whitetiger Posted October 2, 2006 Share Posted October 2, 2006 So i installed the perrin positive steering system bushings in my control arms and had an alignment done. Boy, do they make a huge difference. I had tien flex on my car already but now the steering response is lightning quick. It feels like a whole new beast. before due to the coilovers most of the body roll was elimiated, but now since the front end reacts so quickly, i can feel the body roll again. I guess its time to get sway bars. Im going to an auto-x this weekend so we'll see how it works there on the tight turns. the only bad thing is the increased harshness over bumps. it very noticeable, but i can live with it. I have a second set of control arms incase i get annoyed with it. Link to comment Share on other sites More sharing options...
Gmachine Posted October 3, 2006 Share Posted October 3, 2006 I'm registered for the same event, haven't turned a wheel in anger in forever. See you on course, Dave Link to comment Share on other sites More sharing options...
PGT Posted October 3, 2006 Share Posted October 3, 2006 I'd like to pick up front aluminum control arms and do a PU insert. I think that's the best compromise. Link to comment Share on other sites More sharing options...
Opie Posted October 3, 2006 Share Posted October 3, 2006 I'd like to pick up front aluminum control arms and do a PU insert. I think that's the best compromise. The Spec B (with aluminum control arms) actually has a stiffer bushing than the LGT....and probably not as noisey as the PU insert.... Spec B Bushing: 20204AG011 LGT Bushing: 20204AG01A Link to comment Share on other sites More sharing options...
PGT Posted October 3, 2006 Share Posted October 3, 2006 does the Spec B fit the LGT control arm? that might be a good, budget upgrade Link to comment Share on other sites More sharing options...
wukindada Posted October 3, 2006 Share Posted October 3, 2006 Hmmmmmmm...... I'd like to know that myself Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
PGT Posted October 3, 2006 Share Posted October 3, 2006 problems is that the install takes a bit of work, so someone with a spare LGT control arm <hint hint> would be the best guinea pig. Link to comment Share on other sites More sharing options...
wukindada Posted October 3, 2006 Share Posted October 3, 2006 just a call away;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
panamajack Posted October 3, 2006 Share Posted October 3, 2006 Dan you probably have some extra control arms around there somewhere. Looking forward to doing this once i find some Aluminium arms Link to comment Share on other sites More sharing options...
hifiandmtb Posted October 3, 2006 Share Posted October 3, 2006 As discussed here: http://legacygt.com/forums/showthread.php?t=18287&highlight=fulcrum Fulcrum offer a PSRS alternative that gives all the benefits with none of the downsides (i.e. NVH). A total no-brainer, IMO. Link to comment Share on other sites More sharing options...
PGT Posted October 3, 2006 Share Posted October 3, 2006 who's the US distributor? Link to comment Share on other sites More sharing options...
Underdog Posted October 3, 2006 Share Posted October 3, 2006 who's the US distributor? global performance parts... isn't this mentioned on page 5 or 6 of the above linked thread? The Crimson Dynamo Link to comment Share on other sites More sharing options...
PGT Posted October 3, 2006 Share Posted October 3, 2006 exactly my point underdog Link to comment Share on other sites More sharing options...
Underdog Posted October 3, 2006 Share Posted October 3, 2006 Yeah guys - the bushes are priced at AUD$140. Probably end up at US$140 anyway 'cause they have to be shipped to the U.S. & distributed out. They made an outstanding difference to the way my car steers. And there's no NVH tradeoff, unlike the Perrin ones. Yes, a press is necessary - I'd suggest you get it all done at a good suspension shop. They need to take an alignment reading pre-fitment anyway to know which bush kit to order. Take the time to read my write-up linked to the earlier post. From what I can tell, U.S. customers should discuss this with the U.S. distributor: Glenn Dirkse Global Performance Parts 4554 - 128th Street Michigan 49423 Ph: 616 399 9025 Fax: 616 399 9174 Web: www.globalperformanceparts.com E.Mail: glennd@globalperformanceparts.com I guess I don't understand your point then... since it was listed and you're still asking? The Crimson Dynamo Link to comment Share on other sites More sharing options...
Guest Posted October 4, 2006 Share Posted October 4, 2006 But globalperformanceparts.com does not seem to list that part online. Someone needs to call and ask. Link to comment Share on other sites More sharing options...
TRS Posted October 4, 2006 Share Posted October 4, 2006 But globalperformanceparts.com does not seem to list that part online. Someone needs to call and ask. Just search by part number SPF2801K. Link to comment Share on other sites More sharing options...
hifiandmtb Posted October 5, 2006 Share Posted October 5, 2006 Gees Louise - read the other post! About an hour ago, I talked with Zach at Global Performance Parts, who told me that they can get the kit for $126 within 3 weeks. Now I need to decide which one I want. I think 2803 corresponds to the Perrin PSRS that I currently have. Link to comment Share on other sites More sharing options...
hifiandmtb Posted October 5, 2006 Share Posted October 5, 2006 The official Fulcrum Superpro thread is now here: http://legacygt.com/forums/showthrea...973#post794973 Link to comment Share on other sites More sharing options...
