Need Engine Removal help
I need to pull the motor from my 05. The turbo is gone and there are copper particles in the pan. Didn't see what I was looking for while searching.
Is there a write up for removing and disassembling/reassembling the engine, or a good manual?
Anyone in Denver want to lend a hand?
Removing ang engine is not someting you can do on your own simply based upon forum advice.
If nothing else, get and read a haynes manual to give yourself an idea of what you're getting yourself in for.
How much experience do you have? What equipment do you have? Do you have a cherry picker, etc?
Here is my thread about rebuilding my motor: http://legacygt.com/forums/showthrea....html?t=122981
Engine removal: http://forums.nasioc.com/forums/show....php?t=1301065
Tear-down: http://forums.nasioc.com/forums/show....php?t=1435733
Where to start:
1. Remove battery
2. Remove OEM Airbox
3. Remove Intercooler
4. Separate downpipe (post-turbo in case you are new to Subarus) from turbo
5. Remove undertray
6. Drain coolant and remove radiator
7. Remove accessory belts
8. Remove alternator
9. Disconnect fuel lines w/ special tool, or at FPR (careful with this one obviously)
10. Disconnect main harness near turbo and ground harness under intercooler.
