specialB Posted August 22, 2012 Share Posted August 22, 2012 So Subaru did a recall on many of their ECU's sometime a few years ago. Symptoms that i had (and still have) is cooling fans that run constantly. i had my car checked out back when I heard about this recall and they said my car was not one of the affected... My tuner is concerned my ECU could take a s*=t whenever and wind up destroying my pretty new motor. My question is where can i source a rebuilt ECU over spending like $900+ on a bran new one? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2012 Share Posted August 22, 2012 You may want to ask this in the Tuning forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Strizzy Posted August 22, 2012 Share Posted August 22, 2012 http://www.car-part.com http://car-part.com/cgi-bin/search.cgi?userSearch=int&userPID=1000&userLocation=USA&userIMS=&userInterchange=B%3D%40CA&userSide=&userDate=2006&userDate2=2006&dbModel=70.6.1.1&userModel=Subaru%20Legacy&dbPart=590.1&userPart=Engine%20Computer&sessionID=200000000000000000517857938&userPreference=grade&userZip=60440&userLat=41.6956&userLong=-88.0759&userIntSelect=623985&userUID=0&userBroker=&userPage=1&iKey= My bad luck build Link to comment Share on other sites More sharing options...
specialB Posted August 22, 2012 Author Share Posted August 22, 2012 These are all used, how do i know they're not bad like mine? Would be safer buying a remanufactured one Link to comment Share on other sites More sharing options...
Strizzy Posted August 22, 2012 Share Posted August 22, 2012 When I purchased my new (used) ECU, the salvage yard guaranteed it would work or I could return it for full refund, including shipping charges. The $125 I spent was a hell of a lot cheaper than new, and worked. My bad luck build Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 22, 2012 Share Posted August 22, 2012 You can pick them up on ebay too. Link to comment Share on other sites More sharing options...
ericem Posted August 22, 2012 Share Posted August 22, 2012 do your fans constantly run ? I think your concerned your ecu will die but it's fine ? Link to comment Share on other sites More sharing options...
specialB Posted August 23, 2012 Author Share Posted August 23, 2012 Yea my fans constantly run and my tuner tells me its only bound to fry eventually. I've never seen nor heard of this first hand happening before but I definitely would look into spending the few hundred for a new computer. plus, those fans running all the time is noisy and obnoxious. Link to comment Share on other sites More sharing options...
specialB Posted August 23, 2012 Author Share Posted August 23, 2012 When I purchased my new (used) ECU, the salvage yard guaranteed it would work or I could return it for full refund, including shipping charges. The $125 I spent was a hell of a lot cheaper than new, and worked. I'll have to be sure of a guarantee if I go that route, thanks! Link to comment Share on other sites More sharing options...
.blackgt. Posted August 23, 2012 Share Posted August 23, 2012 When you say all the time, you mean they absolutely never turn off? How was this not addressed when you got the car? That would annoy the hell out of me! Link to comment Share on other sites More sharing options...
Strizzy Posted August 23, 2012 Share Posted August 23, 2012 Are your green test connectors disconnected? My bad luck build Link to comment Share on other sites More sharing options...
.blackgt. Posted August 23, 2012 Share Posted August 23, 2012 Wow that would be awesome if his problem turned out to be that simple. Link to comment Share on other sites More sharing options...
Bioya Posted August 23, 2012 Share Posted August 23, 2012 Are your green test connectors disconnected? If the tuner was the one telling him about this issue, I'm sure even a poor tuner would know, and be using for the tune, the green connectors. Link to comment Share on other sites More sharing options...
FJuan Posted August 23, 2012 Share Posted August 23, 2012 When you say all the time, you mean they absolutely never turn off? How was this not addressed when you got the car? I had this problem just a year after buying the car. The fans will run all the time when the key is in the "ON" position. Luckly my ECU was covered under the recall and they replaced it with a new one. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
ehsnils Posted August 23, 2012 Share Posted August 23, 2012 If the tuner was the one telling him about this issue, I'm sure even a poor tuner would know, and be using for the tune, the green connectors. Easy to make a mistake there. But very embarrassing... Link to comment Share on other sites More sharing options...
specialB Posted August 23, 2012 Author Share Posted August 23, 2012 Are your green test connectors disconnected? they are disconnected and have been since I went stage II like over two years ago Link to comment Share on other sites More sharing options...
.blackgt. Posted August 23, 2012 Share Posted August 23, 2012 They should have always been disconnected, not simply after a tuning session. Did you only notice them unplugged after you went stage deuce? Link to comment Share on other sites More sharing options...
specialB Posted September 7, 2012 Author Share Posted September 7, 2012 I believe so Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
dingbang Posted September 7, 2012 Share Posted September 7, 2012 I went through this with my dealer. If they replaced the fan relay and your fans are still always on, they need to replace the ECU under the recall. If your dealer is giving you sh*t about it, call SOA and tell them what's going on. They'll call your dealer, tell them to pull their heads out of their collective rear ends and do the recall correctly. Link to comment Share on other sites More sharing options...
specialB Posted September 7, 2012 Author Share Posted September 7, 2012 I'll try going through a different dealer. Pita part is that I'd have to flash it back to stock there, have them do the work, then reload my maps. Unless they could somehow give me the ecu and i can just have my tuner install it?? Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
dingbang Posted September 7, 2012 Share Posted September 7, 2012 I'll try going through a different dealer. Pita part is that I'd have to flash it back to stock there, have them do the work, then reload my maps. Unless they could somehow give me the ecu and i can just have my tuner install it?? Sent from my DROID RAZR using Tapatalk 2 They won't do that as they have to install the ECU to satisfy the recall. On drop off for the ecu replacement, I gave them explicit instructions that they are not to 'test drive' my car once the ecu replacement was complete. They could turn it on and idle it - on a cold engine start, the fans should not turn on, so there's no reason for them to drive it around. The fans not turning on is the only thing they need to make sure to it was fixed. Told them they could, at low RPM, drive it from the bay to wherever they park completed cars. I told them why, and that they would be held responsible if they went against my terms and damaged my engine in any way. Plopped myself into my car when I went to pick it up, reflashed, and was good to go. Oh and, you shouldn't have to reflash your car to stock as it would be a completely new ECU that they are putting in your car. Link to comment Share on other sites More sharing options...
specialB Posted September 7, 2012 Author Share Posted September 7, 2012 You don't have to un marry to marry to a new ecu? Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
dingbang Posted September 7, 2012 Share Posted September 7, 2012 Ohhh, you're tuned with an accessport? If that's the case, then yes, un-marry/re-marry. No idea what your tune is, but when they did mine, I was running vf52/e85/740 inj. So low RPM get it from point a to point b odds were nothing catastrophic was going to happen. Hence also why I told them no test drive. They also saw me taking pictures/video of the mileage after I pulled it into the install bay. haha (had a bad experience about 10 years ago with a shop taking my SVX for a romp...) I pretty much take pictures of the odo, video of the install bay with a wall clock shot panning to the odo every time for rare instances when I bring my car in somewhere. Kinda crazy, I know. Link to comment Share on other sites More sharing options...
specialB Posted September 10, 2012 Author Share Posted September 10, 2012 Not crazy at all i don't trust anyone either Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
