SBT Posted August 4, 2005 Share Posted August 4, 2005 There may be something about increased engine performance (driver noted) in the 3500-5000 RPM range on an 0W-30W full synthetic oil. I mention that because the Active Valve Contol System (AVCS) is operated by an engine oil pressurized system. It seems logical that this would be the case because: That RPM range would be during boostThe AVCS could possibly react faster with a lighter viscosity oil coursing through what looks like some pretty small oil journals, opening up the valve breathing a little quicker, which would lead to better performance sooner in the power bandReduced friction across the engine "system" including the turbo would lead to easier/faster turbo spool and reaching boost a bit fasterThere may be more reasons but I think it's likely that drivers are noticing an increase in power delivery at these RPMs. Would be interesting to dyno and see. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
melayout Posted August 4, 2005 Share Posted August 4, 2005 A 0W-30, 5W-30 or 10W-30 at operating temp is a 30 weight oil, so running a 0W-30 oil isn't going to be lighter than any other 30 weight oil. I keed I keeed Link to comment Share on other sites More sharing options...
Ed_T Posted August 4, 2005 Share Posted August 4, 2005 I read somewhere on BITOG that GC doesn't flow as well as some other syns cold. Link to comment Share on other sites More sharing options...
wukindada Posted August 4, 2005 Share Posted August 4, 2005 I am sure the German Castrol syntec is a great product but for 30.00 plus tax for 5qts:lol: Has anyone had it lab tested against Mobil 1 EP? If it is proven to be much better, I will spend the extra 8.00;) Otherwise that is a 1/4 tank of V-Power:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
