fahr_side Posted July 11, 2013 Share Posted July 11, 2013 Ask and ye shall receive. '13 STI (same car), stage 2, one with and one without the intake. Now show the logs with the timing and fuel curves. I see a lot of people not adjusting timing tables to compensate for different MAF scaling. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
BlazeRex Posted July 11, 2013 Share Posted July 11, 2013 Now show the logs with the timing and fuel curves. I see a lot of people not adjusting timing tables to compensate for different MAF scaling. Both were about 18.5 psi, about 14* at peak, with intake about 23.5-24* at redline, without intake about 24-24.5* at redline. Both 11.2:1 AFR. Link to comment Share on other sites More sharing options...
BlazeRex Posted July 11, 2013 Share Posted July 11, 2013 Same car? Similar dyno day conditions (temp/etc)? Same car, about 10-15* warmer with the intake. They were done approx 2 weeks apart. Link to comment Share on other sites More sharing options...
BlazeRex Posted July 11, 2013 Share Posted July 11, 2013 Ohh and to further my statement: http://efilogics.com/dyno/graph.php?gb=0&hp=1&torque=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=2085&rgb1=000000255&runid2=2144&rgb2=204000000 Link to comment Share on other sites More sharing options...
fahr_side Posted July 12, 2013 Share Posted July 12, 2013 That doesn't line up with my own experience on customer cars. Personal experience > anecdotal evidence every time. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 Why tell him to "prove it" if you're just going to write it off anyway? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
BlazeRex Posted July 12, 2013 Share Posted July 12, 2013 That doesn't line up with my own experience on customer cars. Personal experience > anecdotal evidence every time. You do realize I tune professionally and have customers as well? You realize I tuned that 2013 STI I showed the plots of? For 02-07 WRX/STI, I have yet to see a difference with an intake, but you need to keep up, things change. Like I always say - Practice doesn't make perfect. Perfect practice makes perfect. Link to comment Share on other sites More sharing options...
idiot4hire Posted July 12, 2013 Share Posted July 12, 2013 A guy local to me picked up good power on his 18g with a ks tech intake I would say if your on stock turbo money could be better spent else where. But I am also not a professional anything that's just my opinion Link to comment Share on other sites More sharing options...
fahr_side Posted July 13, 2013 Share Posted July 13, 2013 Why tell him to "prove it" if you're just going to write it off anyway? I don't think his plots prove anything and it doesn't gel with my own research. I'm certainly not interested in an off-topic pissing match over this. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
chimera Posted July 15, 2013 Share Posted July 15, 2013 fahr_side does have a point, and I'd like to see better evidence on that dyno. Best way to prove it, is another dyno run on the same car with the same "post-intake tune", but remove the KST65mm intake and replace with the stock intake. That would prove whether the intake+tune has made the improvement, or whether it just happened to be a finer "tweaked" tune over the previous one. If HP is the same increase with stock and post-intake tune, then your argument is irrelevant. Link to comment Share on other sites More sharing options...
