Doogie29th Posted December 30, 2012 Share Posted December 30, 2012 [ame=http://www.youtube.com/watch?v=1OEw9j-C0QI]Doogie's 12.3 @ 113 1.68 60' Subaru Legacy GT - YouTube[/ame] MWSOC Subaru Shootout 2012 Vehicle Specifications: 2005 Legacy GT Limited Garnet Red Pearl 463 WHP E85 405 WHP Pump 93 Engine: EJ255 2.5 Liter, Flat 4 Cylinder NGK Iridium Plugs (1 Step Colder) Crawford V2 Air/Oil Separator Amsoil Synthetic 5W-30 Turbocharger & Induction: Blouch 20G XT (8cm Hotside) AVCS Kit with VF Series Banjo Vibrant 90 Degree Elbow STI Intake Manifold Grimmspeed Phenolic Spacer 3mm Grimmspeed TGV to Engine Gaskets Grimmspeed Intake Manifold to TGV Gaskets TGV Deletes RacerX FMIC with Custom Fabricated Piping Tial Q BOV 50mm 12 PSI Spring HOA 3 Port Boost Control Solenoid Samco Inlet Hose Short Ram Intake Fuel & Tuning: Walbro 255lph Fuel Pump Top Feed Injectors Conversion with Fuel Regulator Custom Fuel Rails with Steel Braided Lines Deatschwerks 1300cc Top Feed Injectors Cobb Access Port 2.0 Tuned by Junior Exhaust: Perrin Equal Length Headers Grimmspeed EWG Up Pipe Tial MVS 38mm VTA EWG (.9 Bar) Perrin Catted Downpipe Magna Flow Resonator Magna Flow 3" Y Pipe Magna Flow Mufflers Drivetrain: 2004 STI 6 Speed Transmission Exedy Stage 2 Clutch Kit Braided SS Clutch Line Kartboy 6 Speed Short Throw Shifter Kartboy Shifter Bushings STI Front Axles Spec B Rear Axles R180 Rear Differential Brakes: 2004 STI Brembo Calipers Front DBA 4000 Slotted Rotors Front Hawk HPS Pads Front 2004 STI Brembo Calipers Rear DBA 4000 Slotted Rotors Rear Hawk HPS Pads Rear SS Braided Brake Line Set ATE Super Blue Brake Fluid Suspension, Wheels, & Tires: Perrin 25mm Front Sway Bar Rallitek Front Endlinks BC Racing BR Series Coilovers 18x8 +50 Enkei Imola Hankook Ventus V12 EVO K110 225/40ZR18 Interior: 52mm Auto Meter Sport Comp II Boost Gauge 52mm Auto Meter Sport Comp II Oil Pressure Gauge Dual Stealth Cubby Gauge Pod LED Conversion Kit (Dome, License, Door) Recaro ProRide Blaze Carseat Exterior: R-Rev Front Lip Painted GRP R-Rev V2 Eyelids Painted GRP Blacked Out Grill DDM Hid Headlights 6000K Cleared and Blacked Out Headlights White/Amber Switchback LED Turn Signal Bulbs Rear Windows Tinted Debadged Emblems Link to comment Share on other sites More sharing options...
Kastley85891 Posted December 30, 2012 Share Posted December 30, 2012 12.3 is no joke, nice work Link to comment Share on other sites More sharing options...
wurkenman Posted December 30, 2012 Share Posted December 30, 2012 Very nice. Stop now before you drain your wallet. Power only makes you want more. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 2, 2013 Share Posted January 2, 2013 Thread Title: 1/4-1/8th: location of run, Vehicle, time/speed example: 1/4 mile, NHIS, 2005 LGT, 13.6 @107mph Event: track run Loaction: name of the Track Date: 08/11/2010 Ambient Temp: in F Elevation: Google can help you with this Weather: Rain? Snow? clear? Car: year, make and model Tuner: Name of person and shop Track info: Transmission: 5speed, 6speed, PPG, JDM, ect ect Peak Horse Power at RPM: The RPM that you reached max HP Peak Torque at RPM: The RPM you reached Max TQ Fuel: Octane rating if pump, octane and brand if specialty fuel Engine/Power Modifications: Anything that adds horsepower that you have added to your car. i.e. bigger turbo, intercooler, exhaust, injectors Driveline Modifications: Stock/Upgraded clutch, light weight flywheel, upgraded drive shaft, upgraded rear or center diff. Suspension Modifications: struts, springs, coilovers, braces, bushings, and other items that reduce body motion and increase power transfer to the ground Other Modifications: weight removal, addition of a roll cage, lighter wheels or rotors, smaller than OE diameter tires, and other items that affect vehicle weight, rotational inertia, and power delivered to the contact patch Picture of Dyno Plot and AFR/Boost Plot: Ask your tuner for this or copy it from your tuning software Link to comment Share on other sites More sharing options...
NSFW Posted January 3, 2013 Share Posted January 3, 2013 Nice run! Was that on pump gas or E85? Also, what settings are you using for launch control? Thanks! Link to comment Share on other sites More sharing options...
Legend Posted January 3, 2013 Share Posted January 3, 2013 Killer 60'! My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Doogie29th Posted January 3, 2013 Author Share Posted January 3, 2013 That run was on E85. Launched @ 5K and flatfoot @ 6300. Link to comment Share on other sites More sharing options...
kongzilla Posted January 3, 2013 Share Posted January 3, 2013 love the laugh. Its the laugh, I killed you biatch. Link to comment Share on other sites More sharing options...
SkateAndDestroy Posted January 4, 2013 Share Posted January 4, 2013 That run was on E85. Launched @ 5K and flatfoot @ 6300. Was something going on with the tune? 463whp =113 traps? Launch and shifting looked solid though! Link to comment Share on other sites More sharing options...
Doogie29th Posted January 4, 2013 Author Share Posted January 4, 2013 It was 90* that day. Do you think the trap should be higher? Comparing my power to other LGT's on dragtimes and other sites, my et and trap seems right to me. The 6mt adds some weight to the car. DANG, I knew I should have taken out the recaro baby seat! Link to comment Share on other sites More sharing options...
blongo804 Posted January 4, 2013 Share Posted January 4, 2013 Sweet run! Car sounds awesome with the EWG. Link to comment Share on other sites More sharing options...
bigjweb Posted January 4, 2013 Share Posted January 4, 2013 Interesting. You go through a whole lot of trouble doing a nice build and customizations, yet choose to use a racerX fmic. May I ask why? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 4, 2013 Share Posted January 4, 2013 Pics of engine bay? Link to comment Share on other sites More sharing options...
NSFW Posted January 4, 2013 Share Posted January 4, 2013 That run was on E85. Launched @ 5K and flatfoot @ 6300. Cool, thanks for the info! Link to comment Share on other sites More sharing options...
TheBlackPearl Posted January 4, 2013 Share Posted January 4, 2013 Shit dude, nice pass! Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
Doogie29th Posted January 4, 2013 Author Share Posted January 4, 2013 Pics of engine bay? <---- I have pics in my albums. Click on my avatar. Link to comment Share on other sites More sharing options...
Doogie29th Posted January 4, 2013 Author Share Posted January 4, 2013 Interesting. You go through a whole lot of trouble doing a nice build and customizations, yet choose to use a racerX fmic. May I ask why? I think the racerX fmic is a nice product. Keep the fogs, good size core, easy to install. The price to great. What fmic would you use instead? Link to comment Share on other sites More sharing options...
mattg Posted January 4, 2013 Share Posted January 4, 2013 Props Link to comment Share on other sites More sharing options...
PeterJMC Posted January 4, 2013 Share Posted January 4, 2013 Nice run! Link to comment Share on other sites More sharing options...
bigjweb Posted January 4, 2013 Share Posted January 4, 2013 I think the racerX fmic is a nice product. Keep the fogs, good size core, easy to install. The price to great. What fmic would you use instead? Nice compared to what? How many intercoolers have you had? Not ragging on you, but most people only like it because they haven't seen the nice stuff. You had to fab custom piping, i'm sure that wasn't done because you wanted to. There's a bunch of brands out there that are good. Avo allows you to keep your fogs and bumper beam as well. Most people shy away from the more expensive intercoolers. But this is one area where you get what you pay for. IMO, the racerX has one of the worst core densities that I have seen. While it may not be a knock off by definition, it shares the same quality as one. The biggest thing that I preach to people when it comes to intercoolers, is that not all cores are the same. Core density is just as important as size and location. I've had five different intercoolers and the Process west TMIC is the best one by far. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 4, 2013 Share Posted January 4, 2013 Thats one quick 20g! Love the 60'. Obscene in the 90+ temps. Link to comment Share on other sites More sharing options...
Spec B Posted January 4, 2013 Share Posted January 4, 2013 Bigweb - Why did you by an LGT instead of a Ferrari? Link to comment Share on other sites More sharing options...
Spec B Posted January 4, 2013 Share Posted January 4, 2013 OP - Awesome run...congrats. Link to comment Share on other sites More sharing options...
bigjweb Posted January 4, 2013 Share Posted January 4, 2013 Bigweb - Why did you by an LGT instead of a Ferrari? Because LGT has the potential to be faster and handle better My turn - Why you call yourself JDM tuner wanna be? You been tuning the RHD cars lately? Link to comment Share on other sites More sharing options...
bigjweb Posted January 4, 2013 Share Posted January 4, 2013 Max, you got to turn up the boost on that 550. You got 20g's making more then you now;) Link to comment Share on other sites More sharing options...
