m sprank Posted April 21, 2017 Author Share Posted April 21, 2017 Oh no, what happened to the shop Forester??? After a "few" miles of running a mildly aggressive stance the front wheel bearings gave out. This was to be anticipated, its what makes a Subaru a Subaru. So, rather than just replace... upgrade time. New knuckles (housings), new bearings, new inner and outer seals, new c-clips, new hubs and new ARP extended wheel studs. Almost ready for auto-x now. Link to comment Share on other sites More sharing options...
m sprank Posted April 25, 2017 Author Share Posted April 25, 2017 Late Monday bump for Subaru service. Link to comment Share on other sites More sharing options...
m sprank Posted April 25, 2017 Author Share Posted April 25, 2017 Its not a Subaru without a dog riding shotgun (at least once). Mario never seems to mind the traffic. He just cant decide which is his favorite Subaru to ride in. Link to comment Share on other sites More sharing options...
m sprank Posted April 27, 2017 Author Share Posted April 27, 2017 This 2008 STi came in with no engine under the hood and no replacement engine. It had not run in almost 2 years. I left a few of the "yellow tags" in place that the owner put on items to remind him of issues when he reassembled the car. Like many projects men start with good intentions... Today, it is alive again. Link to comment Share on other sites More sharing options...
Flinkly Posted April 27, 2017 Share Posted April 27, 2017 don't forget to put the intake snorkus on and good work. always checking in here to see what's new. * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
m sprank Posted April 28, 2017 Author Share Posted April 28, 2017 don't forget to put the intake snorkus on and good work. always checking in here to see what's new. None was provided and I have none. If the customer wants to pay for one/provide one it is not a problem (I would install it for free). We made it to Friday. Have a great weekend! Link to comment Share on other sites More sharing options...
m sprank Posted May 2, 2017 Author Share Posted May 2, 2017 Another engine completed. Break in has begun and the car is ready to hand over to the customer. 2004 STi. The engine now contains a new 2013+ STi heat treated crank, H beam rods, CP pistons, King bearings, ARP studs, KillerB pick up and tray and more. Time to get back to the track for this 3 time champ. Link to comment Share on other sites More sharing options...
m sprank Posted May 3, 2017 Author Share Posted May 3, 2017 It has been a productive week (so far). Began break in driving on this fresh engine last night. This 2006 WRX now has 2013 STi heat treated crank, CP pistons, H beam rods, King bearings, ARP 1/2" head studs, JE Proseal gaskets, air pump delete, Perrin Inlet tube, Precision turbo, 1000cc injectors, Perrin FMIC, KSTech 73mm intake, Tomei headers and up pipe, TBE, South Bend Stage 3 clutch, and a Delicious Tuning break in map. This car should be ready for customer pick up on Thursday. Link to comment Share on other sites More sharing options...
m sprank Posted May 3, 2017 Author Share Posted May 3, 2017 Forged CP piston. Approx 3200 miles on the engine. This is what detonation and temperature do to engine internals. Opened up the top compression ring land and warped the crown of the piston causing it to kiss the head. Porcelain on the plugs is cracked/broken. Small end of the rod bushings are "pounded flat". Leak down is "fair" at 14-15% and I have concerns the exhaust valves got too hot. Bad gas? Bad injector(s)? Bad pump? Bad fuel pressure regulator? Bad tune? Link to comment Share on other sites More sharing options...
m sprank Posted May 4, 2017 Author Share Posted May 4, 2017 FRS FA20, run with low/no oil until it seized. If you have never heard, Subarus have a reputation for oil consumption. It can happen. Please check your oil level periodically. Link to comment Share on other sites More sharing options...
m sprank Posted May 5, 2017 Author Share Posted May 5, 2017 Another nice STi ready to go. Have a great weekend!!! Link to comment Share on other sites More sharing options...
m sprank Posted May 8, 2017 Author Share Posted May 8, 2017 Continuing work on decreasing under hood and oil temps in the '12 STi. Some parts came back from getting hi temp ceramic coated. Time to start wrapping. Link to comment Share on other sites More sharing options...
Flinkly Posted May 8, 2017 Share Posted May 8, 2017 who's coating? tech-line or jethot? * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
m sprank Posted May 9, 2017 Author Share Posted May 9, 2017 Olympic Coatings did the work for us. The TBC is similar to tech-line. A 2011 WRX came in yesterday with low boost. Upper catalytic converter in the down pipe is coming apart restricting exhaust flow (increased back pressure). Not the first time we have seen this. Easily rectified and the car is back on the road now in stage 2 trim. We were even able to send the customer home wit a nice bag of goodies that fell out of the down pipe upon removal. Link to comment Share on other sites More sharing options...
m sprank Posted May 10, 2017 Author Share Posted May 10, 2017 Another 2011 WRX completed today. Installed Cobb 1000cc injectors, AEM fuel pump, Cobb flex fuel kit, Cobb 3 port EBCS, Cobb turbo inlet tube, Process West Verticooler, Turbosmart BPV and a Delicious Tune (Cobb AP). Link to comment Share on other sites More sharing options...
m sprank Posted May 11, 2017 Author Share Posted May 11, 2017 Progress made today on our 2012 STi project car. Current focus is decreasing under hood and oil temps. All the hi temp coated (and wrapped) exhaust parts are installed and the car is up and running again. Next step is "ducting" for the oil cooler. Link to comment Share on other sites More sharing options...
m sprank Posted May 12, 2017 Author Share Posted May 12, 2017 It is finally Friday. What are you doing for Mom on Mothers Day this weekend? Track day??? Moms love track days! Have a great weekend and Happy Mothers Day!!! Link to comment Share on other sites More sharing options...
m sprank Posted May 15, 2017 Author Share Posted May 15, 2017 Hope you had a great weekend. We are back to work today. Finishing up a 2015 STi now (alignment). This morning we installed new RCE yellow springs and SPC rear lower control arms along with some fresh meats. Link to comment Share on other sites More sharing options...
m sprank Posted May 16, 2017 Author Share Posted May 16, 2017 Ummm, who did your vinyl wrap? Because I think they missed a spot. It actually gets worse from here. Very poor work. I suspect the owner did not exactly get what they paid for. Sad. Link to comment Share on other sites More sharing options...
m sprank Posted May 18, 2017 Author Share Posted May 18, 2017 Working on an FRS project car today. Installing a Jackson Racing dual radiator/oil cooler, RSR coil overs, Whiteline rear lower control arms, Whiteline subframe bushings, StopTech 355/345mm front and rear BBK, Rays wheels, Michelin Pilot Super Sport tires and more. Link to comment Share on other sites More sharing options...
m sprank Posted May 18, 2017 Author Share Posted May 18, 2017 2016 WRX. Just completed an install of the new Whiteline lowering springs. With the addition of the wheels and tires the car has a new "attitude" and custom look. A cat back exhaust is next on the owners wish list of mods. Link to comment Share on other sites More sharing options...
m sprank Posted May 20, 2017 Author Share Posted May 20, 2017 Another 2016 WRX. Cobb catted j-pipe and a Grimmspeed TMIC then the car is on the dyno. That is Bill Knose of Delicious Tuning performing his magic on our Mustang dyno. Have a great weekend! Link to comment Share on other sites More sharing options...
m sprank Posted May 22, 2017 Author Share Posted May 22, 2017 This 2002 WRX had not run in over 3 years. We rebuilt the engine and turbo, serviced the transmission/diffs and got her up and running and back on the road. Smog certification was completed today. The car is now ready for pick up. Another Subaru taken off the back 40 and put back into use. Now the owner gets a second chance to enjoy the car again. Link to comment Share on other sites More sharing options...
Rhitter Posted May 23, 2017 Share Posted May 23, 2017 Progress made today on our 2012 STi project car. Current focus is decreasing under hood and oil temps. All the hi temp coated (and wrapped) exhaust parts are installed and the car is up and running again. Next step is "ducting" for the oil cooler. I have an after market header, I have a KB oil pan. Time to bling tape all of it! Any idea if it made a difference? or too soon to tell? Adding an after market oil cooler? or just going to run a hose to the OEM heat exchanger / oil cooler? How is the Legacy race car doing? My OBXT build Link to comment Share on other sites More sharing options...
m sprank Posted May 23, 2017 Author Share Posted May 23, 2017 It makes a difference. Still need time for full testing, but it is already helping. We have a Perrin oil cooler installed already and are in process of making a brushed stainless "duct" for it now to increase efficiency of the cooler. Be careful when "insulating" the oil pan. You dont want to keep the heat in the pan, you just want to keep the extra heat out. So, only insulate what needs it. Max (LALGT) car has been down for some time. He decided to start racing Miatas as they are far cheaper to maintain then the LGT. Currently, it needs a new engine. 35+ track events (large track) will do that. Link to comment Share on other sites More sharing options...
