
FJuan Posted March 28, 2014 Share Posted March 28, 2014 After you clean the MAF, check the OHMs on the front O2 (A/F ratio) sensor to see if it's still within spec. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
adj789 Posted April 29, 2014 Author Share Posted April 29, 2014 Took it to my buddy's shop for a compression test and sure enough it's at 126 psi, way under, so he thinks it's either a valve or a piston ring Link to comment Share on other sites More sharing options...
USMC6217 Posted April 29, 2014 Share Posted April 29, 2014 What is the compression of the other cylinders Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 29, 2014 Moderators Share Posted April 29, 2014 Took it to my buddy's shop for a compression test and sure enough it's at 126 psi, way under, so he thinks it's either a valve or a piston ring 126 psi is not a bad reading as long as all four cylinders are right around that number. If the rest are at 145 that could indicate an issue. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
adj789 Posted April 29, 2014 Author Share Posted April 29, 2014 yeah unfortunately we don't have time to get to the rest but he said it should be at least 165 and 180 is ideal Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 29, 2014 Moderators Share Posted April 29, 2014 yeah unfortunately we don't have time to get to the rest but he said it should be at least 165 and 180 is ideal Don't think so... I don't think I've ever heard of an LGT having that compression, more like 145-150. Again though, consistency is more important that the actual number, so you need to test all four. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
USMC6217 Posted April 29, 2014 Share Posted April 29, 2014 If all the cylinders are within 5ish psi of that 126 you are fine. Cylinder 1 and 3 are the easiest to get to, if you are in a severe time crunch you can at least get those 2 Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
USMC6217 Posted April 29, 2014 Share Posted April 29, 2014 It is most definitely worth your time to test all the cylinders and find a new shop Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
