Tehnation Posted September 16, 2012 Share Posted September 16, 2012 2 of my wheel studs broke on my front driver side hub. Can I replace the studs or do I need an entire new wheel hub? Link to comment Share on other sites More sharing options...
xilles Posted September 16, 2012 Share Posted September 16, 2012 you can replace just the studs not hard if you know how.. take wheel off. take brakes off. take rotor off. hit broken stud out. install new studs put rotor on. tighten lug on to pull new studs into the housing replace brakes install wheel drive Link to comment Share on other sites More sharing options...
Tehnation Posted September 16, 2012 Author Share Posted September 16, 2012 awesome, i just replaced the rear bearing so, I know exactly what to do. Thanks a bunch. Link to comment Share on other sites More sharing options...
Tehnation Posted September 16, 2012 Author Share Posted September 16, 2012 I was about to have nightmares! Worked perfectly, thanks for the quick reply! I was lucky I kept the old rear wheel bearing, just knocked those out and used those. I just had to buy a set of lug nuts, I like cheap fixes.. Link to comment Share on other sites More sharing options...
xilles Posted September 17, 2012 Share Posted September 17, 2012 nice im glad it worked out. fronts are always easier then rears. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 17, 2012 Share Posted September 17, 2012 You should use anti-seize compound on the studs so the lug nut don't mess up the threads. I do that on all the cars I work on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted September 18, 2012 Author Share Posted September 18, 2012 I used loctite! I learned my lesson lol. Link to comment Share on other sites More sharing options...
whitetiger Posted September 18, 2012 Share Posted September 18, 2012 loctite?!? have fun getting a flat and putting on the spare Link to comment Share on other sites More sharing options...
Tehnation Posted September 18, 2012 Author Share Posted September 18, 2012 loctite anti sieze Link to comment Share on other sites More sharing options...
whitetiger Posted September 18, 2012 Share Posted September 18, 2012 oh.. Link to comment Share on other sites More sharing options...
dr_sharp Posted September 18, 2012 Share Posted September 18, 2012 How did the 2 studs break? I had 2 studs break a couple of years ago and the dealer replaced them. I never determined teh cause but figured it had to do with taking to a shop that was hasty with air tools about a week prior. lol Link to comment Share on other sites More sharing options...
Tehnation Posted September 19, 2012 Author Share Posted September 19, 2012 Was getting tires changed and they told me 2 of the bolts are seized. So i said move over lemme give it a shot annnnd then I only had 3 studs left. Link to comment Share on other sites More sharing options...
xero287 Posted September 19, 2012 Share Posted September 19, 2012 Jeez, seized lugs. Someone over-torqued those lol Link to comment Share on other sites More sharing options...
