PINESMOKER Posted February 6, 2013 Share Posted February 6, 2013 As some of you know I recently finished doing the head gaskets on my 98 LGT Wagon 2.5 DOHC. At first I was worried that something was amiss. A lot of white vapor and water coming out of the exhaust tip at a idle. Once warm just a little vapor, but still dripping. Its been a week and a 150 miles later still leaves a puddle out the tail pipe when it's warming up. I'm not losing coolant nor oil, just a lot of water puddling under the muffler. Do Subaru just make water or what?? Car runs good doesn't over heat, No milkshake in the oil. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted February 6, 2013 Share Posted February 6, 2013 http://www.daveware.co.uk/hannah/blog/files/aliens-meme.jpg Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 6, 2013 Share Posted February 6, 2013 2C8H18 + 25O2 ~> 16CO2 + 18H20 Link to comment Share on other sites More sharing options...
Tr00b Posted February 6, 2013 Share Posted February 6, 2013 I have to milk mine in the morning or it gets fussy and won't eat its hay. While you are making this observation, what is the ambient temperature outside? Is it in the morning? Dew point, temp etc are factors. Link to comment Share on other sites More sharing options...
PINESMOKER Posted February 6, 2013 Author Share Posted February 6, 2013 Monkey That is the reaction from the combustion of Octane. I late to class that day. Can you explain it to me again. Link to comment Share on other sites More sharing options...
PINESMOKER Posted February 6, 2013 Author Share Posted February 6, 2013 Troob, it about 50 degree or so and i live on the coast. I have taken that into account. I can run my 96 accord right next to it and no vapor on the honda side. Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 6, 2013 Share Posted February 6, 2013 Honestly, both of my Subies drip water out of the tailpipe. When it is cold out it seems more apparent. Oh, and for an explanation: bonds breaking, blah blah, more favorable energy states, energy is released, blah blah. Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 6, 2013 Share Posted February 6, 2013 Well that's cuz Honda's need water to run VTEC (very tall engine coolant) On some serious talk, mine does the same, and was more prominent when I did my mid back exhaust Link to comment Share on other sites More sharing options...
twisty Posted February 6, 2013 Share Posted February 6, 2013 mine doesnt leave a puddle at all. neither does my dodge nor my civic, but the f150 leaves a trail for miles. depending on the weather i will get drips here and there tho, pretty sure its related to the dew point and weather stuffs tho. Link to comment Share on other sites More sharing options...
mnstrmech Posted February 6, 2013 Share Posted February 6, 2013 water out the tailpipe is a good thing people!!!!!! thats the byproduct of the cat. water coming from the tailpipe means your catalytic converter is working. Link to comment Share on other sites More sharing options...
spooln30 Posted February 6, 2013 Share Posted February 6, 2013 When you did your HG's did you pull the heads with the engine still in the car? Also did you leave the exhaust header in too? What probably happened is when you pulled the heads the coolant in the block poured into the exhaust and now that the cars running your just burning it off and out the tail pipe. Seen and done this before. It may take a while for it all to burn away but if those are the cases then you'll be find, just give it a little time to work its way out. Link to comment Share on other sites More sharing options...
pleaidestar Posted February 6, 2013 Share Posted February 6, 2013 I had a little bit of condensation coming out of my header when I forgotten to put my exhaust manifold gasket on one side I thought it was weird to see that but my car is running great after the swap...500 miles on the swap and still feels good..normal stuff I think. Link to comment Share on other sites More sharing options...
Sludgeroo Posted February 6, 2013 Share Posted February 6, 2013 And I found out I have an exhaust leak at my cat! Water coming from there too. I wouldn't be worried about it pinesmoker Link to comment Share on other sites More sharing options...
