Kodax Posted August 8, 2012 Share Posted August 8, 2012 I was traveling on I-5 and a car rear ended me. The damage wasn't any significant. My rear bumper was a hole, couple of dents and some scratch marks. My front bumper also suffered some scratches as my car was pushed forward to another car. The other owner and I exchanged information. Visually, my car doesn't look so bad but I am worried about the mechanical parts in my car. Since most of the damages are at the rear, I was wondering what kind of damage could there be done. Also, I am going out of town tonight and I will be driving my car, I was wondering if it is wise to drive my car tonight. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 8, 2012 Share Posted August 8, 2012 Post pics but it sounds like your typical fender bender. Likely some damage to the bumper beam foam, R&R of bumper, etc. Are you fenders damaged? Sounds like a minor impact. Sorry for your frustration. Glad you are okay. Link to comment Share on other sites More sharing options...
InnocentGuns Posted August 8, 2012 Share Posted August 8, 2012 Sounds minor. but... worst case scenario is you twisted your body/subframe and car tracks off center. after all body work is done make sure it gets an alignment. and it should be ok to drive as long as you arent leaking any fluids and it isnt pulling to one side bad. Link to comment Share on other sites More sharing options...
Berzerklo Posted August 8, 2012 Share Posted August 8, 2012 Before your leave pay close attention to see if your car pulls off center or has any strange vibrations while driving. If the car is driving normally and you aren't leaking fluids like he ^^^ said, it is probably just cosmetic damage. Link to comment Share on other sites More sharing options...
Kodax Posted August 8, 2012 Author Share Posted August 8, 2012 Here is the damage. Doesn't look too serious I presume. There is one more picture that I couldn't upload. It is a picture from inside the trunk. Seems like the accident has knocked some of the carpet in the trunk out of place. Not sure if that means anything. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 9, 2012 Share Posted August 9, 2012 I would be worried about the rear bumper control arms, but otherwise it doesn't look bad. lol Link to comment Share on other sites More sharing options...
Kodax Posted August 9, 2012 Author Share Posted August 9, 2012 I would be worried about the rear bumper control arms, but otherwise it doesn't look bad. What are the signs to look out for damaged rear bumper control arms? Link to comment Share on other sites More sharing options...
dr_sharp Posted August 9, 2012 Share Posted August 9, 2012 That was sarcasm there's no such thing as rear bumper control arms. Just take it to a body shop and you'll be fine. Getting a new bumper+paint is at worst $1k. If they can pop out that bad dent it should be less. lol Link to comment Share on other sites More sharing options...
InnocentGuns Posted August 9, 2012 Share Posted August 9, 2012 Looks very minor. how is the alignment from the bumper cover to the quarter panel? Front end saw less damage im guessing? Link to comment Share on other sites More sharing options...
ragman Posted October 17, 2012 Share Posted October 17, 2012 [ATTACH]125258[/ATTACH][ATTACH]125259[/ATTACH] Here is the damage. Doesn't look too serious I presume. There is one more picture that I couldn't upload. It is a picture from inside the trunk. Seems like the accident has knocked some of the carpet in the trunk out of place. Not sure if that means anything. What was the outcome on the bumper? Did they fix that rear bumper cover or replace it? Total bill? I got rear ended today on I25, and my bumper looks worse than that, but similar. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted October 17, 2012 Share Posted October 17, 2012 That was sarcasm there's no such thing as rear bumper control arms. Just take it to a body shop and you'll be fine. Getting a new bumper+paint is at worst $1k. If they can pop out that bad dent it should be less. Make sure they check to see if you lost any blinker fluid in the accident though! Glad you're ok, looks pretty darn minor, "that should buff right out". Link to comment Share on other sites More sharing options...
MrTris Posted October 17, 2012 Share Posted October 17, 2012 Definitely check for damage to the muffler bearings, as a rear-ender can cause negative pressure to build up in the exhaust housing of the mufflers, which creates pressure and causes excess wear to the mufflers and their bearings. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted October 17, 2012 Share Posted October 17, 2012 Definitely check for damage to the muffler bearings, as a rear-ender can cause negative pressure to build up in the exhaust housing of the mufflers, which creates pressure and causes excess wear to the mufflers and their bearings. Wait wait, I didn't think the muffler bearings were servicable on the 4th gen LGT.....shouldn't the mufflers themselves be replaced instead? Link to comment Share on other sites More sharing options...
joeblow Posted October 17, 2012 Share Posted October 17, 2012 They're not typically serviceable because its a closed system. But if something opens the system, such as a crack resulting from a rear end collision, they should be adjusted accordingly. I think the FSM calls for at least a lubrication of the bearings, if not a full blown replacement when the system is opened. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 17, 2012 Share Posted October 17, 2012 And dont use mobil1 Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted October 17, 2012 Share Posted October 17, 2012 So what kind of sandwich is everyone eating today? Link to comment Share on other sites More sharing options...
MrTris Posted October 17, 2012 Share Posted October 17, 2012 Due to this back-assward thread, I'm gonna go with. . . Sh*t Sammich. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted October 17, 2012 Share Posted October 17, 2012 I could go for one of these today, if only I knew of a good place around Santa Monica for one. http://macorixny.com/wp/wp-content/uploads/2012/07/PulledPorkSandwich.jpg Link to comment Share on other sites More sharing options...
xero287 Posted October 17, 2012 Share Posted October 17, 2012 Does it look like that on the way out too? Link to comment Share on other sites More sharing options...
02603sec Posted October 17, 2012 Share Posted October 17, 2012 Could have been a lot worse! Link to comment Share on other sites More sharing options...
ruggerheist Posted October 17, 2012 Share Posted October 17, 2012 looks to be at least $10k in damage, insurance may just total your car. sorry for your loss Link to comment Share on other sites More sharing options...
Max Capacity Posted October 18, 2012 Share Posted October 18, 2012 That'll buff right out. I'd be more worried about the whiplash in your neck. Man I'm surprised your even able to drive the car after that kind of a impact. BTW we had sloppy joes for diner last night. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PB007 Posted October 19, 2012 Share Posted October 19, 2012 Effing Seattle drivers right?!?! Sorry to hear about your bad luck but if the trunk closes, your airbags didn't go off, and the exhaust isn't harmed (a quick visual and maybe try shake it and see if anything moves more than normal) the damage appears to me more of a hit to the pride than the car. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted October 19, 2012 Share Posted October 19, 2012 the damage appears to me more of a hit to the pride than the car. *DING DING DING!* What do we have for him Johnny? Link to comment Share on other sites More sharing options...
