bmx045 Posted March 2, 2012 Share Posted March 2, 2012 you have an 06 spec b, lol, the bastard year Link to comment Share on other sites More sharing options...
Lardo420 Posted March 2, 2012 Share Posted March 2, 2012 sounds like your spec b is on the 2.5i level right now bro Link to comment Share on other sites More sharing options...
charlie_sheen Posted March 2, 2012 Share Posted March 2, 2012 Right - hence stage 3.5. Upgraded turbo + spec.b haters. [ame=http://www.youtube.com/watch?v=pjC1r72hYgQ]Senor Chang - Gay - YouTube[/ame] Link to comment Share on other sites More sharing options...
Max Capacity Posted March 2, 2012 Share Posted March 2, 2012 If you need a shortblock here; http://www.heubergermotors.com/parts/index.htm 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted March 2, 2012 Share Posted March 2, 2012 http://media.tumblr.com/tumblr_lzdg1vtX561qbnggp.png Link to comment Share on other sites More sharing options...
dmp Posted March 2, 2012 Author Share Posted March 2, 2012 If you need a shortblock here; http://www.heubergermotors.com/parts/index.htm that's a good link. $300 cheaper than fredbeans, but $120 more expensive in shipping. Still - will go that route, unless I find something cheaper-still. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
compsurge Posted March 2, 2012 Share Posted March 2, 2012 Get a killer b oil pickup or buy a new OEM as well. Throw in a new oil cooler and replace or remove the banjo bolt filters. Link to comment Share on other sites More sharing options...
dmp Posted March 2, 2012 Author Share Posted March 2, 2012 Thanks...and the OCV's. too. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
compsurge Posted March 2, 2012 Share Posted March 2, 2012 Also PM m sprank for motor. Link to comment Share on other sites More sharing options...
bmx045 Posted March 2, 2012 Share Posted March 2, 2012 the ocv's will be fine once they have oil going to them again, just clean them out Link to comment Share on other sites More sharing options...
dmp Posted March 2, 2012 Author Share Posted March 2, 2012 So - $4600 total. $2240 just in labor. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
bmx045 Posted March 2, 2012 Share Posted March 2, 2012 in the ass Link to comment Share on other sites More sharing options...
Max Capacity Posted March 2, 2012 Share Posted March 2, 2012 in the ass Stop looking at my girlfriend. Yea...right. LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 3, 2012 Share Posted March 3, 2012 OP, are you going to inspect the oil pickup tube for cracks? Link to comment Share on other sites More sharing options...
dmp Posted March 3, 2012 Author Share Posted March 3, 2012 I am. Thanks. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
dmp Posted March 5, 2012 Author Share Posted March 5, 2012 fwiw, I cut-open the oil filter sunday. Found nothing that shouldn't be there. Hope is, the metal stayed in the pan. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 I can't say that the filter contents are the determining factor in whether or not your engine was damaged. But if it's in your pan, the pieces were from the bearings....and that material is no longer where it should be. Link to comment Share on other sites More sharing options...
dmp Posted March 5, 2012 Author Share Posted March 5, 2012 It's all data/evidence. What I know now is, debris didn't significantly travel to the filter area (and likely beyond). SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 it's not that the debris damaged anything, it's the fact that the bearings had no oil for a second or two and the pieces came from them and dumped out with the return oil back into the pan. the pieces very well may not have recirculated around the system and your turbo and heads may be okay...but we can't be sure yet....it doesn't take obvious carnage in the pan to do damage, can be just as much as flakes that will wreak havoc in the system and can be sucked up through the pickup(even though it has a grate on it to filter big objects) Link to comment Share on other sites More sharing options...
Lardo420 Posted March 5, 2012 Share Posted March 5, 2012 your oil pan probably looks like this Link to comment Share on other sites More sharing options...
dmp Posted March 5, 2012 Author Share Posted March 5, 2012 it's not that the debris damaged anything, it's the fact that the bearings had no oil for a second or two and the pieces came from them and dumped out with the return oil back into the pan. the pieces very well may not have recirculated around the system and your turbo and heads may be okay...but we can't be sure yet....it doesn't take obvious carnage in the pan to do damage, can be just as much as flakes that will wreak havoc in the system and can be sucked up through the pickup(even though it has a grate on it to filter big objects) Quite possible. Again - just trying to get as much info as possible; won't know till I know, ya know? your oil pan probably looks like this Well...my car still runs/starts fine. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 change the oil and hope for the best i guess if it sounds fine Link to comment Share on other sites More sharing options...
Max Capacity Posted March 5, 2012 Share Posted March 5, 2012 May be buy a lottery ticket...lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dmp Posted March 5, 2012 Author Share Posted March 5, 2012 change the oil and hope for the best i guess if it sounds fine Doesn't change the knocking I heard; as somebody said, engines don't typically heal. Twas the knocking and light I saw which drove this thread - then, after finding the "gold" - I believe I have no choice but to try and replace the shortblock. Maybe buy a lottery ticket...lol Lost on all three over the weekend. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 Well...my car still runs/starts fine. I said that they don't heal, but if it runs fine :confused::confused::confused::confused::confused::confused::confused::confused::confused: Link to comment Share on other sites More sharing options...
