Adoniram Posted February 24, 2013 Share Posted February 24, 2013 A couple months ago, I had a leaking valve cover gasket. At first it just smelled like burning oil, then it started smoking a little (seeping out under the scoop at stop lights, etc). Then it became an enormous cloud of smoke... then I replaced the gasket It was a PITA, but I did it all at the same time as the 60k service, and replacement of the driver's side CV axle (due to busted boot) Link to comment Share on other sites More sharing options...
adreyna Posted February 24, 2013 Share Posted February 24, 2013 I dropped it off at a shop to get looked at even more thoroughly this week. I really hope it's not the turbo. . . . I wanted to buy the infamous oil pick up but I don't think it'll get here in time. . . . Link to comment Share on other sites More sharing options...
joemo Posted February 25, 2013 Share Posted February 25, 2013 I had the seal on my oil cooler replaced should fix it. Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted February 26, 2013 Share Posted February 26, 2013 any thoughts on this? this is a coolant line leaking oil...how f***** am i? SMH http://i1289.photobucket.com/albums/b514/CoolHandLuke12/subarulegacy05/IMAG1127_zps0f675136.jpg Link to comment Share on other sites More sharing options...
Adoniram Posted February 26, 2013 Share Posted February 26, 2013 Awfully hard to tell from the pic, but that looks like a TINY amount of fluid. What color is your coolant? If it's old (or the orange kind), it can easily appear brown or rust-colored. Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted February 27, 2013 Share Posted February 27, 2013 Coolant is green, but I touched that line, it smells and is oil for sure Link to comment Share on other sites More sharing options...
zepplinluvr2 Posted June 10, 2013 Share Posted June 10, 2013 I have an oil leak coming from under my turbo. When you get under it, you can see the oil, but you can't see where it's coming from. Any ideas? Not too much smoke, and not losing a ton of oil, but underneath the turbo, it looks like I lost a ton of oil. It's coming down from higher up around the turbo also. I'm thinking it's a common leak. What do you guys think it is? Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted June 11, 2013 Share Posted June 11, 2013 any pictures? and when you say under the turbo....only thought it the oil return line? Link to comment Share on other sites More sharing options...
CoolHandLuke12 Posted June 11, 2013 Share Posted June 11, 2013 http://i1289.photobucket.com/albums/b514/CoolHandLuke12/subarulegacy05/IMAG1085_zps1fc7edb0.jpg Link to comment Share on other sites More sharing options...
zepplinluvr2 Posted June 12, 2013 Share Posted June 12, 2013 I replaced my turbo inlet yesterday, and I saw a hose with a hose clamp on it. Not like the one picture above, but the kind you have to un screw to loosen. I tightened it down because it was loose, and I think that might have fixed my problem. I also was able to really tighten the Coolant line to my turbo, which was very loose also. I did my spark plugs also. Link to comment Share on other sites More sharing options...
zepplinluvr2 Posted June 12, 2013 Share Posted June 12, 2013 It could still be leaking though, it's hard to tell. I am going to do a down pipe soon, and when I do that, I'm going to check all my hoses to my turbo. Link to comment Share on other sites More sharing options...
mikeshilk Posted July 10, 2016 Share Posted July 10, 2016 Have been having the same issue with my 05 Legacy GT. I replaced the turbo after it failed about 18 months ago, just about 100k miles. Mechanic said to expect the oily smell for a few weeks afterwards since the turbo had dumped a lot of oil everywhere. It went away but then came back over last winter. Finally got the car in and changed the valve cover gasket but smell persists. Symptoms are much the same, i.e., occurs after running hard (turbo kicks in) and then I get the smell and even some smoke from under the hood. No noticeable decrease in oil volume. Will take it back and have them check the PCV valve and let everyone know how it turns out. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 10, 2016 Share Posted July 10, 2016 Was the oil return hose replaced ? They will get hard with age and can crack and leak. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
