Saul_Good Posted June 17, 2012 Share Posted June 17, 2012 Front LSD Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 Also...are there any negative effects from running a gutted uppipe on a stock tune? Link to comment Share on other sites More sharing options...
mmm def Posted June 17, 2012 Share Posted June 17, 2012 I threw a Borla and a thicker rear sway on my otherwise stock LGT and called it a day. Sounds delightful. Link to comment Share on other sites More sharing options...
SCASEYS Posted June 17, 2012 Share Posted June 17, 2012 I've seen the vids, and oh damn I'd love to have that mod! And he's local for me too. That drives me crazy! Do this, best $500.00 ever spent I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
xero287 Posted June 17, 2012 Share Posted June 17, 2012 The negative effects of running a bigger DP on your car without a tune is just that. The car will try to compensate and run timing like a hoe to try and adjust itself for the increased flow. You won't run anywhere near even. Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 The negative effects of running a bigger DP on your car without a tune is just that. The car will try to compensate and run timing like a hoe to try and adjust itself for the increased flow. You won't run anywhere near even. Ok. So what about gutted uppipe on the stock tune? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 Don't gut your up pipe, just get a catless up instead. Gutting the cat out is a major pita. Also do you have a 5eat? If so, then yes F1VB! That was certainly my favorite mod. It really transforms the way the car drives. Link to comment Share on other sites More sharing options...
xero287 Posted June 17, 2012 Share Posted June 17, 2012 Yeah, don't gut your uppipe. It's a great way to destroy your turbo if you leave shavings in there. Uppipes are fairly inexpensive too (~$180 for a really good one). http://www.grimmspeed.com/catalog/product_info.php?products_id=79 Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 I have a new, unused FMS up pipe I will sell you if you want it, as I no longer need it. It's already coated and wrapped as well. PM me if you're interested. Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 Don't gut your up pipe, just get a catless up instead. Gutting the cat out is a major pita. Also do you have a 5eat? If so, then yes F1VB! That was certainly my favorite mod. It really transforms the way the car drives. Yes, 5EAT. I can't wait for the day I have an excuse to spend the money on the F1! Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 So whats the deal with a catless uppipe on a stock tune? Link to comment Share on other sites More sharing options...
xero287 Posted June 17, 2012 Share Posted June 17, 2012 lol, the only problem you'll have with a catless uppipe is a CEL. There shouldn't be any side effects. If I were you, I'd save the money and get both and install them at the same time. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 You will throw a code because you don't have the egt sensor anymore. You can run it on the stock tune no problem, but to get rid of the code you have two choices, get a custom tune that turns the egt cel off, or use a resistor to trick the car into thinking the sensor is still there. If I were you, I would just get an up pipe, down pipe, and tune. But, if you don't plan on a DP or a tune then just put in the resistor. http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-131488.html?t=131488&highlight=egt+resistor+mod Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 If the pipe has the egt bung the light shouldnt be triggered,right? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted June 17, 2012 Share Posted June 17, 2012 My favorite mod will be the LAST one Link to comment Share on other sites More sharing options...
subiestang Posted June 17, 2012 Author Share Posted June 17, 2012 My favorite mod will be the LAST one Yea right. The last mod is selling the car! Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 There will never be a last one. Modded cars are like works of art, they are never truly finished. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 17, 2012 Share Posted June 17, 2012 45 lb shift knob. Link to comment Share on other sites More sharing options...
Cyclozene Posted June 17, 2012 Share Posted June 17, 2012 45 lb shift knob. Pix or it didn't happen! —Pirated Tapatalk app Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 17, 2012 Share Posted June 17, 2012 45 lb shift knob. Osmium shift knob? Link to comment Share on other sites More sharing options...
Legend Posted June 17, 2012 Share Posted June 17, 2012 What"s your favorite mod? E85 My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Spec B Posted June 17, 2012 Share Posted June 17, 2012 e85 +1 Link to comment Share on other sites More sharing options...
mwm5094 Posted June 17, 2012 Share Posted June 17, 2012 F1 VB. Video def doesn't do it justice. Coilovers is a close 2nd though. Link to comment Share on other sites More sharing options...
Strizzy Posted June 17, 2012 Share Posted June 17, 2012 Front LSD. My bad luck build Link to comment Share on other sites More sharing options...
jherr Posted June 17, 2012 Share Posted June 17, 2012 Stage 2 minimum, turboback and tune. Link to comment Share on other sites More sharing options...
