fahr_side Posted March 26, 2012 Share Posted March 26, 2012 I had no idea the ecu had logic to interpret and/or predict OL fueling trims because the narrowband is clearly not designed for WOT monitoring. I did not know range D means that much percentage is changed from there on and higher ranges. Good to know For one thing, the MAF scaling on later models is deliberately on the side where the car will normally run richer than called for in the tables and let the ECU trim fuel leaner in CL, based off the values the O2 sensor reads. For another, the logic is set up to use the D-range trim in OL because it's assumed that any condition that exists in CL to cause the system to run either rich or lean, whether mechanical or through climatic conditions, will still be present in OL and both could and should be compensated for. In the absence of reliable input from the O2 sensor the best data available is the calculated trim from range D, and applying that is better than just reading from the table and applying the temperature compensations alone. At least that seems to be what Subaru was thinking... Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
bmx045 Posted March 26, 2012 Share Posted March 26, 2012 Interesting. I love having a wideband, there's no question or wondering what you're doing while wot. at the moment, and I think I need to tweak the scaling, I'm running 11.3 WOT where my targets are 11.13. No knock so I'm procrastinating. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 27, 2012 Author Mega Users Share Posted March 27, 2012 leak after THAT leak is fixed and ECU is reset once again. Apparantly I have another one, but I can't find it. romraiderlog_20120326_200759.csv "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 LV is definitely better. now. continue to listen. you said your car ran great before hows it feel now? Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 27, 2012 Author Mega Users Share Posted March 27, 2012 i have a shit ton of knock and the LV looks like shit. The car SOUNDS a lot better with that fixed. I guess it runs better. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 that LV does not show a shit ton of knock. your trims are still off so track that down and reassess the small knock you do have. at the moment that knock is not to be concerned about. Link to comment Share on other sites More sharing options...
iNVAR Posted March 27, 2012 Share Posted March 27, 2012 I can't see your picture. I left my microscope in high school. Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 Right at the t bolt wedge like i mentioned at the meet Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 27, 2012 Author Mega Users Share Posted March 27, 2012 ya ya ya ya "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 27, 2012 Author Mega Users Share Posted March 27, 2012 I think that it's either my MAF O ring that is ripped apart, or my O2 sensor is going. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 If the maf does not have an air tight seal that could cause your trim issue. Autozone has an oring kit you can buy that has all size orings. Harbor freight might...worth a shot Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 27, 2012 Author Mega Users Share Posted March 27, 2012 thanks brosef "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
m sprank Posted March 27, 2012 Share Posted March 27, 2012 O2 sensor going will manifest itself in fluctuating idle, stumbles and a nice CEL. Harbor Freight should have the o-rings in their "kit". At least one of them, they sell at least 3 different kits, lol. Link to comment Share on other sites More sharing options...
bmx045 Posted March 27, 2012 Share Posted March 27, 2012 I amazingly found one suitable for my top injector oring. Believe it or not. It said petroleum product safe orings. So win. Ill have to get the brand kit from my friend. Very very handy. Link to comment Share on other sites More sharing options...
m sprank Posted March 27, 2012 Share Posted March 27, 2012 Harbor Freight sells Viton (fuel rated) o-rings in a kit. Never checked, but there might be the proper size for fuel injectors in there. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 28, 2012 Author Mega Users Share Posted March 28, 2012 Ahhhh yaaaa the car is definitely running a lot smoother, better, faster. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 28, 2012 Author Mega Users Share Posted March 28, 2012 Harbor Freight sells Viton (fuel rated) o-rings in a kit. Never checked, but there might be the proper size for fuel injectors in there. I'll be putting an order in for a Clutch and some other goodies soon. Promise. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 28, 2012 Share Posted March 28, 2012 Look at you $$$ tree Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 29, 2012 Author Mega Users Share Posted March 29, 2012 Everytime I try to launch the road dyno airboy thing in RR it says the defninitions can't be found or something. anything special way to do this on a WinXP? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 29, 2012 Share Posted March 29, 2012 cars.xml is needed for RR, download it Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 29, 2012 Author Mega Users Share Posted March 29, 2012 i did and extracted it in the RR directory. Still comes up with that error message. I think I'm just going to have to dig into the RR forum to see whats going on. Wait, I said I said WinXP, I meant Win Vista. Vista blowwwws. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted March 29, 2012 Share Posted March 29, 2012 yeah, in C:\Program Files\RomRaider should be the file cars_def.xml Link to comment Share on other sites More sharing options...
mr.hicksta Posted March 29, 2012 Share Posted March 29, 2012 Fun fact: Vista is Latin for 'Worst f&*king operating system ever' Link to comment Share on other sites More sharing options...
bmx045 Posted March 29, 2012 Share Posted March 29, 2012 win 7 is win i've been into computers and electrical engineering for a while as a side hobby, i havent whitnessed this good of an OS since windows 2000 professional. Link to comment Share on other sites More sharing options...
mr.hicksta Posted March 29, 2012 Share Posted March 29, 2012 Windows 7 is what Vista should've been. Vista = rushed release so customers were essentially beta testers. I'm running Windows 7 Pro on my netbook and have it stripped down so it's running great. No complaints at all Link to comment Share on other sites More sharing options...
