legacypimp Posted August 7, 2005 Share Posted August 7, 2005 is it possible to swap the engine of a legacy 2.2l 92 for a impreza wrx 2003 ?? and by the same time is it possible to swap the automatic tranny for a standard one ??? Link to comment Share on other sites More sharing options...
rao Posted August 7, 2005 Share Posted August 7, 2005 Yes to both. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
legacypimp Posted August 7, 2005 Author Share Posted August 7, 2005 is it an hard job ?? cause i m seriously thinking about doing that and do you ever saw a similar set up ?? what time it could do on a 1/4 mile ? Link to comment Share on other sites More sharing options...
rao Posted August 7, 2005 Share Posted August 7, 2005 http://www.nasioc.com go to the Subaru Conversions forum for everything you need to know. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Yukonart Posted August 8, 2005 Share Posted August 8, 2005 Also check out http://bbs.legacycentral.org as that site is ALL about BC/BF Legacies. Link to comment Share on other sites More sharing options...
NutBucket Posted August 8, 2005 Share Posted August 8, 2005 It'd be tough since the wiring would have to be redone. As far as swaps go, Subarus are harder. Link to comment Share on other sites More sharing options...
PGT Posted August 8, 2005 Share Posted August 8, 2005 moved to 'older legacy performance' Link to comment Share on other sites More sharing options...
tora Posted August 19, 2005 Share Posted August 19, 2005 It's not a bad swap at all, and depends what you want to do in terms of the swap. Auto to manual is pretty easy if you have all the right parts. (eg. 5spd uses a different started than the auto). As for the engine swap the swap itself is simple simon, the wiring is not bad, but very time consuming ASSUMING you want to use the WRX wiring harness and ECU (which make ssense for a street car as then you can use all the ECU programming that is available for the WRX (EcuTeK et al). If this is for motorsports or for any other reason you want a standalone system then it makes things a little more straight forward. As said, for the nitty gritty details check the conversion forum on NASIOC. Good luck with your swap! Link to comment Share on other sites More sharing options...
jlk97legacygt Posted August 24, 2005 Share Posted August 24, 2005 yes, i live in madison wi and a local performane shop just put a 96 imprezza wrx engine and trans into a 92 legacy. Link to comment Share on other sites More sharing options...
low_suby_wagon Posted September 7, 2005 Share Posted September 7, 2005 I did a 95 2.5RS swap on mine. It was hard, well, harder than those wussy honda swaps but can be done. let me get my pics uploaded I will show you some b4 and afters. Link to comment Share on other sites More sharing options...
Kaos22B Posted September 8, 2005 Share Posted September 8, 2005 yes to both again, it would be easier to do both at the same time also (aslong as the donor engine/ecu/harness is from a 5mt) Link to comment Share on other sites More sharing options...
