laggin_wagon Posted April 27, 2013 Share Posted April 27, 2013 Any idea what would make my 05 GT wagon continuously honk like a friggin' goose when accelerating at max boost? And then "whoosh" like it has a giant BOV when I shift? I've checked to the best of my ability, the inter cooler end tanks and as many hoses as I can access. I have a CEL code that reads something to the effect of "Wastegate Solenoid Actuator...". Could the wastegate be stuck open or closed? It's an Evo 18G/TDO5 from BNR super cars with a 1bar spring. Otherwise stock... Thanks for any help! Link to comment Share on other sites More sharing options...
iNVAR Posted April 27, 2013 Share Posted April 27, 2013 Why do I have a sneaking suspicion you didn't have your car tuned nor did you reinforce your TMIC with the bulletproof mod.... The noise is most likely a leak. Keep looking. At your end tanks. Closer. Link to comment Share on other sites More sharing options...
laggin_wagon Posted April 27, 2013 Author Share Posted April 27, 2013 So you don't think the problem could be associated with the wastegate? Link to comment Share on other sites More sharing options...
iNVAR Posted April 27, 2013 Share Posted April 27, 2013 no. also please provide more information. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted April 27, 2013 Share Posted April 27, 2013 It could be associated with the stock tune, if you didn't get tuned... so--did you? I had a similar sound coming from my stock BPV, but it wasn't accompanied by a CEL. If you've had a tune for this turbo, check the lines going to the wastegate actuator. See if the orifice is installed, and make sure there aren't any leaks there. If you haven't had a tune for this turbo... stop driving until you have. Tits mcgee Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 27, 2013 Share Posted April 27, 2013 Sounds like turbos going or a serious leak. Check the TB hose and Turbo Inlet, if they come off/loose under accel it might sound like that.. But if you never got tuned after that 18g, watch out!!! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 27, 2013 Moderators Share Posted April 27, 2013 Tb hose to tmic connection. I have a video of my last car making the same noise. The inner collar has likely popped out, easy fix--and tighten it up real good this time. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 27, 2013 Moderators Share Posted April 27, 2013 Here's the video: http://i934.photobucket.com/albums/ad187/BarManBean/IMG_0292.mp4 "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
laggin_wagon Posted April 29, 2013 Author Share Posted April 29, 2013 Thanks man. That was the problem. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 29, 2013 Moderators Share Posted April 29, 2013 Makes a hell of a bad noise, doesn't it? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
stuck686 Posted April 29, 2013 Share Posted April 29, 2013 so is ur car tuned?? Link to comment Share on other sites More sharing options...
iNVAR Posted April 29, 2013 Share Posted April 29, 2013 So annoying when people ask important questions and posters just ignore them and don't answer them. Hope your car doesn't blow up OP but it's your own fault if it does. Link to comment Share on other sites More sharing options...
laggin_wagon Posted April 29, 2013 Author Share Posted April 29, 2013 So, I've had this new Torque Solutions TMIC sitting around for about 3 years now and thought there's no better time than the present to put it on. I removed the 30mm recirc. hose and the 2-10mm bolts that hold the recirc. valve on. When I went to pull the small hose off the other barb, the hose came away with most of the barb still inside it. It almost looks like it was damaged and somebody tried to super glue it back on. Oh and once I got the TB hose off I discovered that I'll likely have to purchase a new one. I looked around a little bit but there doesn't seem to be an "upgrade" in the way of non-OEM aftermarket item. Does anyone know of a decent replacement or should I just get the factory one from Subaru? And yes, the car has been tuned since the turbo upgrade, but thanks for the concern... Nevermind, found the AVO one. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted April 30, 2013 Share Posted April 30, 2013 I'm going to go ahead & say no tune. Tits mcgee Link to comment Share on other sites More sharing options...
iNVAR Posted April 30, 2013 Share Posted April 30, 2013 His latest reply says he has a tune.... Anyway, OP, do a search here about that TMIC and then decide if you want to install it. It's a knockoff, of a Perrin, which already has fitment issues for many people. Plus it might suck for cooling in general. https://www.google.com/search?q=torque+solutions+site%3Alegacygt.cmo&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#client=firefox-a&hs=KpK&rls=org.mozilla:en-US%3Aofficial&sclient=psy-ab&q=torque+solutions+site:legacygt.com&oq=torque+solutions+site:legacygt.com&gs_l=serp.3...1404.1700.0.1792.4.4.0.0.0.0.130.325.2j1.3.0...0.0...1c.1.11.psy-ab.kZOXDuyXxKQ&pbx=1&bav=on.2,or.r_cp.r_qf.&bvm=bv.45645796,d.dmQ&fp=3e0fe4c0fe974a3d&biw=1366&bih=666 Link to comment Share on other sites More sharing options...
laggin_wagon Posted April 30, 2013 Author Share Posted April 30, 2013 His latest reply says he has a tune.... Anyway, OP, do a search here about that TMIC and then decide if you want to install it. It's a knockoff, of a Perrin, which already has fitment issues for many people. Plus it might suck for cooling in general. https://www.google.com/search?q=torque+solutions+site%3Alegacygt.cmo&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#client=firefox-a&hs=KpK&rls=org.mozilla:en-US%3Aofficial&sclient=psy-ab&q=torque+solutions+site:legacygt.com&oq=torque+solutions+site:legacygt.com&gs_l=serp.3...1404.1700.0.1792.4.4.0.0.0.0.130.325.2j1.3.0...0.0...1c.1.11.psy-ab.kZOXDuyXxKQ&pbx=1&bav=on.2,or.r_cp.r_qf.&bvm=bv.45645796,d.dmQ&fp=3e0fe4c0fe974a3d&biw=1366&bih=666 Yeah, that's the main reason it sat behind the couch for 2.5 years... I put it on tonight and other than it being a bear to get shoe-horned into the throttle body hose, it wasn't too bad. Only other fitment issue is the recirc hose now rests directly on the intercooler. I'll have to keep and eye on that so it doesn't destroy that hose. That and get an updated tune going. Link to comment Share on other sites More sharing options...
