Will 17" rims fit an 08 Spec-B?
robertsm99
I know standard rims on my '08 Spec-b are 18" but have ahd a lot of issues with the factory rims and blowing tires on potholes. Never had an issue in my '05 Legacy GT which had 17" rims and tires. Does anyone know if 17's will fit with the calipers and everything else?
Thanks.
Yes, a 17" OEM wheel will fit without any issues. 215/45/17 tire size is factory spec
that's only for the GT
the specB has a taller sidewall, so use a tire size calculator to find the right size for yourself
GT and SpecB shares the same brakes, therefore if it fits the GT, it'll fit the SpecB
So I started looking around and was informed that even if I go with a 17" rim and use a 215/45 17 tire that it wouldn't help my situation with potholes and that I'd need a 50 or 55 to actually make the difference. Do they make a 215/50 18 tire? Would it fit in the wheel well or would I have to go with a 215/50 17?
