charlie_sheen Posted May 25, 2012 Share Posted May 25, 2012 i still dont know if this noise is caused by a worn idler pulley, or my tob. towards the end it almost makes a new sound, a different one than in the beginning. its annoying as hell, thats for sure. goes away with clutch pressed in. only makes noise in neutral or 1st gear. is alot noiser at start up than operating temp. http://i408.photobucket.com/albums/pp166/crf150yo/th_2012-05-25_12-12-08_982.jpg Link to comment Share on other sites More sharing options...
bmx045 Posted May 25, 2012 Share Posted May 25, 2012 tob did you order the new clutch yet? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 25, 2012 Share Posted May 25, 2012 Is there a video there? I can't see that at work. I'm guessing input shaft bearing. Thinking out loud here: If I'm correct, the TOB should not be moving unless your foot it pressing in the clutch pedal ? In neutral the clutch should not be spinning, the only things spinning are the FW and PP. So the input shaft of the tranny should not be rotating too. So that say's it shouldn't be the input shaft bearing. Yet you have the noise in 1st gear. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted May 25, 2012 Mega Users Share Posted May 25, 2012 tob did you order the new clutch yet? +1 for tob. an excessively worn idler pully will sound like rod knock at idle and will not go away when you depress or release the clutch "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Ozzy Posted May 25, 2012 Share Posted May 25, 2012 That's what mine sounded like for a short while before it seized and I got a new clutch installed.. Link to comment Share on other sites More sharing options...
__raj Posted May 25, 2012 Share Posted May 25, 2012 That is what our TOB sounded like and changed the way you described. The funny part is my wife took the car to our subie mechanic for a $24 oil change. After changing oil he started car up and thought he forgot the engine oil. Apparently it finally seized for him. Good timing. For us $850 fix including the labor & clutch but kept old flywheel. Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 25, 2012 Author Share Posted May 25, 2012 it has been confirmed, the car makes the noise in all gears now. and is still apparent at operating temp Link to comment Share on other sites More sharing options...
bmx045 Posted May 25, 2012 Share Posted May 25, 2012 http://store.discovery.com/img/product/resized/232/00259565-073232_catl_200.jpg?k=3a624fa6&pid=259565&s=catl&sn=discovery Link to comment Share on other sites More sharing options...
JPU1 Posted May 25, 2012 Share Posted May 25, 2012 http://store.discovery.com/img/product/resized/232/00259565-073232_catl_200.jpg?k=3a624fa6&pid=259565&s=catl&sn=discovery Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 25, 2012 Author Share Posted May 25, 2012 fuc kyou Link to comment Share on other sites More sharing options...
bmx045 Posted May 25, 2012 Share Posted May 25, 2012 fuc kyou http://store.discovery.com/img/product/cat08/00281199-166781.jpg Link to comment Share on other sites More sharing options...
No DRFT Posted May 25, 2012 Share Posted May 25, 2012 Wtf is tob? I have no control over drippie. Link to comment Share on other sites More sharing options...
charlie_sheen Posted May 25, 2012 Author Share Posted May 25, 2012 throwout ballsack, dumbass Link to comment Share on other sites More sharing options...
No DRFT Posted May 25, 2012 Share Posted May 25, 2012 Don't talk to me that way Dickweed I have no control over drippie. Link to comment Share on other sites More sharing options...
bmx045 Posted May 25, 2012 Share Posted May 25, 2012 Not sure if cinnamon toast crunch Link to comment Share on other sites More sharing options...
No DRFT Posted May 25, 2012 Share Posted May 25, 2012 You too Fat tits I have no control over drippie. Link to comment Share on other sites More sharing options...
Gire Posted May 25, 2012 Share Posted May 25, 2012 Thread closed. Before it gets stupider in here. If that's possible. Link to comment Share on other sites More sharing options...
