scans007 Posted August 4, 2005 Share Posted August 4, 2005 ^^ +1 with out this tip from the DM, I would've never gotten them off. I actually tried once before and gave up. I thought a shop was gonna have to do it.......this method works AWESOME..... Link to comment Share on other sites More sharing options...
eVoMotion Posted August 4, 2005 Share Posted August 4, 2005 WOW! Great tip! Link to comment Share on other sites More sharing options...
whoopwhoop Posted August 30, 2005 Share Posted August 30, 2005 how are the Coilovers treating you??? Link to comment Share on other sites More sharing options...
whoopwhoop Posted September 8, 2005 Share Posted September 8, 2005 Secret: use a long breaker that extends to the ground so nobody has to hold it (and you have almost unlimited resistance). Put a ratchet on the other end and jack it up with a jack until loose. Hammer and punch (screwdriver in my case) to get the bolt out. Rinse and repeat. how are the coilovers treating you??? Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 9, 2005 Author Share Posted September 9, 2005 how are the coilovers treating you??? Fine. Link to comment Share on other sites More sharing options...
BrownBoy Posted September 9, 2005 Share Posted September 9, 2005 ^ That's a half assed answer DM! I think the man was looking for a little bit more than that. Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 9, 2005 Author Share Posted September 9, 2005 ^ That's a half assed answer DM! I think the man was looking for a little bit more than that. The ride is still good, but I still get clunks from the front suspesion even after checking everything. Meh, I guess I'll have to live with it. Link to comment Share on other sites More sharing options...
Xenonk Posted September 9, 2005 Share Posted September 9, 2005 The ride is still good, but I still get clunks from the front suspesion even after checking everything. Meh, I guess I'll have to live with it. You're not hitting the bumpstops on the coilovers are you? Raise the car, loosen the camber plates, clean out any other debris, and then re-seat everything afterwards before lowering the car. Also check for your spring preload, it's very possible that the spring can float when the car has no load. You might also want to check the shock to see if it's already "wet". Last thing you want is a leaking shock. Keefe Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 9, 2005 Author Share Posted September 9, 2005 You're not hitting the bumpstops on the coilovers are you? Raise the car, loosen the camber plates, clean out any other debris, and then re-seat everything afterwards before lowering the car. Also check for your spring preload, it's very possible that the spring can float when the car has no load. You might also want to check the shock to see if it's already "wet". Last thing you want is a leaking shock. No. Did it already. Did it already. Checked. Nothing. Link to comment Share on other sites More sharing options...
highwaydrifter Posted September 12, 2005 Share Posted September 12, 2005 sounds like a binding strut.. had that happen to a buddies set of cusco's.. you can try luybing up the shaft a bit that may or may not help. anyone else concur? maybe you twisted the shaft during installation? trying to throw ideas out there.. (or over tightened them?) Link to comment Share on other sites More sharing options...
XT6Wagon Posted September 13, 2005 Share Posted September 13, 2005 Torque the bolt at the top hat like its your worst enemy... Link to comment Share on other sites More sharing options...
eVoMotion Posted October 14, 2005 Share Posted October 14, 2005 What has everyone done to secure the ABS and brake lines? Mine are ziptied. Link to comment Share on other sites More sharing options...
Drift Monkey Posted October 14, 2005 Author Share Posted October 14, 2005 What has everyone done to secure the ABS and brake lines? Mine are ziptied. Same. Link to comment Share on other sites More sharing options...
eVoMotion Posted October 14, 2005 Share Posted October 14, 2005 thanks! Same. Link to comment Share on other sites More sharing options...
scans007 Posted October 17, 2005 Share Posted October 17, 2005 What has everyone done to secure the ABS and brake lines? Mine are ziptied. Yup zipped http://www.pimpmyauto.com/Pictures/Ksport/Large/DSC02112.JPG More pics here: http://www.pimpmyauto.com/pic_coilovers.htm Link to comment Share on other sites More sharing options...
eVoMotion Posted October 17, 2005 Share Posted October 17, 2005 Did those brackets come with the coilovers? Mine did not. Link to comment Share on other sites More sharing options...
ProConcept Posted October 17, 2005 Share Posted October 17, 2005 Yeah, mine only came with 2 instead of 4. Link to comment Share on other sites More sharing options...
team23jordan Posted October 18, 2005 Share Posted October 18, 2005 so how does everybody who has Ksport coilovers like'em? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
scans007 Posted October 18, 2005 Share Posted October 18, 2005 Did those brackets come with the coilovers? Mine did not. Yeah what Pro said, except I got 2 per I love the ksports, took a long time to get the dialed in and feel'n great though Link to comment Share on other sites More sharing options...
big lou Posted October 18, 2005 Share Posted October 18, 2005 so how does everybody who has Ksport coilovers like'em? they are perfect now that the clunks are gone. Link to comment Share on other sites More sharing options...
zildjiank Posted December 12, 2005 Share Posted December 12, 2005 DM, your PM box is full...I can't send a PM... BTW, your setup looks AWESOME!!! Hot wheels...where did you get them? How much were they, if you don't mind me asking... Link to comment Share on other sites More sharing options...
scans007 Posted December 12, 2005 Share Posted December 12, 2005 DM is um.......well he can't check his PM's.... Link to comment Share on other sites More sharing options...
icandy Posted December 19, 2005 Share Posted December 19, 2005 just rereading this thread and heard a few people had clunks. what are these clunks, i'm a bit lost. Link to comment Share on other sites More sharing options...
scans007 Posted December 19, 2005 Share Posted December 19, 2005 It's just the way it sounds, like when you are driving around and hit bumps the ksports will make clunking sounds, just a sound that is not pleasent......I never really had them at all, it all comes down to the install..... Make more sense? Link to comment Share on other sites More sharing options...
eVoMotion Posted December 19, 2005 Share Posted December 19, 2005 Mine never made a peep until two months after the install. I now hear the springs move around a bit. I need to check and see if they are just loose or there is dirt in the seat or something. 6kg front springs are waiting for an install day now. Link to comment Share on other sites More sharing options...
