Installs, Service, Maint, Repairs, etc. at the shop
It is with a heavy heart and a lump in my throat that I say goodbye to my best friend and partner in crime for the past 13 years. Our original shop mascot has left us. Unfortunately it was far too soon to leave and an unnatural exit.
You will always be loved, remembered and missed. You will always be my GOOD BOY and my BUD.
RIP "Mr." Mario.
20626697_1680531278666056_5259986563744389622_o.jpg?oh=3a8237c7fb44d22e8107753b09a391d9&oe=5A254039
  • Replies 1.2k
  • Created
  • Last Reply
Back to cars... We had a previously prepped 2015 STi on the dyno today. ETS intake, Invidia catted down pipe, ETS cat back exhaust, Cobb 1050x injectors, AEM/Cobb fuel pump, Cobb Flex Fuel kit, stock clutch.
The car made some decent power with the assistance of a Delicious Tuning map provided by Master Tuner Bill Knose of Delicious Tuning.
20689722_1681500558569128_3886188012453186789_o.jpg?oh=1ec5f01df4aa4a09e73bf9e7b8f93ad7&oe=5A35B653
20638931_1681500578569126_1234118253355164396_n.jpg?oh=be1718ebf39d4a303d3bb872bfc65ec2&oe=5A2D1E95
Another busy day at the shop. Another car on the dyno today getting a Flex Fuel tune from Delicious Tuning. Pump gas tune was completed and on the third pull on e85 the (customer supplied) DW65c burnt out. We will be swapping the pump out tomorrow and hopefully finishing the tune so the customer can have the car back for the weekend.
20745985_1682441045141746_3475896158225384297_o.jpg?oh=4f9911fcf126c2535cbc6711ee66a4f8&oe=5A2EEDC7
What pump are you going to put in? Have you seen the DW65cs failing more frequently?
i believe the AEM pump is now the favored one. 50-1215?
Mike can correct me if I misinform, but apparently the 65c's are know to fail when on Ethanol. They overheat and die.
We'll be going with a 300c next.
The DW65c are known to fail (overheat) when used with ethanol. We will be going to a DW300c. The AEM pumps fit like pooh imho and I am not a fan. Bill, my tuner does not like the AEM pumps either, but is a fan of the 300c. We have not had issues with the 300c pumps failing.
Performed a little maintenance and upgrades on a 2013 BRZ today. It was time for the 60k service, which we took care of. We also installed some new chassis bracing, sway bars and links. Lots of Cusco blue under the car now, along with a set of Whiteline end links.
20690001_1683410931711424_3562953436478545478_o.jpg?oh=b50662647fc0de8e87f8c0e5348b9570&oe=5A21134B
20728050_1683411058378078_4840799657597516952_n.jpg?oh=9e6bd96ac82aa40539931c1038597060&oe=5A37D791
20728689_1683411478378036_2206722091833067386_o.jpg?oh=7f0c30cf8afe2c3bbd005801deb93f73&oe=59F066B3
20776480_1683411455044705_5184873058895007171_o.jpg?oh=ae8dd1615bd21e4201e85689d06567a4&oe=5A2758E0
20664729_1683411578378026_8787876055241982042_n.jpg?oh=707c408c0b71406fb1c14dd8f29810bb&oe=5A396F74
FA20 out of a 2015 BRZ almost ready to drop back in the car. Finish up this one and then I have an EJ255 to drop back in a WRX. Should have that engine ready to go by Wed. Had another FA20 dropped off this morning to have the engine pulled and I have a 2012 STi scheduled to be dropped off this week to have the engine pulled (lifted heads). Possibly another 06 WRX with lifted heads getting dropped off this week too. Two on deck, two more waiting and possibly a third. The engine "storm" continues.
20786071_1686382594747591_5313950116051670392_o.jpg?oh=fd74340c3125de68ef32ad9a5f38b169&oe=5A3989EF
A crank and rod bearing from an FA20 recently disassembled. Best I can say is a HEAVY pulsation ripped the bearings apart. There are times when a diagnosis can not be performed of the cause/effect, because the remaining parts are so badly damaged. This damage happened in less than 3000 miles. This could be severe "abuse" from multiple points; tune, fuel used, ambient conditions, environment, etc.
For example: if a tune is perfect but air temp rises dramatically due to an undersized inter cooler or not enough air flow over the inter cooler core, this type of damage could occur. If air temps were perfect and the tune was perfect but fuel was of a poor grade, or the fuel pressure dropped this type of damage could occur. This type of damage could result from any number of combinations.
Keep in mind that with supercharged FA20's (BRZ/FRS) the intake air temp sensor is many times before the super charger and the inter cooler.
20881822_1687510557968128_8450571945323098774_n.jpg?oh=ab503e847cbbc52ae63b6ced5fe66b29&oe=5A24FA2B
20799248_1687510744634776_5775632502350805022_n.jpg?oh=bf0eaf9999bd8c67a46bbfe51a888776&oe=5A2473B3
20800226_1687511147968069_3363412657274511136_n.jpg?oh=c4e2c3a0bbba939f9ab74e8175dcb393&oe=5A2B8514
20799500_1687510954634755_6129356612424473264_n.jpg?oh=dc2e1e9229597512b5dcd694e4bf6aa1&oe=5A2D6A28
20881980_1687511031301414_7992572319491370665_n.jpg?oh=fe5d88214e340e4909fb50771b86e6e8&oe=5A1F5089
20882063_1687511111301406_4721045637748890726_n.jpg?oh=54067cb4488e0c27fa1423a8e4406e89&oe=5A202A90
For anyone unfamiliar or confused by some of the replies to my previous post here is a pic of the Innovate/Sprintex S/C kit (non-inter cooled) on a 2013 FRS here at the shop today.
This kit uses the OEM intake air temp sensor which is is located right after the air filter but before the supercharger. So, air temp is not taken after the air has been compressed. The intake temps could be extreme without knowing.
20819702_1688407434545107_8063906941889231692_o.jpg?oh=bc75991618a136c0da95ffda66ee8f07&oe=5A338700
Another 2012 STi in for some major work. We will be rebuilding/upgrading the engine, upgrading the turbo, upgrading the fueling, upgrading the clutch and adding some chassis bracing. Yes, the car will need to be re-tuned with the new modifications.
Began work on the car today. The first Cusco chassis brace is installed.
20819233_1689152524470598_5003953773131940368_o.jpg?oh=62b448e23f6bab4af46b506ea1a62be9&oe=5A25D0EE
20863500_1689152947803889_920358697938170657_o.jpg?oh=b99582a175808197b8a42c0dda544ec5&oe=5A24FF21
20863588_1689152894470561_3930793201908819664_o.jpg?oh=c5f759a8d7a7f63c29096f430f2b57b0&oe=5A1960ED
20901548_1689152981137219_855957645285263412_o.jpg?oh=a46646a6f9fda5b5c787349fee4b303e&oe=59EEA48C
2017 WRX from today. Installed a Mishimoto radiator and reservoir, Whiteline front and rear sway bars with adjustable links, Rally Armor flaps, Subie Speed lower rear brake lamp and a set of black trunk badges.
20988460_1693415710710946_2920662752869191985_o.jpg?oh=294ef5b55eec086a0cd170b90bf28f60&oe=5A28A321
20988415_1693415840710933_3750658458425071460_o.jpg?oh=2780a6cfa30d2b8de45722d1ab38a175&oe=5A313CBB
20989127_1693415864044264_8254483390126495982_o.jpg?oh=be087f581913e48978f2c58111a81151&oe=5A18E9A0
21032899_1693416014044249_1354058245851374546_n.jpg?oh=bce1606198336ce06cc89430e89ec6cb&oe=5A2DD0FB
20621985_1693416090710908_2419387971770609578_n.jpg?oh=02944cbefd5dbc01250cb9e2b9beb2bf&oe=5A3223C3
One of, if not the worst assembled FA20 engines I have come across yet. For starters, both valve covers are broken. One has a crack that looks suspiciously like a rocker flipped, the other has a "wad" of silicone I have zero explanation for except that they dropped the cover on the floor breaking it and used the silicone to "seal" it rather than replace it. Not to mention the silicone oozing from everywhere, the scored camshafts, the broken cam gears, the oil pump that is 50% worn and more. The owner had no idea any of this was there. The engine lasted less than 4000 miles. Hmmm...
20988527_1695130873872763_4281048629960801282_o.jpg?oh=989c68815a6a0e8ce1b4d6ad6364dc5d&oe=5A355370
21054871_1695130923872758_3112838762530538158_o.jpg?oh=fdf13bd092a79db78b9fd17ac734e599&oe=5A232473
This newly released item showed up at the shop today. These are currently not stocked in the US and are special order from Japan. But a BIG THANK YOU to AVO Japan for the opportunity to get our hands on this first and review/test it. If interested we can certainly supply these to our customers. Retail price is $399, regular Infamous Performance price is $360.
AVO Silicone Intake Pipe Wire Reinforced
Red P/No: S7W15841AREDJ
Blue P/No: S7W15841ABLUJ
Black P/No: S7W15841ABLKJ
Fitment: 2015+ Impreza WRX and Forester 2.0L DIT engine (FA20DIT) and the 10-13 Subaru Legacy GT.
AVO`s Silicone wire reinforced intake pipes are world renowned in the Subaru community for being the largest and strongest in the market. We made no exceptions on the FA20, it`s Unique Registered Pattern Design has integrated the BOV mount direct to the turbo to stop issues with the stock plastic pipe breaking. T he AVO FA20 intake pipe goes from the front of the turbocharger all the way to the air box with no joints and no interruption in flow to the turbocharger. This intake pipe can be used with the stock turbo and also with the AVO Turbo Kit.
21083057_1695826183803232_9098377609040823584_o.jpg?oh=1c13a57cbf7976196fc461d3dff074a7&oe=5A5F250E
21014131_1695826393803211_4599968875580877132_o.jpg?oh=200eb0a223f03cd8ee230d5d7562a005&oe=5A1C196F
21054891_1695826733803177_290407981428074720_o.jpg?oh=0edb15f9380d65b0b75a77c1e7a2a3a3&oe=5A1708B8
21016011_1695826920469825_5656620978990906657_o.jpg?oh=43077e1c466d164dbb93b3efeb534e37&oe=5A1697B4
21078286_1695827077136476_3432672254594718882_n.jpg?oh=5df819aa85a1e944892d4c4075f46eb4&oe=5A190E52
21016064_1695826903803160_8018331640543957732_o.jpg?oh=b778207ce9765a757fa8b89e14fad117&oe=5A30CAC9
A 2012 WRX freshly rebuilt (it had lifted the heads) and ready for pick up. CP Pistons, King bearings, H Beam Rods, new STi heat treated crank, 1/2" ARP head studs, 11mm STi oil pump, JE Proseal gaskets, etc. A new Koyo Racing radiator too. Should handle the e85 power without issue now.
21083728_1696394780413039_6137225652222421963_o.jpg?oh=77eb7c8adc9000b607bba8d2c6ee2e6f&oe=5A187696
While performing an oil change on the shop Forester today (hard to believe we already have over 17k on the new engine) we added a Cusco Type 1 front power brace. A Type 2 brace will not fit until/unless we install a custom catless header.
21191942_1699995070053010_2492383753061161679_n.jpg?oh=7be71550800b8a596bf53541683d15e6&oe=5A611A84
So much want!
2007 Legacy SpecB. Built motor, plenty of mods, SoCal Porting VF52 turbo, Delicious Tuning Flex Fuel kit and tune.
The dyno numbers (from our Heart Breaker Mustang)...
269awhp on ACN91 pump gas
355awhp on e-60 (e85)
21248586_1701335866585597_3039564439435270468_o.jpg?oh=eb1a5f3f331b6cd8ec66d0a60416eee4&oe=5A5E6F5B
21192162_1701335896585594_2387679716185493544_n.jpg?oh=547177aa883aa4a59574a663151e55ba&oe=5A1F2BCE
21150362_1701335933252257_2241040716441467196_n.jpg?oh=323cd13230964078804fd491314e4cbe&oe=5A283870
2016 WRX in for some parts installs today. Today we installed:
KillerB header, Grimmspeed 3 port EBCS, Perrin BPV, Grimmspeed charge pipe, Grimmspeed TMIC, Perrin shifter stop .
Previously we had installed a Invidia turbo back exhaust and AEM intake.
The car goes back on the dyno tomorrow for a tuning adjustment (car was previously tuned here). Tune provided by Bill Knose of Delicious Tuning.
21200803_1702369203148930_4365468978602460926_o.jpg?oh=2d8af499be2a482b69e8cb703e8a39e7&oe=5A5FC654
21230858_1702369256482258_2080464386693329157_n.jpg?oh=79c7fac5f8a67d8bef40170fcfb1f683&oe=5A217388
21248158_1702369359815581_5758501745378788490_o.jpg?oh=6863eebf078389447c0610eb8166884d&oe=5A552DD3
21246253_1702369613148889_728184463511137508_o.jpg?oh=4161eb645e87af3f914cae1932519b76&oe=5A594515
21246232_1702369759815541_3750163892464551968_o.jpg?oh=19dbfa91462a02482f6b0eef6d91a00e&oe=5A57773D
Love how well this car hides the mods. You really can't see the header or bpv unless you look under the car. I'm sure that helps when it comes to smog visuals.
