yukonm Posted June 21, 2008 Share Posted June 21, 2008 An additional degree of front camber (-1.9 degrees) on stock suspension! I used the 16mm Ingalls I-81280 camber adjustment bolts in the top position. The nice thing is that this bolt torques to 125 ft-lbs. Unfortunately, the Ingalls Catalog tells folks to use the wrong part (14mm I-81260 that only torques to 77 ft-lbs). So the 81280 is the one to get. Front: stock w/camber bolts. -1.9 camber, 0 toe. Rear: stock w/ 21mm cusco rear bar & AVO SB brackets. -0.5 camber. A little toe-in. Tires: bridgestone re01r (very good tire - comfortable w/ decent grip) Off-camber constant radius turns have just a little understeer. Banked turns w/ power is very neutral, possibly mild oversteer. If you steadily add steering angle going into a turn, you can get the rear loose. Link to comment Share on other sites More sharing options...
fweasel Posted June 21, 2008 Share Posted June 21, 2008 good info. I was able to get -1.5 up front on stock bolts, but my car is lowered which adds static camber. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 21, 2008 Share Posted June 21, 2008 Fweasel: How much is your car lowered, cause my car on stock bolts was only able to get about -0.9 IIRC. I have the same bolts as the OP for next alignment. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
rao Posted June 21, 2008 Share Posted June 21, 2008 good info. I was able to get -1.5 up front on stock bolts, but my car is lowered which adds static camber. Give me 5 minutes with your car and I will get you as much negative camber as you want To the OP - interesting find for the racers out there and for the tire companies Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fweasel Posted June 22, 2008 Share Posted June 22, 2008 Give me 5 minutes with your car and I will get you as much negative camber as you want To the OP - interesting find for the racers out there and for the tire companies :lol: Fweasel: How much is your car lowered, cause my car on stock bolts was only able to get about -0.9 IIRC.Ions, tokicos, specB top hats. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
rexster Posted June 22, 2008 Share Posted June 22, 2008 For those interested in the setup - Front: stock w/camber bolts. -1.9 camber, 0 toe. Rear: stock w/ 21mm cusco rear bar. -0.5 camber. A little toe-in. Tires: bridgestone re01r (what a great tire!) How it drives: constant radius turns have just a little understeer. If you steadily add steering angle going into a turn, you can get the rear loose. relatively little understeer under power. Might be a little too tail happy for high speeds, but great for tight turns. thanks for the info on the camber bolts, i'll give them a try. if you still have the stock shocks/springs you should get the rear sway bar brackets. Link to comment Share on other sites More sharing options...
Underdog Posted June 22, 2008 Share Posted June 22, 2008 My car was at -1.3 Camber up front, just after dropping it on Swifts. After my most recent alignment the tech had set the front to -0.8. There seemed to be a noticeable difference in how tight the front end felt (-1.3 feeling much "grippier"), even though I never took it to the limit. rexster: great avatar, I have that album hanging up in my den. The Crimson Dynamo Link to comment Share on other sites More sharing options...
VTGT Posted June 22, 2008 Share Posted June 22, 2008 I am shooting for around -1.5 camber lowered slightly with KW's on stock bolts. Link to comment Share on other sites More sharing options...
rao Posted June 23, 2008 Share Posted June 23, 2008 The outside edges of my tires keep wearing out perhaps due to a defective steering wheel controller. Maybe more neg camber will help. Btw, I also had an e36 M3. Loved it, but not as much as the Legacy Wagon. M3 wagon might be what I need. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rexster Posted June 23, 2008 Share Posted June 23, 2008 rexster: great avatar, I have that album hanging up in my den. yeah, too bad their other albums are no where near as good... Link to comment Share on other sites More sharing options...
spyguy Posted November 6, 2008 Share Posted November 6, 2008 those are money shots!!! what are your suspension mods fellow wagon brothern? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 8, 2008 Share Posted November 8, 2008 ST-43s, how do you like them? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Buru Posted November 11, 2008 Share Posted November 11, 2008 This could help your rear track adjustments. http://www.legacygt.com/forums/showthread.php?t=98132 Link to comment Share on other sites More sharing options...
rexster Posted November 12, 2008 Share Posted November 12, 2008 Any issues with these slipping on you yet? i need more negative camber up front, my outside edges are wearing at a much faster rate. Link to comment Share on other sites More sharing options...
yukonm Posted November 12, 2008 Author Share Posted November 12, 2008 Any issues with these slipping on you yet? i need more negative camber up front, my outside edges are wearing at a much faster rate. Not that I can tell, and the alignment shop was pretty confident of the setup. I'd tend to agree with them because the bottom bolt is stock (non eccentric) , and the top bolt has a more eccentric cam, but it still torques close to stock amount. I'd be worried about slipping with a 14mm bolt in the top position. Even more so with a second cam in the bottom position. Link to comment Share on other sites More sharing options...
rexster Posted November 14, 2008 Share Posted November 14, 2008 Not that I can tell, and the alignment shop was pretty confident of the setup. I'd tend to agree with them because the bottom bolt is stock (non eccentric) , and the top bolt has a more eccentric cam, but it still torques close to stock amount. I'd be worried about slipping with a 14mm bolt in the top position. Even more so with a second cam in the bottom position. Very cool thanks for the info. Link to comment Share on other sites More sharing options...
