wurkenman Posted June 24, 2012 Share Posted June 24, 2012 I put in my request a couple of weeks ago, but no one listened, so I had to do the yard work first. Now that it's done on the the 05 LGT engine build. Here are some of the internals. http://i433.photobucket.com/albums/qq54/wurkenman/LGT/P1010282.jpg The crank. What is the clearance on the rods to the crank. These feel kind of loose. http://i433.photobucket.com/albums/qq54/wurkenman/LGT/P1010285.jpg If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted June 25, 2012 Author Share Posted June 25, 2012 Checked the rod clearance and it is good at .0015. Now just waiting for the right main bearings. Seems that I bought an under size set. Not only am I getting old, apparently I can't frikin read either. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 25, 2012 Share Posted June 25, 2012 If you bought cosi's, you're not alone in screwing that up. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
wurkenman Posted July 2, 2012 Author Share Posted July 2, 2012 Got the right bearings. Block halves together. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-01134611.jpg Almost too pretty to hide in an engine block. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-01134659.jpg If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Leviman Posted July 2, 2012 Share Posted July 2, 2012 Aren't you supposed to put the pistons on the rods before the case halves go together? This ain't no VW... Link to comment Share on other sites More sharing options...
wurkenman Posted July 2, 2012 Author Share Posted July 2, 2012 Aren't you supposed to put the pistons on the rods before the case halves go together? This ain't no VW... Not possible. At least I can't figure it out. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2012 Share Posted July 2, 2012 Not possible. At least I can't figure it out. Correct that why there are those ports in the side of the block. That's one of the pieces that make these engine rebuilds labor intensive and why my buddy told me to get a new oem short block instead of paying his shop to rebuild my old short block. If I want a 400whp+ block he could build me a good one. But for my hp goals it wasn't worth it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wurkenman Posted July 2, 2012 Author Share Posted July 2, 2012 Correct that why there are those ports in the side of the block. This is my fourth Subaru tear down. Believe me the first one was a mystery on how to get the pistons and block separated. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted July 2, 2012 Author Share Posted July 2, 2012 Getting a little closer. They sure look nice in their home. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-02150454.jpg Still working on putting a transmission in my sons WRX at the same time. Here is what the garage looks like at the moment. http://i433.photobucket.com/albums/qq54/wurkenman/2012-06-28220715.jpg If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 3, 2012 Share Posted July 3, 2012 you need a lift My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
2000_LegacyOutback Posted July 3, 2012 Share Posted July 3, 2012 sub'd for more Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 3, 2012 Share Posted July 3, 2012 sub'd for more x2 Link to comment Share on other sites More sharing options...
LegacyDan Posted July 3, 2012 Share Posted July 3, 2012 You not going to get the block faced before the heads go on? Link to comment Share on other sites More sharing options...
plumb Posted July 3, 2012 Share Posted July 3, 2012 whats in the brian crower boxes? Link to comment Share on other sites More sharing options...
specialB Posted July 3, 2012 Share Posted July 3, 2012 man I have three bays and three storage lifts in my garage and I'd much rather be in yours. my father is merely a collector and always gives me shit when I try to wrench on my car in the garage. can't wait to do my short block install and hopefully 6mt drivetrain swap all at the same time. good luck with the build seems like you've been around the block once or twice with these Link to comment Share on other sites More sharing options...
wurkenman Posted July 3, 2012 Author Share Posted July 3, 2012 whats in the brian crower boxes? Stage 2 cams, connecting rods, valve springs. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted July 3, 2012 Author Share Posted July 3, 2012 You not going to get the block faced before the heads go on? Took them to work and indicated the surface. Still flat within .001. Good enough. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
ckinyon Posted July 3, 2012 Share Posted July 3, 2012 you a machinist? Link to comment Share on other sites More sharing options...
wurkenman Posted July 3, 2012 Author Share Posted July 3, 2012 Yes I am a machinist. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 3, 2012 Share Posted July 3, 2012 Do you plan to port the heads and norrow the dividers ? I had my buddies machine shop do that to mine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wurkenman Posted July 3, 2012 Author Share Posted July 3, 2012 I am not doing any head work at this time. The heads are shimmed and new cams are ready for install. After having to replace the heads and the block, funds are just running low. It should still be fun and it will be my daily driver. It's not a problem pulling the engine anyway, just in case I need MORE:). If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
wurkenman Posted July 7, 2012 Author Share Posted July 7, 2012 Last couple of days have been hotter than hell in the midwest. I stayed in the house with the air on. Got out today and did some more assembly. Oil pick up and plate installed. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06201610.jpg Oil pan. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06204334.jpg Cosworth oil pump. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06205218.jpg ARP studs. http://i433.photobucket.com/albums/qq54/wurkenman/2012-07-06213206.jpg If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
KCwagon Posted July 8, 2012 Share Posted July 8, 2012 I wish my garage looked like yours and my wife is happy it does not. Looks like a great build. Thanks for the pics. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 8, 2012 Share Posted July 8, 2012 I'm here for more pictures lol Link to comment Share on other sites More sharing options...
wurkenman Posted July 8, 2012 Author Share Posted July 8, 2012 I wish my garage looked like yours and my wife is happy it does not. Looks like a great build. Thanks for the pics. My wife does not like my garage either. Too messy for her taste. More pics to follow as time permits. Yard work waits for no one and I have 2 acres of grass to cut. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
