buckminster Posted June 12, 2012 Share Posted June 12, 2012 I have come up with a list of mods for my car, and was just curious to see if people had any thoughts or suggestions. Intake/Exhaust avo panel filter CNT catted DP Up pipe TMIC TB hose Turbo inlet hose CBE OBXmagnaflowmegan racing single tipFMSBrakes/Suspension SS brake lines H&R or Epic Springs front strut tower brace pads & fluid (but i need to do a little more research in order to narrow down my choices) Front and rear sways Interior/Audio all weather mats possibly a set of memphis pr10s that i still have from my old car Wheels motegi mr274 7 sp10 18x8 +40 Other/future options remote start accessport v2 blue volks racing rays lugs Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 12, 2012 Share Posted June 12, 2012 Make sure you get a good set of tires first and foremost. An aftermarket turbo inlet is useless on a factory turbo, save the money on that. Your car shouldn't have a cat in the UP, so no need to replace that. The strut tower brace won't really do anything, it's mostly underhood eye candy, they do look cool, but just know that going in. I would strongly suggest you replace struts/springs, or struts first. Lowering springs on oem struts rides pretty poorly in my experience. I would also replace the rear bushing on the front lca, the offset positive caster ones are my preference. Also, if you do get lowering springs, add the whiteline RC/bumpsteer kit. Pads and clean fluid bled properly are essential. SS lines are nice to have, but not necessary and won't make a huge difference. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 12, 2012 Share Posted June 12, 2012 Pretty much what he said. But I'm still running the oem TB hose. I don't see any need to replace it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 12, 2012 Moderators Share Posted June 12, 2012 I have come up with a list of mods for my car, and was just curious to see if people had any thoughts or suggestions. Intake/Exhaust avo panel filter CNT catted DP TMIC accessport v2 Brakes/Suspension pads & fluid (but i need to do a little more research in order to narrow down my choices) Front and rear sways H&R or Epic Springs Konis or other struts/shocks SS brake lines Interior/Audio all weather mats possibly a set of memphis pr10s that i still have from my old car Wheels motegi mr274 7 sp10 18x8 +40 Other/future options TB hose Turbo inlet hose Up Pipe remote start blue volks racing rays lugs front strut tower brace CBE OBXmagnaflowmegan racing single tipFMS I reordered things for you. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 12, 2012 I Donated Share Posted June 12, 2012 An aftermarket turbo inlet is useless on a factory turbo, save the money on that. Not necessarily true. I wouldn't replace it until you FUBAR the stock one, though. I'm on my third stock one, and none of the failures had anything to do with my turbo -- they all had to do with the lack of durability of the stock one. I have heard that the stock one on 07+ is more durable, though. And yes, you need the AP or a Tactrix to tune for your other mods. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 12, 2012 Share Posted June 12, 2012 I agree with that. What I meant is that unless the oem turbo inlet is damaged, it's unnecessary, no performance gains with a factory turbo. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 12, 2012 I Donated Share Posted June 12, 2012 Frankly, no performance gains with ANY turbo. It's just a durability/reliability thing. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 12, 2012 Share Posted June 12, 2012 Unless you go with a 3" inlet. Link to comment Share on other sites More sharing options...
dr_sharp Posted June 12, 2012 Share Posted June 12, 2012 Don't forget the headlight delete mod. lol Link to comment Share on other sites More sharing options...
buckminster Posted June 18, 2012 Author Share Posted June 18, 2012 Will a stage 2 ofs accewsport map work with a dp or will I have to get a protune? Link to comment Share on other sites More sharing options...
LouzGT Posted June 18, 2012 Share Posted June 18, 2012 The stage 2 map will work with just a dp but its always better to get a protune not necessary tho. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 19, 2012 Share Posted June 19, 2012 Stage 2 Cobb map will work with DP, and with or without catback, factory intake. DP is the only requirement though. Link to comment Share on other sites More sharing options...
13larry Posted June 19, 2012 Share Posted June 19, 2012 What do you do with your car?? Autocross, rallycross, go get food? Link to comment Share on other sites More sharing options...
dr_sharp Posted June 19, 2012 Share Posted June 19, 2012 go get food? lol Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 19, 2012 Share Posted June 19, 2012 If you want to keep it in good condition, you should never drive it. Link to comment Share on other sites More sharing options...
supatkd Posted June 19, 2012 Share Posted June 19, 2012 i have a 08 legacy gt auto transmission. I have cobb ap and cobb dp. What should i do next for more power? Any recommendations? Link to comment Share on other sites More sharing options...
buckminster Posted June 19, 2012 Author Share Posted June 19, 2012 What do you do with your car?? Autocross, rallycross, go get food? The car is just my dd right now. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted June 19, 2012 I Donated Too Share Posted June 19, 2012 i have a 08 legacy gt auto transmission. I have cobb ap and cobb dp. What should i do next for more power? Any recommendations? Search http://legacygt.com/forums/showthread.php/begin-modifications-your-legacy-gt-19037.html Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 19, 2012 Moderators Share Posted June 19, 2012 Search http://legacygt.com/forums/showthread.php/begin-modifications-your-legacy-gt-19037.html Search nazi is in full effect today "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted June 19, 2012 I Donated Too Share Posted June 19, 2012 Search nazi is in full effect today Hey, at least I provided a link. Link to comment Share on other sites More sharing options...
buckminster Posted June 28, 2012 Author Share Posted June 28, 2012 How do tunes affect the si-drive? Link to comment Share on other sites More sharing options...
dr_sharp Posted June 28, 2012 Share Posted June 28, 2012 In S and S# si-drive only affects throttle response. i-mode limits boost too, I'm not sure if it limits boost to a specific pressure or a specific % of max pressure. lol Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 28, 2012 Share Posted June 28, 2012 i have a 08 legacy gt auto transmission. I have cobb ap and cobb dp. What should i do next for more power? Any recommendations? Next you should get the F1 valve body before you go past stage 2. Link to comment Share on other sites More sharing options...
MatsuDano Posted June 28, 2012 Share Posted June 28, 2012 Next you should get the F1 valve body before you go past stage 2. Not available for 08+ yet Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 29, 2012 Share Posted June 29, 2012 ^And that's why you don't make suggestions on your phone, can't read the small print. Don't worry late model 5eaters, your time will come. Link to comment Share on other sites More sharing options...
