WahooNo2 Posted September 1, 2017 Share Posted September 1, 2017 Anything that will help! I get the brackets are in inches but I guess I dont understand how to measure each side from 1 starting point? Haha if that makes sense? Just kinda looking for something that shows each side in inches. Again, if that makes sense... In the brackets there are inch marks. you start with a 48 x 48 inch sheet of material startIng from the bottom measure from the lower left corner 11.5 inches to the right and mark it then at 36.5 mark again. Then from from the lower left corner again measure up 6.25 inches, then 19.25... and work your way around with the points. Draw lines between the points and then cut. maybe try on graph paper first so you get the measuring part down. You dont need to really know how long things are just where all the points are and then you connect the dots and draw lines and you get a cool T shaped under tray. Link to comment Share on other sites More sharing options...
amm203 Posted September 1, 2017 Share Posted September 1, 2017 PDF attached showing different dimension style. Running dimensions (as SCHM1AN originally showed) make for easier fabricating. However, this PDF might make more sense to some people. Thanks again to SCHM1AN for taking the time to measure this out and test-fit!SkidPlateDims.pdf Link to comment Share on other sites More sharing options...
risdb1 Posted September 2, 2017 Share Posted September 2, 2017 Great idea Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
MrMileHighGuy Posted September 3, 2017 Share Posted September 3, 2017 Very nice! I'll be making one as I need to replace mine. Thanks! Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted September 6, 2017 Share Posted September 6, 2017 See if that link works. That's the dxf file for the skid plate. Any machine shop should be able to take that and convert it to whatever they want to use skid plate Link to comment Share on other sites More sharing options...
