dan.jarvis Posted May 5, 2013 Share Posted May 5, 2013 As part of a repair and upgrade job on my 05 LGT, I replaced the Oil Cooler. Figured I would share with you all the glorious image of the water by-pass pipe coming out of the oil cooler. I need to replace this. Also, for good measure a picture of the old oil cooler and the new oil cooler and half my dad's license plate number. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 5, 2013 Share Posted May 5, 2013 Here's my old pipe at 154,000 miles. http://i185.photobucket.com/albums/x40/92Si/DSCN4727.jpg And the new one installed. http://i185.photobucket.com/albums/x40/92Si/DSCN4767.jpg I painted it with high temp paint. We'll see if that helped in about 6 years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dan.jarvis Posted May 5, 2013 Author Share Posted May 5, 2013 Nice. Just found the other thread on here about this pipe, which gave me the PN. I'll be dropping by the dealer to grab one and the two elbows. Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 5, 2013 Share Posted May 5, 2013 Almost 8 years and 92k miles Sent from my SCH-I535 using Tapatalk 2 Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Windy Road Posted May 6, 2013 Share Posted May 6, 2013 Mine has a little rust on it for 4 years and 61k miles 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
Joe Quimby Posted May 11, 2013 Share Posted May 11, 2013 Took a look at mine after I read this thread, and was relieved to find mine appears to be brand new (looks like dealership replaced it before they sold the car to me approximately 6 months ago)! Interesting that this part isn't galvanized given where it is... Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 12, 2013 Share Posted May 12, 2013 This part SHOULD be thermoplastic and then it would NEVER have a rust issue. Stupid design. Link to comment Share on other sites More sharing options...
baconbits Posted May 12, 2013 Share Posted May 12, 2013 This part SHOULD be thermoplastic and then it would NEVER have a rust issue. Stupid design. Assuming the heatshields are as good as we hope they are, agreed. Link to comment Share on other sites More sharing options...
MAP Posted May 12, 2013 Share Posted May 12, 2013 Damn... I'm glad I don't live in the northeast... that's a lot of rust on the pipe and sheet metal... ouch... there are some pluses to living in southern california Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 13, 2013 Share Posted May 13, 2013 :rolleyes:Not enough to way out the negatives IMO.. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
zactek Posted May 13, 2013 Share Posted May 13, 2013 Here's my old pipe at 154,000 miles. http://i185.photobucket.com/albums/x40/92Si/DSCN4727.jpg And the new one installed. http://i185.photobucket.com/albums/x40/92Si/DSCN4767.jpg I painted it with high temp paint. We'll see if that helped in about 6 years. POR-15 works wonders on parts like that, provided you brush it on onto new clean metal. After many years underneath my last car in the Northeast, I have yet to see a sign of rust or chipping on stuff I painted with it. High-heat enamel? I give it a year max. POR-15 is amazing stuff. Zack K. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2013 Share Posted May 13, 2013 Damn... I'm glad I don't live in the northeast... that's a lot of rust on the pipe and sheet metal... ouch... there are some pluses to living in southern california :rolleyes:Not enough to way out the negatives IMO.. X2 to that one. But I guess if I grew up there, it might be different. I did spend 4 four years in the high desert in the late 70's. But I think its changed a lot since then. POR-15, I'll have to check that out. Thanks, Hey, I wonder how that stuff would work on my 86' Ford F150...LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
KRM Posted May 14, 2013 Share Posted May 14, 2013 I also use por15 on my rusty 91 loyale. Hands down it can't be beat by any other rust and under coating I've used. I'm also painting my water pipe with the stuff while the engine is out. Link to comment Share on other sites More sharing options...
zactek Posted May 14, 2013 Share Posted May 14, 2013 I also use por15 on my rusty 91 loyale. Hands down it can't be beat by any other rust and under coating I've used. I'm also painting my water pipe with the stuff while the engine is out. Make sure you topcoat it with something you like (regular enamel). If you don't it turns flat/ashy if exposed to UV rays. Doesn't affect the way it works, just looks ugly. I don't paint anything anymore unless it has been underpainted with POR-15 first. Zack K. Link to comment Share on other sites More sharing options...
coco77 Posted August 22, 2014 Share Posted August 22, 2014 Can someone provide the part number for this I'm doing a timing belt soon & want to replace this pipe but cant find the P/N. Thanks Coco Link to comment Share on other sites More sharing options...
baconbits Posted August 22, 2014 Share Posted August 22, 2014 opposedforces.com Link to comment Share on other sites More sharing options...
FknBoss Posted August 22, 2014 Share Posted August 22, 2014 Dude all yours look better than mine did. Mine looked like a 10yr old petrified but hot dog was rusted so bad it was seeping. Link to comment Share on other sites More sharing options...
dan.jarvis Posted August 28, 2014 Author Share Posted August 28, 2014 can someone provide the part number for this i'm doing a timing belt soon & want to replace this pipe but cant find the p/n. Thanks coco p/n: 14067aa041 Link to comment Share on other sites More sharing options...
quick4dr Posted August 28, 2014 Share Posted August 28, 2014 Mine looked way worse at 100k when I swapped mine during oil cooler gasket change. Such an easy preventative Maintenace fix. Link to comment Share on other sites More sharing options...
Rhitter Posted August 28, 2014 Share Posted August 28, 2014 I just ordered this pipe and 3 elbows / connectors to replace all this when I replace my radiator. It's possible I ordered something wrong. Off of opposed forces this is what I grabbed Number (from opposed forces diagram), description, part number, and quantity. 5 hose 807611031 3 4 Clamp oil hose 21351aa000 2 6 hose clamps 805918010 4 8 pipe-oil cooler 21328AA011 1 My OBXT build Link to comment Share on other sites More sharing options...
ivonr Posted December 28, 2015 Share Posted December 28, 2015 reviving this old thread for any help on how to get to this water bypass pipe for inspection Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted December 28, 2015 I Donated Too Share Posted December 28, 2015 Lift the hood of the car and look down. It's at the front center of the engine and visible above the exhaust. Link to comment Share on other sites More sharing options...
snm95ls Posted December 28, 2015 Share Posted December 28, 2015 This reminds me, I need to inspect mine. Link to comment Share on other sites More sharing options...
TonyF Posted December 28, 2015 Share Posted December 28, 2015 I bought my car with 153000 miles, my pipe was ugly too, and my oil cooler was leaking. Changing out the pipe, elbows and oil cooler oring were all a piece of cake with the right deep socket. Link to comment Share on other sites More sharing options...
ivonr Posted December 29, 2015 Share Posted December 29, 2015 Lucky me I looked at mine and its just black with no rust. Then again my car was a Cali car w /60k mi Link to comment Share on other sites More sharing options...
