iNVAR Posted November 12, 2012 Share Posted November 12, 2012 I agree with ripemeat. The target is still 14.7. If you're using more fuel in closed loop mode on the AP compared to another map, it's because your fuel trims haven't adjusted yet... If you keep resetting the ECU, it'll never learn to pull fuel. Link to comment Share on other sites More sharing options...
Rancid Posted November 13, 2012 Share Posted November 13, 2012 accesport... Which monitor? The AP does not have a fuel level monitor. It honestly sounds like you're just guessing. Cruising and idle will target right about 14.7 AFR. Link to comment Share on other sites More sharing options...
ripemeat Posted November 13, 2012 Share Posted November 13, 2012 log a/f sensor 1, it should show up in afr. it's accurate until you start to hit boost Link to comment Share on other sites More sharing options...
stuck686 Posted November 13, 2012 Share Posted November 13, 2012 dont know how to log with mac Link to comment Share on other sites More sharing options...
slvr08lgt Posted November 18, 2012 Share Posted November 18, 2012 I called Cobb yesterday and asked about running there sf intake and using tere stage 1 tune..I asked the tune says not compatible with any intake turbo etc other then stock but then if u look at the intake on the web it says they make tunes for it..the guy told me that you/me should be fine running the stage one or two(supporting mods) because its the same as the stock intake Link to comment Share on other sites More sharing options...
ripemeat Posted November 18, 2012 Share Posted November 18, 2012 lolwut Link to comment Share on other sites More sharing options...
HOJeepster Posted December 16, 2014 Share Posted December 16, 2014 So I just installed a Cobb catted DP and loaded the OTS Stage 2 91 octane map. My first impressions is that I like the stock & stage 1 mapping better. This stage 2 map doesn't make the car feel in boost as much, just more motor revving. Not really what I expected, but I'll give it a few days to try and learn. Anyone else less than satisfied with the OTS stage II 91oct? Link to comment Share on other sites More sharing options...
cryo Posted December 17, 2014 Share Posted December 17, 2014 Give it a couple days and report back. If your still unhappy with the performance after that it may be a leak that developed or the map itself doesn't sit well on your specific car but either way the stage 2 setup should net a noticeable gain in power and torque than stock/stage 1. I notice you are in co, we would be happy to help you out with a custom tune as well to reap the most out of your setup safely. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
HOJeepster Posted December 17, 2014 Share Posted December 17, 2014 Thanks Dave - I might just consider that. I'm noticing the upshifts are now less smooth, and more ubrupt. Update - after a day or two of driving, the OTS map feels like its settling in for the better. Not too shabby at all. Link to comment Share on other sites More sharing options...
scooby_x Posted December 22, 2014 Share Posted December 22, 2014 Gentlemen, From what I am reading on this post it would seems that a Cobb OTS stage 2 map with an SF intake and no boost gage is a BAD idea. I have a 2005 wrx with a custom stage 2 tune and am looking to upgrade to 2009 lgt. I have found one with low mileage, cat-less divorced downpipe, SF intake, and cobb stage 2 tune. It has no gages so that makes me worry...am I being paranoid? Thanks! Link to comment Share on other sites More sharing options...
serx7 Posted December 23, 2014 Share Posted December 23, 2014 If that LGT has a Cobb tune it presumably comes w/ an AP, so you could always throw Boost on the AP's live display and use that. I prefer having an analog gauge but I do have Boost as one of my AP3's gauges, which I use primarily to keep an eye on peak boost. Link to comment Share on other sites More sharing options...
