bmglaude Posted March 18, 2012 Share Posted March 18, 2012 Looking for some assistance diagnosing why my cooling fans won't stop cycling on/off at idle? Hope someone can help! Link to comment Share on other sites More sharing options...
authenticamd Posted March 18, 2012 Share Posted March 18, 2012 It's suppose to do that. The car is heat soaking at idle. Link to comment Share on other sites More sharing options...
cseagle08 Posted March 18, 2012 Share Posted March 18, 2012 Is your A/C on? usually just having AC or Defrost on will automatically start to cycle the fans. Link to comment Share on other sites More sharing options...
Balrock Posted March 18, 2012 Share Posted March 18, 2012 Not sure where you live, but if it is constant on and off it has nothing to do with heat soak. If your car is an 05 there is a recall for a bad relay fan switch and if it is not cought in time the the ECU had to be replaced. Check with your local dealer. Link to comment Share on other sites More sharing options...
lee07 Posted March 19, 2012 Share Posted March 19, 2012 Not sure where you live, but if it is constant on and off it has nothing to do with heat soak. If your car is an 05 there is a recall for a bad relay fan switch and if it is not cought in time the the ECU had to be replaced. Check with your local dealer. Didn't know about this. So should I go get this replaced? My fans are working just fine though. On when it's suppose to and off when not needed Link to comment Share on other sites More sharing options...
Max Capacity Posted March 19, 2012 Share Posted March 19, 2012 You may want to check and see if the recall is still being done, on a 7 year old car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Balrock Posted March 19, 2012 Share Posted March 19, 2012 You may want to check and see if the recall is still being done, on a 7 year old car. Yeah, I did say chek with the dealer. Link to comment Share on other sites More sharing options...
bhinak Posted March 20, 2012 Share Posted March 20, 2012 Check the test connectors. See if they are clipped together. Link to comment Share on other sites More sharing options...
frank_ster Posted March 20, 2012 Share Posted March 20, 2012 if there clipped together the car isn't gonna run Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted March 20, 2012 Share Posted March 20, 2012 it could be because of the a/c .. turn ac off.. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
thisisthenewsic Posted March 20, 2012 Share Posted March 20, 2012 You may want to check and see if the recall is still being done, on a 7 year old car. mine got fixed a few months back. its an 05 lgt with 137k miles. mine had the ecu and relay replace and the recall is is the fans stay stuck on all the time. not if they are cycling on/off Link to comment Share on other sites More sharing options...
RuskiTrombone Posted March 21, 2012 Share Posted March 21, 2012 if there clipped together the car isn't gonna run Car does run with the test connectors clipped together. Link to comment Share on other sites More sharing options...
frank_ster Posted March 21, 2012 Share Posted March 21, 2012 but it would say er hc on the odo no? and the water temp gauge full up Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ouch1011 Posted March 23, 2012 Share Posted March 23, 2012 but it would say er hc on the odo no? and the water temp gauge full up Only says that when a flash is in progress because the ipc cannot communicate with the pcm. With the test connectors jumped, the fan will cycle on and off and the cell will flash. Link to comment Share on other sites More sharing options...
