06silvarubiLGT Posted February 25, 2013 Share Posted February 25, 2013 results yet? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 25, 2013 Author Share Posted February 25, 2013 results yet? Just found out I have to wait till noon tomorrow to get my results . Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 25, 2013 Moderators Share Posted February 25, 2013 booooooo. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 25, 2013 Share Posted February 25, 2013 that's weak sauce right there.. why the delay? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 25, 2013 Author Share Posted February 25, 2013 that's weak sauce right there.. why the delay? It's a very small shop (the owner, his wife and one more dude). He got stuck on one car today that took a lot of their time apparently.. As a side note, very few shops offer compression tests around here . So not a whole lot I can do about it. I am OK waiting a little more as the shop is very close to where I live and I ride my bike to work. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 Update: guy only tested cylinders on the driver side. About 30 psi less in #4 compared to #2. He believes that the rings are fine as there was no smoke coming from the oil filler during idle. So valves may be the issue I guess . In any case, time for a teardown.. Let the fun begin. Link to comment Share on other sites More sharing options...
Indiglow Posted February 26, 2013 Share Posted February 26, 2013 valves valves valves!! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 valves valves valves!! Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 Just for the record, is this car on the stock tune, OEM MAP ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 Just for the record, is this car on the stock tune, OEM MAP ? yes sir! Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 26, 2013 Share Posted February 26, 2013 thats the problem there man.. looks like rebuild time.. what are you plans? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 Given that I am on the other side of the pond right now (), my plan is to change the bare minimum to get the car back on the road. However, I'll probably add an aftermarket oil pick up tube, a tsk3 kit for the clutch, and maybe oil lines from infamous as well. I am probably forgetting things, but that's what comes to mind right now. If the block turns out fine, I'll leave it as is for now and just get work done to the heads. I wish I could have at least pulled the engine out myself, but I don't have a garage, and no friends with one. Link to comment Share on other sites More sharing options...
Indiglow Posted February 26, 2013 Share Posted February 26, 2013 forget the oil line, get the turbo replacement kit from fred beans, comes with all new everything, keep the banjo filters in but of course clean them beforehand. never look back. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 forget the oil line, get the turbo replacement kit from fred beans, comes with all new everything, keep the banjo filters in but of course clean them beforehand. never look back. thanks for the suggestion. I'll have a look on their website. As for the banjo bolts, I already have a couple brand new ones ready to install. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 Just for the record, is this car on the stock tune, OEM MAP ? yes sir! You know what they say about the stock tune. And you know that some of us high mileage guy's have removed the banjo filters. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 You know what they say about the stock tune. And you know that some of us high mileage guy's have removed the banjo filters. Yes and yes. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2013 Share Posted February 26, 2013 Just wanted to make sure we're clear on the basic's... Good Luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 26, 2013 Author Share Posted February 26, 2013 Good Luck. Thank you. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 27, 2013 Author Share Posted February 27, 2013 After some thinking, I am still not clear on how to conclude that the rings are OK and the valves are the issue given that the leak down test apparently showed no leaks through the valves . Link to comment Share on other sites More sharing options...
Max Capacity Posted February 27, 2013 Share Posted February 27, 2013 Will history shows us that these cars are prone to burnt valves. You should also put money aside to have the block rebuilt while the heads are being rebuilt. I planned to keep my wagon so that's why I did it the way it did. I was also pretty sure I didn't have any burnt valves seeing is the wagon has been on a tune since 8000 miles. I'm also thinking rings will not a miss-fire code. Your plugs would have to have a lot of oil on them and you would have massive oil usage. If the plug's look good, it's valves. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 27, 2013 Author Share Posted February 27, 2013 You're right. I forgot that my plug on 4 was indeed dry, a bit carbon fouled. There was no oil residue on it (see: http://legacygt.com/forums/showpost.php?p=4275127&postcount=1) I was just wondering cause once the engine is teared down, can you tell if the ringlands (or rings) are damaged without taking the pistons off? And yes, I do plan to keep this car until it's dead. And maybe in a few years, do an engine swap with an FA20 if possible . Link to comment Share on other sites More sharing options...
Max Capacity Posted February 27, 2013 Share Posted February 27, 2013 I would think if the ring lands had cracked or chipped, you'll be able to see scratches in the walls. If you remember, my #2 had light scoring but nothing real bad. The others along with that one still had the crosshatch in them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 27, 2013 Author Share Posted February 27, 2013 Yeah I see. It's just mind boggling to have failing valves and yet no (apparent) air leaking through them. In any case, my major issue right now is to find a good competent mechanic to begin the surgery . That's tough.. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 14, 2013 Author Share Posted March 14, 2013 Teardown should begin next week. I've been avoiding driving the car though this Saturday, we must go and get a car seat, stroller, etc.. for our upcoming baby . Problem is that we'll have to drive a total of 190 miles (mostly highway). Car drives fine really and boosts and everything except for a rough idle and CEL at times on #4. So, do you think it'll be safe to drive the car? Link to comment Share on other sites More sharing options...
crashdumbe Posted March 14, 2013 Share Posted March 14, 2013 Why would I remove banjos for high mileage?? And what's a decent price to pay for leak down test? I'm located n northern California. Thanks Link to comment Share on other sites More sharing options...
