Joaks Posted June 7, 2012 Share Posted June 7, 2012 Hopefully soon, when my motivation is high, I will replace my multifunction switch. I have a replacement and instructions. Has anyone done this before? I'm honestly just wondering if it is as difficult as I think it will be Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 7, 2012 Share Posted June 7, 2012 What is a multifunction switch? Link to comment Share on other sites More sharing options...
Joaks Posted June 7, 2012 Author Share Posted June 7, 2012 The thing containing your turn signal and headlight switches. It has a another similar name which I do not recall. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 7, 2012 I Donated Share Posted June 7, 2012 The blinker switch is what I've always know it as -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Zues Marine Posted June 7, 2012 Share Posted June 7, 2012 i believe the correct name for that piece contains the word 'stalk'.. turn stalk maybe? Link to comment Share on other sites More sharing options...
SteelFlounder Posted June 12, 2012 Share Posted June 12, 2012 I work at Advance auto and they're always listed as "combination switches." "Turn Signal Switch" or "Headlight Switch" is too specific, and on some vehicles they are a totally separate item. For example, on my old Saab 9-5 Aero the "Headlight switch" was a little unit under the dash that kept the lights on for 15 seconds after key off and then faded them out. Just my 2 cents. =) Link to comment Share on other sites More sharing options...
mattmattyxcore Posted September 22, 2012 Share Posted September 22, 2012 Old thread but I'm in need of doing this myself and could really use a point in the right direction. Has anybody here had to change their combo switch? My issue is my low beams do not work but everything else does. I've replaced relays but no dice, just wanted to see if their is an easier way aside from what the FSM says. Begins on Page 3 Continued Link to comment Share on other sites More sharing options...
Osei Posted September 22, 2012 Share Posted September 22, 2012 Have you changed the bulbs? Know it's odd for two to go at once but it has happened to me once before. Insofar as the switch is concerned, it is modular, so once the cover and perhaps wheel are removed it won't be as hard as it seems. Not familiar with that gen. O. Link to comment Share on other sites More sharing options...
mattmattyxcore Posted September 22, 2012 Share Posted September 22, 2012 I've replaced both bulbs and both relays with no success. I even went so far as to swap the spade connections on the harness so that the low's come on instead of high so I'm not pissing everybody off at night ha ha. Link to comment Share on other sites More sharing options...
Joaks Posted September 23, 2012 Author Share Posted September 23, 2012 The combo switch should be straightforward to change. I failed right at the begining while trying to take out the torx screws (I rounded one out). Mine were insanely tight. Link to comment Share on other sites More sharing options...
