slowGT Posted February 25, 2012 Share Posted February 25, 2012 I have the torx plus 50 socket. Obviously the WRX bolts are the same thread pitch but different head shapes. Are the lengths the same? If so I can save money and reuse the LGT bolts. The pressure bolts should also work from the LGT, or no? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted February 28, 2012 Share Posted February 28, 2012 Id believe its all the same. The only differnce is the head of the flywheel bolts. Link to comment Share on other sites More sharing options...
chutrain Posted February 28, 2012 Share Posted February 28, 2012 I would save the possible headaches down the road. You can strip those TP50 bolts and then it'll become a major task to get them out if needed. The WRX bolts are so much easier to use. Link to comment Share on other sites More sharing options...
Firepuma Posted February 28, 2012 Share Posted February 28, 2012 The new bolts are worth it. Link to comment Share on other sites More sharing options...
Sicotic Posted February 29, 2012 Share Posted February 29, 2012 i bought a WRX Flywheel for my clutch as well. it comes with new bolts, should i use those instead? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 1, 2012 Share Posted March 1, 2012 IMO if the new bolts are hex head, Yes use them. Make sure they will clear the inside of the clutch disc first. I would not use the 50+ torx POS's. The person that made them should be shot...if not worse. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OutbackXT05 Posted March 3, 2012 Share Posted March 3, 2012 No all you have to do to the guy is make him take the old T50's out to show him how stupid he was for the design. Link to comment Share on other sites More sharing options...
LongIslandLegacy2 Posted March 6, 2012 Share Posted March 6, 2012 dont forget the loctite too! Link to comment Share on other sites More sharing options...
