muhoms1 Posted June 10, 2012 Share Posted June 10, 2012 Driving home 65 mph car starts bucking check engine light come on. hook up code reader get the p0025/26 code. As im making my way to the shoulder engine start rev bouncing then bam shuts off. I coast to the shoulder. Car never starts again. Tried to turn the motor at the crank wont budge. Just bought the car in april 101k no warranty looks like im going to need a new motor. Do alot of highway driving so put 8k on the car since i had it. Can't understand wtf happened. Any one any ideas what happened. Oil levels were good no leaks no smoke just bam gone thanks. Also any one know some feasible place to buy a motor anyone selling? Link to comment Share on other sites More sharing options...
pillboy Posted June 10, 2012 Share Posted June 10, 2012 Wrong oil. Mobil 1 is known to seize Subaru motors even when it is present in the proper quantity. It is still ugly. Link to comment Share on other sites More sharing options...
muhoms1 Posted June 10, 2012 Author Share Posted June 10, 2012 doubt its oil run rotella in my sti no problems there???? same stuff in here Link to comment Share on other sites More sharing options...
MooKz Posted June 10, 2012 Share Posted June 10, 2012 Just replace the bottom end or the internals in yours. You could get away with new bearings but might as well replace it all while you're there. Link to comment Share on other sites More sharing options...
muhoms1 Posted June 10, 2012 Author Share Posted June 10, 2012 not handy when it come to building so looking for another motor Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 11, 2012 Share Posted June 11, 2012 So your STi engine seized or your new car which I assume is a N/A Legacy seized up? Seized motor means no oil did you ever check the oil since youve had the car? Bottom end is toast at the point. Link to comment Share on other sites More sharing options...
compsurge Posted June 11, 2012 Share Posted June 11, 2012 Heuberger has oem shortblock for $1800 shipped. If you have confidence in your abilities to turn a wrench, ask questions, and follow instructions (and have access to the tools) you can pull the motor from the Legacy, break it down, and reinstall it in a weekend (or two). I'm sure there are enough willing forum members in NJ to lend a hand. Link to comment Share on other sites More sharing options...
muhoms1 Posted June 11, 2012 Author Share Posted June 11, 2012 the legacy motor seized, no way i can do the work myself not that handy and this is my d/d so got to get it up and running. Possible found a motor someone local if i can pressed the op to ship on nasioc. Link to comment Share on other sites More sharing options...
MooKz Posted June 11, 2012 Share Posted June 11, 2012 Well, I guess eBay is your friend. Good luck finding cheap longblocks elsewhere. Link to comment Share on other sites More sharing options...
jton Posted June 14, 2012 Share Posted June 14, 2012 i bought a motor from a junkyard w/ 30k on it as well as a 1 year/15000 mile warranty for 600 bucks when i needed to replace my motor. it was from an 07 impreza. Link to comment Share on other sites More sharing options...
muhoms1 Posted June 17, 2012 Author Share Posted June 17, 2012 also found a motor from a 07 impreza 2.5i, is it a direct bolt in??? thanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 18, 2012 Share Posted June 18, 2012 What year is the legacy ? Link to comment Share on other sites More sharing options...
muhoms1 Posted June 18, 2012 Author Share Posted June 18, 2012 leggy is also a 07 Link to comment Share on other sites More sharing options...
compsurge Posted June 19, 2012 Share Posted June 19, 2012 The engine you want is an EJ253. I'm not sure, however, about the specs of the heads. I assume if this site has same parts for both cars that it will be fine. Use this parts site: http://parts.subaru.com/parts/2007/SUBARU/LEGACY/?siteid=215892&searchText= if you need anything. Another good reference site is http://opposedforces.com/parts/ Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 20, 2012 Share Posted June 20, 2012 leggy is also a 07 Well now that we have the basics, pull a Ej253 from a 06+ N/A 4 cyl Subaru, your Stock ECU can run any of them and it is a plug n play job. Don't mix it up and try to run EJ251 heads or a hybrid setup as you will only want to kick yourself. Rebuilding one isn't a terrible pita the work is fairly standard and youll need to go for the OEM over sized pistons made just for people that rebuild EJ25 bottom ends (.50mm overbore to 100mm dia) the heads can be refreshed if they are in bad shape (guides, lashing, seals) Link to comment Share on other sites More sharing options...
muhoms1 Posted June 21, 2012 Author Share Posted June 21, 2012 GEE-OTTO thanks picked up the imprezza long block jut have to use old intake and manifold hope to be back up and running by the weekend. Well now that we have the basics, pull a Ej253 from a 06+ N/A 4 cyl Subaru, your Stock ECU can run any of them and it is a plug n play job. Don't mix it up and try to run EJ251 heads or a hybrid setup as you will only want to kick yourself. Rebuilding one isn't a terrible pita the work is fairly standard and youll need to go for the OEM over sized pistons made just for people that rebuild EJ25 bottom ends (.50mm overbore to 100mm dia) the heads can be refreshed if they are in bad shape (guides, lashing, seals) Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted June 21, 2012 Mega Users Share Posted June 21, 2012 Oil levels were good no leaks no smoke just bam gone thanks. Also any one know some feasible place to buy a motor anyone selling? Wrong oil. Mobil 1 is known to seize Subaru motors even when it is present in the proper quantity. Wrong and wrong. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
1055 Posted June 21, 2012 Share Posted June 21, 2012 Even tbough there was oil there, doesn't mean it was making its way through the motor. Could have been a ripped pickup tube o ring, oil pump that failed, or a restriction elsewhere. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted June 21, 2012 Mega Users Share Posted June 21, 2012 oil pump i could see, pickup no. not if it was at its appropriate levels. ive never heard of a pump failing, even on an na car. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Max Capacity Posted June 21, 2012 Share Posted June 21, 2012 OP, how close are you to AZPinstalls.com they are in northern NJ. Check them out. They can do the work for you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1055 Posted June 21, 2012 Share Posted June 21, 2012 oil pump i could see, pickup no. not if it was at its appropriate levels. ive never heard of a pump failing, even on an na car. The car has 110k miles and who knows who owned/ didnt maintain it before op. I could see some hefty sludge impeding oil. Wouldnt be the first time. Also... a torn or failing pickup o ring(or even cracked pickup tube) will suck air and make shit go wrong. Link to comment Share on other sites More sharing options...
