xt2005bonbon Posted October 25, 2013 Author Share Posted October 25, 2013 Then your car is DBW. Pull fuel pump fuse, put foot all the way to the floor. (Gas pedal..) this is 'clear flood' mode and the car will not inject fuel in an attempt to burn out whatevers in there VERY interesting... Never heard that our ECU was programmed to do that. Very good to know. thank you. Link to comment Share on other sites More sharing options...
Strizzy Posted October 25, 2013 Share Posted October 25, 2013 EVERY drive-by-wire car has that same "feature." Hold the throttle pedal to the floor and crank turn the key. My bad luck build Link to comment Share on other sites More sharing options...
1055 Posted October 26, 2013 Share Posted October 26, 2013 EVERY drive-by-wire car has that same "feature." Hold the throttle pedal to the floor and crank turn the key. Even most modern cable cars have this 'feature'. Most OBD II fuel injected cars actually Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 30, 2013 Author Share Posted October 30, 2013 As a quick update, I did use the method described by 1055 and it worked like a charm!! I was really happy. Now I am curious: what would happen if I leave the fuel pump fuse in place AND start the car while holding the throttle pedal to the floor? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 6, 2013 Author Share Posted November 6, 2013 Now I am curious: what would happen if I leave the fuel pump fuse in place AND start the car while holding the throttle pedal to the floor? Bump Link to comment Share on other sites More sharing options...
Strizzy Posted November 6, 2013 Share Posted November 6, 2013 Bump The car will just keep cranking, as if the fuel pump fuse has been pulled. My bad luck build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 6, 2013 Author Share Posted November 6, 2013 The car will just keep cranking, as if the fuel pump fuse has been pulled. Then, there's no need to pull the fuel pump fuse in the future if my goal is to crank the engine for 3-5 secs, so it gets lubricated after sitting for a long period of time. This is perfect! Link to comment Share on other sites More sharing options...
Strizzy Posted November 6, 2013 Share Posted November 6, 2013 Then, there's no need to pull the fuel pump fuse in the future if my goal is to crank the engine for 3-5 secs, so it gets lubricated after sitting for a long period of time. This is perfect! That is correct. My bad luck build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 6, 2013 Author Share Posted November 6, 2013 Thanks for confirming Strizzy. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 6, 2013 Share Posted November 6, 2013 So the process is, put your foot to the floor and turn the engine over for a short time. Then just lift your foot and keep cranking ? or turn the key back to off, then lift foot and start as normal ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 6, 2013 Author Share Posted November 6, 2013 So the process is, put your foot to the floor and turn the engine over for a short time. Then just lift your foot and keep cranking ? or turn the key back to off, then lift foot and start as normal ? ^Bold is what I did. I wonder if the first option you have above could work too. I guess that's the next question to ask now, Strizzy? Link to comment Share on other sites More sharing options...
Strizzy Posted November 6, 2013 Share Posted November 6, 2013 Hold the throttle to the floor the entire time you are cranking. Once you let off the throttle, the engine will start like normal. My bad luck build Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 6, 2013 Author Share Posted November 6, 2013 Hold the throttle to the floor the entire time you are cranking. Once you let off the throttle, the engine will start like normal. That is even way better. Thanks for the follow-up. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 7, 2013 Share Posted November 7, 2013 Awesome. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
