ThatGuyFromAus Posted January 3, 2013 Author Share Posted January 3, 2013 After abit of research I found it to be NGK FX61 is this correct?? Thanks Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted January 3, 2013 I Donated Too Share Posted January 3, 2013 If you're going to go through the trouble of a grounding mod, may I suggest going all the way and just do the big 3 mod. As the book says: Half measures availed us nothing. Use welding cable, It's better and cheaper. Fellow friend of Bill W.? Link to comment Share on other sites More sharing options...
stevenva Posted January 3, 2013 Share Posted January 3, 2013 Fellow friend of Bill W.? Yes RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
stevenva Posted January 3, 2013 Share Posted January 3, 2013 After abit of research I found it to be NGK FX61 is this correct?? Thanks Ah yes. I was thrown off by the term "leads". NGK (7600) FX61 are what I got. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted January 3, 2013 Author Share Posted January 3, 2013 Haha sorry about that just slang that I use. Link to comment Share on other sites More sharing options...
DenCon509 Posted January 3, 2013 Share Posted January 3, 2013 Bosch Platinum +4? (for '97 2.5 LGT) Link to comment Share on other sites More sharing options...
twisty Posted January 7, 2013 Share Posted January 7, 2013 After abit of research I found it to be NGK FX61 is this correct?? Thanks this will work. its the same set i ripped off of a 1998 impreza wagon while i was at a junk yard. the thing got totaled, had brand new wires on it. i ripped the coil also, got both for 14 bucks. the cables have the same specs as our stock cables, the only difference are the coil ends. male vs female. also, the driver side cables have a 90 deg bend in there to avoid hitting the throttle cables. Link to comment Share on other sites More sharing options...
LONO100 Posted January 7, 2013 Share Posted January 7, 2013 i just bought a set of bosch iridium plugs and wires. anyone have any opinions on this brand for use in subies? i run them in my truck and they do great, just wondering what people though of these on legacies. Link to comment Share on other sites More sharing options...
stevenva Posted January 7, 2013 Share Posted January 7, 2013 I've used the iridium plugs before and noticed no difference. Iridiums were designed for newer cars that don't recommend replacing plugs for 100,000 miles or some goofyassnumber. Subies are so easy to do. If it was my old GMC Jimmy then I might consider it. That number 6 plug had 0 access. I use regular NGKs in mine and it runs great. Be careful with your aluminum heads. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
twisty Posted January 8, 2013 Share Posted January 8, 2013 i put iridium plugs this last go round, i havent seen (or noticed) any change over the coppers i had in there. both are NGK brand tho, ive used the bosch in my dodge truck and they seem to work well. Link to comment Share on other sites More sharing options...
LONO100 Posted January 8, 2013 Share Posted January 8, 2013 I just tested my spark plug wires and they are all reading between 11 & 12.5. Should i still replace them p or take them back and save my 50 bucks? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 9, 2013 Share Posted January 9, 2013 Bosch Platinum +4? (for '97 2.5 LGT) No. Do not do this. I've used these before on my old 2.2s. Do this & it won't take you long to get to Misfire City. Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted January 10, 2013 Author Share Posted January 10, 2013 Bit of an Update I've ordered NGK FX61 Wires $47.71 NGK BKR6IEX-11 $ 7.45 each MSD 8239 $ 90 I received the coil overnight but when it turned up i found the coil to be cracked so I'm in a depute currently with the company because they don't cover shipping damages although the box it was shipped in wasn't damaged it was the actual MSD box which means it was damaged before they even packed it. Hopefully it gets resolved shortly Link to comment Share on other sites More sharing options...
smokee_won Posted January 11, 2013 Share Posted January 11, 2013 pulstars with a well grounded engine block does wonders for me Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 12, 2013 Share Posted January 12, 2013 Bit of an Update I've ordered NGK FX61 Wires $47.71 NGK BKR6IEX-11 $ 7.45 each MSD 8239 $ 90 I received the coil overnight but when it turned up i found the coil to be cracked so I'm in a depute currently with the company because they don't cover shipping damages although the box it was shipped in wasn't damaged it was the actual MSD box which means it was damaged before they even packed it. Hopefully it gets resolved shortly Bastards! Link to comment Share on other sites More sharing options...
